Question about Ovens
My oven heating element does not heat, we heard a loud pop and it quit, model 79096112400 kenmore, where do i start checking
  • 932 Answers
Eddie, Start with either un-plugging your oven or turning the breaker off so that there is no chance of power being on so that you do not get electrocuted. More than likely your element has blown, and one way you can quickly tell is to run your hands carefully around the element and feel for any blistering or bubbles in the surface of the element. If there is anything that looks like a flash powder burn, that would be a good place to start. If you find any of those problems you will definitely need to replace your element. Usually there is a couple of 1/4" screws that hold the element in place. Take those out and see if you can carefully pull the wires connected to the element through the hole in the back of the oven bulkhead. If you cannot pull them through you will have to take of the back panel if the stove to be able to un-hook the wires. You should be able to find a new element at most appliance repair stores and if you do not have one close to you, you can order one online from Sears at Water Filters Lawn Garden Appliance Parts or another place would be Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns . Putting it back together is just a matter of reversing your steps taking it apart. Hope this helps!
Posted on Dec 10, 2014
  • 37 Answers
Hi Eddie. It sounds like a bad heating element. This is easily replaced and not too expensive at about $60 for a new heating element. First lets verify the heating element is bad. Follows these steps:
1. Find the 50 amp breaker to your oven in your electrical panel and turn the power off. Just to ensure your safety also unplug it from the wall (incase that pesky neighbor wants to see you break dance and decides to turn the breaker back on while you are working on the oven!)
2. Pull stove away from wall or out so that you can access the back panel.
3. Remove the back panel and look through the insulation on the lower 1/3rd of the oven to find the ends and connections to your heating element. There should be one wire on each side of it secured by a screw or slide on connector. At this time you only need to remove the wire on one side of the element. This is for testing and verification purposes.
4. After removing one end of the wire take a multimeter or any continuity tester and put one probe on each end of the heating element connection on the element itself. Right where the wire connects from the one side you removed, and you can place the other lead right on the connection/connector metal part of the element connector. If the heating element is bad as I suspect, you will see that there is an "Open Line" condition or zero continuity which means infinite ohms on an ohm meter. If the element is good you will have continuity and your meter will indicate 20-40 ohms. If you did not damage any electronic controls when the element blew, you will be good to go with a cheap element replacement. Otherwise you may have damaged electronic controls (control board) as well. Check out this link as it will have great information and Youtube videos to show you how to test and replace this element. Good Luck!
http://www.appliance411.com/faq/test-element.shtml
Regards,
Randy
Appliance411 FAQ Testing Range Stove Oven Cooktop Element
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Kenmore oven 317b6034
It sounds like the heating element is faulty. If it has a short, it will have a damaged place. A short causes a build up of amps until it can't take anymore and then a action will happen like a fuse blowing, which it the noise you hear. You can get replacement elements on Amazon fairly cheap. To fix, unplug the stove. Lift and tug on the element to pull it out of the socket. It is usually easy.
Rich Long
Jan 26, 2014 | Kenmore Ovens
Oven does not heat up
That pop could have been the element. Check all around the element for a bubble or a large pit/hole. If you don't find anything then check for a burned wire in the back (please unplug the range). Does your range have fuses? If so then check the 30A fuses, but if one is blown you'll have to find the short that caused it, usually a burned wire fused to the chassis or a burned out element. There are many things that could have caused this but these are the most common. Cheers
Nov 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery Series Electric Oven has stopped working. I was trying to preheat the oven and after a few minutes heard a very loud pop/bang. The oven had the PF (power failure) symbol flashing and my...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Frigidaire 30 in. Electric Gallery Series...
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not heat
Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
Plz let me know how you get on.Thanks.
Jan 03, 2009 | GE JKP15 Electric Single Oven
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
97 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
