Question about Briggs & Stratton Briggs Stratton 7 kW Auto Standby Generator
Bought new. No problems until two weeks ago. Now has 252 HRS. Starts all the time, runs 10 seconds then shuts down. I have removed wire an oil pressure switch. no help. Found connector off on switch p
Checked oil pressure switch, oil quality and level, air filter, switch part number 31 had connector off(do not know what switch is called) which was no help. Looked over fuel valve assy which looks OK. Unit has been used for 2 years hooked up to 500 lb propane tank. Never a problem,
    New Friend:
  • 17 Answers
It shuts down because it's not making power. You are probably getting a failure to start error code. If it doesn't make power it doesn
t know its running. Rotor has lost residual magnetism to start the voltage regulator. Replace the voltage regulator. The new one is designed to overcome this.
Posted on Dec 13, 2014
Testimonial: "How do I know if I'm going to get newer regulator. The part number I have is 196070GS. is there any way I can test voltage regulator with a meter?"
  • Bill Palonis
    Bill Palonis Dec 14, 2014
    Where is voltage regulator on model 040301 7K propane model?
4 Suggested Answers
  • 5603 Answers
SOURCE: Briggs and Stratton propane gernerator will not run.
The engine is starved for fuel. Check fuel flow. Possibly a dirty fuel filter someplace in the line or the regulator has low flow.
You can verify this by putting an UNLIGHTED Bernz propane torch into the intake. If that improves it, then low fuel flow is the culprit.
Fuel filters for propane are very fine and can plug up easily. I am not sure where yours are, however I would check at the inout of the regulator for one there for sure.
Posted on Mar 31, 2010
Testimonial: "Problem solved. The engine was starved for fuel. The regulator diaphragm had pulled away allowing air in."
duane_wong
  • 6826 Answers
SOURCE: My neighbor gave me a 10 year old 5000 watt
That's interesting that you bypassed the fuel pump after noticing that the carburetor was below the tank, not needing a fuel pump to start the engine.
Maybe they put a fuel pump in to ensure that the float bowl valve is not the only thing preventing gas from overflowing into the carburetor when stored for a long period of time.
I would put the pump in if that's the way they originally designed the fuel supply for the engine, just to be safe.
Good luck on this repair.
Posted on Dec 31, 2010
ftw1952
  • 10319 Answers
SOURCE: I have a generac 5500XL. Starts and runs fine.
Check the adjustment to the needle and seat. If the gap is too wide it will stall when set to an idle. If the adjustment is on the money clean the jets out since your inti it. There are 4 holes in the brass jet. If anyone gets clogged up it will affect the idle a well
Posted on Aug 28, 2011
My '99 Prowler has been running great for the last 267,000 miles, yes that number is correct, and was until about three weeks ago. I was cruising about 45 mph and it just shut down. I safely got to the...
Start by checking all your fuses. If not, take your time and look for any bad plugs or connections in the wiring harness. Oil or debris might be making a contact you don't need. TAKE YOUR TIME DOING THIS! Also notice Cam and Crank sensor are two different ones.
Mar 10, 2017 | 1999 Plymouth Prowler
I have a 8000 watt honda gen with 13hp motor out of no where It shut down starts right back up.I changed gas filter,air filter, oil,spark plug again only cause Ive bought new plugs before and they were bad...
The low oil level sensor may very will be causing the problem. Make sure it is fully serviced with oil and then see if it still keeps sutting down at random. If this resolves the problem great. If the problem persists try disconnecting ONE wire from the low oil level sensor. If it still keeps shutting down load or no load remove the fuel float bowl from the bottom of the carb and check for debris. Check fuel flow float bowl removed. It should fill a spray paint can lid in 8 to 10 seconds to the point your worried about over-flow. If you can not get this rate of fuel flow... check the fuel filter, sediment bowl under the fuel selector and the fuel tank exit port. Then clean up the float bowl / bowl nut (or solenoid) and reinstall it.
Still have the problem... start looking at the wire to the fuel solenoid on the bottom of the carb (if used) and the ignition wire to the stop run switch for any signs of chaffing all the way from the start runn switch to as far as you can follow it on the engine without disassembly.
I would appreciate any feedback.
Thanks for choosing FixYa,
Kelly
Sep 15, 2011 | Honda Electrical Supplies
I have a 7-41 I.R. compressor. Recently serviced with 1200 hrs done. It now only runs for about 20 mins before shutting down. After 15 mins she starts again. I have tried bypassing water temp sender and...
make sure the cooler(s) are clean. Next check the airend discharge temperature switch commonly called a HAT (High Air Temp) switch. These switches will reset as the compressor cools down. I would be able to access the switch quickly. Run unit until shutdown remove wires and see if switch is open. if open you found your problem
Jun 01, 2011 | Ingersoll Air Tools & Compressors
John Deere LA125 riding mower, three years old, 84 hours, Briggs 21 hp engine. I mowed the lawn. I cleaned the machine with a water hose. Now, IF it starts it will die after about 10 seconds. I took the...
Bought a new John Deere LA125 IN 08 only has 106 hrs on it, maintained it to a tee, changed oil etc, now it smokes, blue smoke, smells like burning oil, it does this when i rev up or down or when theres a load on the engine, but doesnt smoke all the time, i chaanged my plug which was amazing it would start it has the 21 horse briggs and stratten engine. Any help appreciated.
May 09, 2011 | Garden
My tv shuts down after 10-15min being on red light starts blinking about 10 time then shuts off then later it will come back on within few min to hrs sound and picture ok but just keeps shutting down will...
I have the same problem with mine. I can recreate the problem by stopping the small fan on the right side by the inputs. I'm not sure if its a heat problem or not. I already bought a new Sony Bravia but will continue to tinker with this for awhile.
Jul 03, 2010 | LG 52SX4D 52" HDTV
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see www.polar.fi under support in forums) link: http://forum.polar.fi/showthread.php?t=14065 - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
Jun 02, 2010 | Polar RS200sd Running Computer Heart...
Inspiron 6000 starts to boot but then shuts down after only 10 seconds. New Battery, power supply measures ok. Caps lite is on.
Try reseating the RAM memory modules, see if any change.
If no change, remove, battery, Drives, Wireless card and RAM, see if the system will run longer or give an error code. If something changes, add 1 RAM module and try again. If the system runs, then add items back one at a time until you determine the faulty item.
If the system issue doesn't change, odds are a motherboard problem. Motherboard are about $100 on Ebay
Dec 06, 2009 | Dell Inspiron 6000 Notebook
Between 1 to 6 hrs of sittting, 45 sec. crank to start
timing has to be off , this car is nothing but problems get rid of it and get a honda or toyota
Sep 25, 2009 | 1995 Eagle Vision
Monitor turns on for less than a second, then off. I bought a 19" Samsung LCD monitor (953BW) about 10 months ago and the first time I used it, it would only switch on for a split second and shut down. ...
Although the OP was 2009. I had this problem.
I simply replaced the power board. Which I bought from ebay for $20AUD.
It was real easy to remove as well. Just have a look for youtube videos.
Fixed!
Aug 31, 2009 | Samsung 953BW LCD Monitor
92 gmc c2500 turbo diesel. starts then dies after a few seconds.
Sounds like the Pump Mounted Injection Module.. Starts, dies, Starts dies... Not a fun fix.. but atleast it's just under the intake..
Mar 30, 2009 | 1994 GMC Sierra
Briggs & Stratton Briggs  Stratton 7 kW Auto Standby Generator Logo
170 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
