Question about Health & Beauty
Recently assembled the Thomas and friends tri scooter for my sons Xmas present lucky i noticed there are 4 washers for the back wheels missing which means we cant put it together as it was from amazon they have advised to send it back for replacement which i grudge as it wont arrive in time for Xmas now is there somewhere i can just but them from and do it myself please like a diy store or shop thanks
  • 1,271 Answers
Hi, i can help you but i will require pictures etc ,,
Regards
gewizrepairs.co.uk
Posted on Dec 22, 2014
Missing rear axle. is there a way to replace? the company won't.
I had the same problem. I bought this scooter for my daughter at a flea market and the rear axle was gone, someone had tried to fix it with a bolt, but it was very unstable. Here is what I did and it has seemed to work well. This will cost you less that 10.00 at your nearest home improvement store.
You will need
1x - 5/16 x 8 hex bolt 1x - 5/16 nut 4x - 5/16 x 1 1/4 flat washers 2x - 1 1/4 hard rubber stoppers 1x - 3/8 drill bit & drill 1x - gorilla glue or lock tight
Ok... before we start let me tell you what all this is for and how it works. The way I assembled this was, hex bolt, 1 washer, wheel for scooter, 1 washer, 1 rubber stopper (Insert this into the metal tube on the back of the scooter, so that on the other side you will just have a bolt sticking thru) now, 1x rubber stopper, 1x washer, other scooter wheel, 1x washer, hex nut.
The rubber stoppers are the hardest part and the reason for them is to keep the bolt going thru the middle of the axle tube. This will help to eliminate the scooter from wobbling.
Now, if you have read this far here is how we did it in order.
1. Take both rubber stoppers and trim them with a kitchen knife so that they will fit into the metal tube on the back of the scooter securely. (do not push them all the way in yet)
2. Drill a hole thru the middle of both trimmed rubber stoppers with the drill and bit
3. Take your hex bolt and slide a washer on
4. Slide your 1st wheel on
5. Slide on a 2nd washer
6. push on the trimmed rubber stopper to where it meets the washer. (The wheel should be able to still spin pretty freely, If you think it is to tight just pull the rubber stopper up a bit)
7. Take this assembly and push it into one side of the metal tube on the back of the scooter (you want the rubber stopper to be and flush with the edge of the metal tube and you can)
8. Your hex bolt will be stick out of the other end of the tube, slide on the last rubber stopper try and work it into the tube as best you can.
9. slide on 3rd washer
10. Slide on last wheel
*At this point I put the scooter on its side and pushed down on the wheel to force the stopper into the tube
11. slide on 4th washer
12. screw on nut
*Now I found that if you put the nut on to tight the wheels would not turn, but if you left it loose it would fall off.
13. To fix the above issue we put some gorilla glue on the bolt threads and screwed the nut on, we would spin the back wheels until we were happy with the amount of tension on the wheel. We then put some more glue on the top of the nut to help hold it in place.
14. Let the glue dry
Thats how I fixed my daughters scooter. I am in NO WAY a professional or expert at this stuff. Just a dad trying to make his baby happy. Hope this works for you!
Jan 26, 2011 | Bravo Dora the Explorer 3 Wheel Scooter
My son has just received a roaring rex from toy story 3 for Christmas and it sounds more like a duck when you squeeze it. According to other reviews, other people have the same complaint, what can be done...
Have you got the reciept? Or have the people who bought it got the reciept?
We bought my son th Toy Story 3 Buzz Lightyear and at xmas, found that the wing was broken. We couldn't do anything about it though because we had bought it a month prior to xmas and was no longer aloud to bring items back.
A friend also bought Toy Story 2 Woody and when you pulled his cord, he was missing 2 phrases. I love toy story, but I think they're toys are not so good.
If you haven't got a recipet, then I doubt you could do much. You could try and go back to the shop and explain to them and they might take it off your hands and replace it without a reciept.
Good luck.
Jan 02, 2011 | Disney Toy Story 3 Rex the Roaring...
I have the Thomas and Friends Trackmaster talking Thomas train. 2 days after I bought it he stopped working. I changed the batteries and now he only talks. He wont move on or off the track at all?
I brought one a few days ago and out of the box it talked but would not move. I returned it to the store for a replacement. I noticed that the back wheels under the on and off switch have weight on them before the train will move. If the train is not sitting on the track, it will not move, That is what makes thomas stop at the station
Nov 11, 2010 | Thomas and Friends Trackmaster Motorized...
Spin and fix thomas instruction manual
not sure if you ever found them but I've recently done some searching and found both the assembly and play instructions at the following links.
http://thomastrackmaster.com/pdf/Spin%20&%20Fix%20Thomas%20Assembly%20Instructions.pdf
http://thomastrackmaster.com/pdf/Spin%20&%20Fix%20Thomas%20Play%20Instructions.pdf
hope they help anyone looking for these hard to find replacement books
Jan 06, 2010 | Hit Thomas and Friends Trackmaster Railway...
Never recieved assembly instructions for millenium MX120 starter drum kit, need urgent help..
look on you-tube - put how to build a drum kit and get some great videos showing you how - had same problem when unpacked my drumkit for my sons Xmas present and no instructions in box
Dec 24, 2009 | Toys
How do you remove the back wheel of a Pride Hurricane scooter
Undo the centre wheel nut and remove along with the washer, jack the rear of the scooter off the ground then slide the wheel off the axle. If it will not remove, it will need knocking off from the inside rim. Be careful not to lose the hub key (a small piece of metal that locates in a slot in the wheel and axle) as the scooter will not drive if this is missing. To remove the trye from the rim, undo the 4 bolts that hold the two wheel halves together. When refitting the wheel, be sure to apply some grease to the axle before sliding on the wheel.
Jul 30, 2009 | Pride Hurricane 4 Wheel Personal Mobility...
Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
May 10, 2009 | Razor MX500 Dirt Rocket
Health & Beauty Logo
41 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
