Question about OneTouch Can Opener by One Touch
Can open opener worked for two years, after changing batteries does not work.
Changing batteries, worked after first change and like it because cannot use manual opener. this is my second one touch can opener
My gardena water timer won't stop bipping. See the picture. Is it the battery ?
for the Gardena-T-1030-1805 model....
Gardena 1030 1805 Operating Instructions Manual Page 7
11. Battery
11.1 Status indicator
If the battery capacity falls below a certain level, a warning signal sounds every 15 seconds. The programs you have set are not run. The water flow cannot be opened manually. If a valve is open, however, it will be closed.
11.2 Changing the battery
If the battery capacity is too low (the warning signal beeps every 15 seconds), you must change the battery.
To do this, the water timer must be removed from the tap.
Important : Changing the battery deletes the data you have set.
To change the battery :
1. Insert the battery in the battery compartment
2. Set the Run Time control knob
3. Reset the watering data as described in "Setting the watering data".
3 If the Run Time knob is not turned to Reset, 5 seconds after the
battery was inserted the current Run Time shall be accepted. This is confirmed by a double beep.
Note : The time the battery was changed is taken to be the starting time.
To ensure that the water timer works properly we recommend that you insert a new battery at the beginning of every gardening season, or at the latest after a year.
Important ! Please dispose of used batteries properly at the appropriate communal waste disposal site. Only dispose of batteries when flat.
May 28, 2016 | GARDENA Hardware & Accessories
Fob not will not open or lock even though its working
How do you know it is working?? if it wont open or close the doors, it might just be a flat battery in the remote. Try changing the battery first.
May 02, 2016 | 2000 Rover 75
Cant i recharge my ups battery,instead of changing it?
No you cant. some times the battery it's self opens up internally. They do go bad after a few years. 3 years is about average
Aug 10, 2011 | Compaq R1500 ( 295459-001 ) UPS...
Doll is new has not worked right since it was boughten. Before changing batteries mouth and eyes worked. and after changing batteries only mouth moves. what could be wrong ?
Amazing allysen takes two sets of batteries. When you open up her back you will see where you replace 4 AA batteries. If you open up the littel doors UNDER the AA's there is a space for 3 AAA's. That might be a solution.
Dec 05, 2010 | NRS Amazing Allysen Doll
Battery changed now watch not working
It sounds as if there is a detector in the watch that registers when the watch has been opened.
Perhaps there is a method of resetting your watch (perhaps known to recognized dealers?).
Read your instructions carefully to see if you can find anything about battery changing. Most makers don't recommend that you change batteries yourself, so I don't hold out much hope on that one.
Otherwise you will have to take it to a recognised dealer in your type of watch.
Feb 02, 2010 | Watches
Keypad and remote will not open door
Did the remote and keypad work before you changed the battery? Changing the battery in the keypad should not affect the remote.
Jun 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote doesn't work, after changing the battery
Reprogram the remote. Press the learn button on the back of the opener and then press the remote button until the light on the opener blinks once.
Feb 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 HP
You may have a model that requires you to reprogramme your PIN after changing batteries...
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
OneTouch Can Opener by One Touch Logo
471 people viewed this question
Top OneTouch Home Experts
Donni Steen
Tom Chichester
Are you an OneTouch Home Expert? Answer questions, earn points and help others
