Question about Jeep 2006 Liberty Limited Edition
Fuel injector removal - Jeep 2006 Liberty Limited Edition
  • 35 Answers
Https://www.youtube.com/watch?v=gRNfT3oatmI
video is for a Laredo.
Liberty is basically the same procedure.
New O-rings are recommended before replacement.
Posted on Dec 30, 2014
How to install a fuel injector on a 2002 jeep liberty 3.7
so that mean the old one is all ready removed.?
or did you mean all steps in the fsm for INJECTOR.
the steps are the same on all EFI fuel rail injectors.
you could google that or you tube it or read the FSM.
hide call keys from step 2 on, or very bad things can happen.
(wife or kids no aware of danger)
ill just cover the (basics)
1: per FSM , depressurize the system, in can be at 60PSI
parked. so avoid fuel in eyes, or a fire. we do that first.
gain access to rail under failure. (RUF) (no barking)
2: remove injector X , wire plug. (failing)
3: then detach the injector rail clamps the both rails off as one....
injector are all now loose, to pull off.
4: add new seals to new injector, and install in reverse order.
that's it, only the gain access , varies,... mostly.
last depressure steps:
run engine,
remove fuel pump relay, engine stalls. key off, hide keys
next tje FSM words (just the OFF section)
  1. Remove fuel tank filler tube cap.
  2. Perform Fuel System Pressure Release Procedure.
  3. Remove negative battery cable at battery.
  4. Remove air duct at throttle body air box.
  5. Remove air box at throttle body.
  6. Disconnect fuel line latch clip and fuel line at fuel rail. A special tool will be necessary for fuel line disconnection.
  7. Remove necessary vacuum lines at throttle body.
  8. Disconnect electrical connectors at all 6 fuel injectors. Push red colored slider away from injector. While pushing slider, depress tab and remove connector from injector. The factory fuel injection wiring harness is numerically tagged (INJ 1, INJ 2, etc.) for injector position identification. If harness is not tagged, note wiring location before removal.
  9. Disconnect electrical connectors at throttle body sensors.
  10. Remove 6 ignition coils.
  11. Remove 4 fuel rail mounting bolts.
  12. Gently rock and pull left side of fuel rail until fuel injectors just start to clear machined holes in cylinder head. Gently rock and pull right side of rail until injectors just start to clear cylinder head holes. Repeat this procedure (left/right) until all injectors have cleared cylinder head holes.
  13. Remove fuel rail (with injectors attached) from engine.
end expert.
alldata.com
login and read all steps. that be best , then ask questions?
Jan 02, 2012 | 2002 Jeep Liberty
Can you remove the injectors on 2003 Jeep Grand Cherokee diesell whithout removing the engine not a lot of space to get the back injector out ???????
YEP REMOVE TOP ENGINE COVER AND DISCONNECT INJECTORS ELECTRICAL CONNECTOR,REMOVE FUEL RETURN LINE FROM INJECTOR, REMOVE FUEL INJECTOR HIGH PRESSURE LINE, REMOVE FUEL INJECTOR RETAINER AND RETAINING BOLT,THEN REMOVE FUEL INJECTOR FROM THE CYLINDER HEAD. YOU NEED A FUEL INJECTOR EXTRACTOR TOOL 9075A ON TO INJECTOR AND CYLINDER HEAD.YOU DONT HAVE TO REMOVE THE ENGINE.
Jun 29, 2011 | 2003 Jeep Grand Cherokee
1996 4.3 vortec S10. Cranks wont start when engine/ outside temp is cold. Have used starting fluid,will start and run rest of day. Fuel pmp is cycling relay is working,needed a tune up I replaced all...
The plenum shouldn't be damp with gas. Is it a throttle body fuel injection system?
Could be a leaky injector.
Fuel Meter Body & Fuel Injectors (4.3L Engine) Removal & Installation 1995-2002 Models (RPO L35) To Remove:
4.3L (RPO L35) Fuel meter body assembly gm_trk_sil15_02-04_43_fuel_metr_body_assy.gif
  1. Before servicing the vehicle, refer to the Cautions and Warnings in the beginning of this section
  2. Remove or disconnect the following:
    • Upper intake manifold (See: Upper Intake Manifold)
    • Fuel meter body
    • Injector retainer lock nuts (J) and retainer (K)
    NOTE: Use care in removing the fuel injectors to prevent damage to the electrical connector terminals. The fuel injector is serviced as a complete assembly only. Also since the injectors are electrical compartments, these injectors should not be immersed in any type of liquid solvent or cleaner as damage may occur. Fuel injector cleaning is not recommended.
  3. While pulling the poppet nozzle tube downward, push with a small tip punch down between the injector terminals until the injector is removed
To Install:
Note: When ordering new fuel injectors, be sure to order the correct injector for the application being serviced.
  1. Lubricate the new injector O-ring seals with clean engine oil.
  2. Install or connect the following:
    • Fuel injector (L) into the fuel meter body injector socket
    • Retainer (K) and injector retainer lock nuts (J) and tighten the nuts
      1. Torque to: 27 inch lbs. (3 Nm)
    • Fuel meter body
  3. Test drive the vehicle to confirm the repairs.
1993-2005 Models (RPO LU3) To Remove:
4.3L (RPO LU3) Fuel meter body assembly gm_trk_sil15_02-04_43_rpolu3_fuel_metr_body_assy.gif
  1. Before servicing the vehicle, refer to the Cautions and Warnings in the beginning of this section.
    • Fuel meter body
  3. While pulling the fuel injector downward, push with a small tip punch down between the injector terminals until the injector is removed
To Install:
  1. Lubricate the NEW injector O-ring seals with clean engine oil
    • Retainer (K) and the injector retainer lock nuts (J) and tighten the nuts
    • Fuel meter body
Jan 29, 2011 | 1996 Chevrolet S-10 Pickup
Replace fuel inj 2009 lincoln ls 3.9 eng
Check this procedure about V8 3.9L Fuel Injectors - Removal & Installation
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Relieve fuel system pressure.
  3. Remove or disconnect the following:
    Negative battery cable Engine appearance covers Fuel lines Fuel pressure regulator Fuel cross over elbow Fuel injector connectors Fuel injector clamping plates Fuel injectors
To install:
  1. Install or connect the following:
    Fuel injectors. Use new O-ring seals. Fuel injector clamping plates Fuel injector connectors Fuel cross over elbow Fuel pressure regulator Fuel lines Engine appearance covers Negative battery cable
  2. Start the engine and check for leaks.
  2. Disconnect the negative battery cable.
    CAUTION The engine appearance cover is equipped with a noise suppressor. If the noise suppressor becomes separated from the engine appearance cover it must be positioned on the intake manifold prior to installing the engine appearance cover.
  3. Remove the engine appearance cover and the noise suppressor, if detached.
  4. Remove the air cleaner outlet pipe.
  5. Release the fuel system pressure.
  6. Remove the four engine appearance cover mounting bracket nuts and the brackets.
  7. Disconnect the fuel pressure sensor electrical connector from the sensor.
  8. Disconnect the fuel pressure sensor vacuum connector from the sensor.
  9. Disconnect the eight fuel injector electrical connectors from the injectors.
  10. Disconnect the fuel temperature sensor electrical connector from the sensor.
  11. Disconnect the fuel supply tube retaining clip from the fuel injection supply manifold.
  12. Disconnect the fuel supply tube spring lock coupling.
  13. Remove the four bolts and the fuel injection supply manifold and fuel injectors as an assembly.
  14. Remove the fuel injectors from the fuel injection supply manifold.
    CAUTION Use O-ring seals that are made of special fuel-resistant material. Use of ordinary O-ring seals can cause the fuel system to leak. Do not reuse the O-ring seals.
  15. Remove and discard the 16 O-ring seals from the fuel injectors.
    Fig. Exploded view of the fuel injector mounting-3.9L engine shown
To install:
  1. Lubricate the new fuel injector O-ring seals with clean engine oil before installing.
    CAUTION Use O-ring seals that are made of special fuel-resistant material. Use of ordinary O-rings can cause the fuel system to leak. Do not reuse the O-ring seals.
  2. Install sixteen new O-ring seals onto the fuel injectors. Lubricate the O-ring seals with clean engine oil prior to installation.
  3. Install the fuel injectors and clips onto the fuel rail.
  4. Install the fuel rail and injectors as an assembly. Tighten the fuel rail bolts to 89 inch lbs. (10 Nm).
  5. Install the remaining components in the reverse order of removal.
Keep us updated.
Jan 14, 2011 | 2002 Lincoln LS
How do i chage the fuel injector for a geo metro 1997 LSI?
REMOVAL & INSTALLATION Fig. 1: Removing injectors from fuel rail 84245032.gif
Fig. 2: Make sure injectors rotate freely in cylinder head 84245033.gif
  1. Relieve fuel system pressure and disconnect the negative battery cable.
  2. Remove intake air hose between throttle body and intercooler.
  3. Remove accelerator cable.
  4. Unclamp PCV and fuel return hoses from deliver pipe.
  5. Unclamp injector wiring harness.
  6. Disconnect injector coupler.
  7. Remove cold start injector pipe from delivery pipe.
  8. Remove vacuum hose from pressure regulator.
  9. Remove fuel feed hose from delivery pipe.
  10. Remove pressure regulator from delivery pipe.
  11. Remove delivery pipe with injectors.
  12. Remove injectors from delivery pipe. To install:
  13. Replace injector O-rings and lubricate with fuel. NOTE: Make sure injectors rotate smoothly. If not, probable cause is incorrect installation of O-ring.
  14. Check if insulator is scored or damaged. If it is, replace with new one.
  15. Connect delivery pipe with injectors.
  16. Install pressure regulator to delivery pipe using a new O-ring.
  17. Install fuel feed hose to delivery pipe.
  18. Install vacuum and fuel return hoses to pressure regulator and clamp securely.
  19. Install cold start injector pipe to delivery pipe using new gaskets.
  20. Install injector coupler. Clamp injector wiring harness.
  21. Install PCV hose to cylinder head.
  22. Install throttle position sensor coupler.
  23. Install accelerator cable and adjust free-play.
  24. Install intake air hose to throttle body and intercooler.
  25. Connect the negative battery cable.
  26. Start engine and check for leaks.
Jul 03, 2010 | 1997 Geo Metro
After removing the fuel injectors and rail to remove the manifold, how do you reinstall the fuel injectors?
the same way you took it apart. put a little grease around the rubber seals so they will slide in easier. just tap on the fuel rail while lightly tapping it into place.
Mar 28, 2010 | 2002 Honda Passport
How do i get to feul injectors
YOU HAVE TO RELIEVE FUEL SYSTEM PRESSURE.REMOVE THE INTAKE MANIFOLD COLLECTOR.REMOVE VACUUM HOSE FROM THE FUEL PRESSURE REGULATOR.REMOVE FUEL HOSES FROM THE FUEL RAIL.REMOVE FUEL RAIL BOLTS AND INJECTOR HARNESS CONNECTORS.REMOVE INJECTORS AND FUEL RAIL AS AN ASSEMBLY.REMOVE INJECTORS FROM RAIL BY PUSHING THEM OUT.REMOVE DISCARD FUEL INJECTORS ORINGS REPLACE WITH NEW ORINGS LUBRICATE NEW ORINGS WITH CLEAN ENGINE OIL.YOU HAVE TO BUY ORINGS FOR FUEL INJECTORS AT THE DEALERSHIP.BESURE TO TAKE OLD ORINGS SO WILL GET THE RIGHT SIZE ORINGS.
Mar 20, 2010 | 1997 Infiniti.5 J30
My 2001 chevy blazer (v-6, 4.3L)., has a fuel injector problem and I would like to know how to repair the number 5 injector.
You will need to remove the fuel rail bolted to the intake manifold. There maybe a clip holding on the injector. Spraying some WD-40 on the ends of the injectors to aid removal, also when installing, spray some on the O-rings, will help in installing them. Make sure all are seated.
Mar 08, 2010 | 2001 Chevrolet Blazer
Changing fuel injectors
here is the answer,follow these steps one by one please: (1)relieve fuel pressure by using a fuel pressure gauge that also has a bleeder valve on it (2)disconnect the negative battery terminal (3)remove the intake manifold service cover (4)remove air intact duct between the air cleaner housing and the throttle body gasket.also remove the throttle body spacer bolts,remove the spacer and remove thegasket.discard the old gaskets. (5)Disconnect the fuel supply and return lines from the fuel rail. 960Disconnect the vacuum hose from the fuel pressure regulator. (6)Remove the nut that attaches the fuel rail end-point bracket retainer. (7)Disconnect the electrical connectors form all 8 fuel injectors and set the fuel injector harness aside. (8)Remove the fuel rail mounting bolts. (9)Remove the fuel rail and the fuel injectors as a single assembly. (10)Remove the fuel injectors one by one,by flipping up the U-clip retainer then pulling the injector from the fuel rail. (11)Remove the old O-rings from the injectors and be sure to use new ones when installing the new injectors. (12)Also use a new gasket when installing the spacer,also use a new throttle body gasket.>>when finished start car and check for leaks.and you're done.
Jun 21, 2008 | 2004 Ford F350
Jeep 2006 Liberty Limited Edition Logo
67 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
