Question about Lincoln Ranger 225 Engine Driven Welder and Generator Kohler Gas Engine
Having problem with poweroutlet and cant weld
Nothing
  • 5 Answers
You have to be more specific about your problem. Do you speak english? If not, ask your question in another language. What is the problem with the "poweroutlet"?
Posted on Dec 25, 2014
Still having the same probem i have a blown 02 sensor cant find a bung r anything its n right passenger side
So you have a hole in the exhaust where bung used to be? Weld in new bung. Or do you mean you can't find the existing O2 sensor?
Jun 18, 2015 | 1994 Ford Thunderbird
Phaser 8400 Fault 37,005.41:108192
power issue.
Check if the poweroutlet/cord is ok.
Otherwise engineer
May 30, 2013 | Xerox Phaser 8400 Laser Printer
2007 dodge caravan power outlet fix
do you mean the cigarrete lighter plug? check the fuses first.
Feb 11, 2013 | 2000 Dodge Caravan
I have a Lincoln Pro Core 100 wire feed welding machine; it is (5) years old. I use the machine often. A year ago I built a 5' X 20" barbeque pit out of pipe and attached a 2' X 2' X 4' smoker to it...
Hi:
There is nothing wrong with your machine. The Pro-core100 is a 20% duty cycle machine; meaning: that will work for 2 straight minutes of welding and then needs 8 minutes to cool down.
Just allow the machine to cool down, turn it off and start again after the 8 minute cooling process.
If this was useful to you please vote. Thanks.
Mar 29, 2011 | Lincoln Electric Welding Tools
Broken flex joint on exhaust
it would be the front pipe you can buy new at about 200-300 hundred or go to auto parts and ask for a flex tube they have 3 or 4 different sizes from 1 and a half inch to 2 and three quarters of inch it should costs 40 to 60 dollars and if you can weld with a mig welder you cut the pipe as close to the flex or weld as possible then install the new part and weld it or if you cant weld and no money is loose buy muffler clamps and tighten them on the pipe new part or find one in scrap yard that is better if theres a problem ask me i have done many
Jan 06, 2011 | 2002 Hyundai Accent
Clarke weld 85 en welds when gun trigger is not operated
hello make sure its not set on auto or the pin inside the set is not bent good luck
shaun
Mar 24, 2009 | Welding Tools
Wont spark or weld
lets go over the basics 1 do you have it set up ,the wire feader turned up at least to see if it sparks 2 do you have itset up at least to see if the amps are on enough to get a spark? try thoughs and see where you are,then turn those up enough to weld with . (make sure your wearing a good helmut .please you only get one pair of eyes!!!!!!!!! )hope this helps jojogunn.
Mar 13, 2009 | Hobart Handler 125 Ez
1997 jeep cheorkee no power at poweroutlet fuse ok
maybe unplugged on the back, you have to remove trip to get behind outlet and see if wire is plugged into back of it.
Sep 10, 2008 | 1997 Jeep Cherokee
Lincoln Ranger 225 Engine Driven Welder and Generator Kohler Gas Engine Logo
85 people viewed this question
Top Lincoln Electrical Supplies Experts
John Trevino
jdthefixer
Jay Finke
Jay Finke
Are you a Lincoln Electrical Supply Expert? Answer questions, earn points and help others
