Question about Canon EOS 600D Rebel T3i Digital Camera with 18200mm lens
In the shutter counter of canon t3i,,,how many numbers of shot can I make,,,
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 884 Answers
Hi
There are several points here. The number of shots available at any time is dependant upon :-
1. The state of charge of the battery
2. The use or non-use of the flash
3. The size of the SD card used for recording the pictures.
The number of shots left is given on the bottom right hand corner of the LCD screen and should presumably take these things into account from past history. Otherwise the number may just reflect the space left on the SD card. In terms of continuous shooting, it takes about 3.7 shots per second whilst the shutter button is held down, presumably until the battery runs out, or the SD card is full. All the above details are available in the camera User Guide which can be downloaded and saved from here:-
http://gdlp01.c-wss.com/gds/7/0300008087/03/EOS_600D_Instruction_Manual_EN.pdf
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 10, 2014
How do I deal with an Err. 20 on my Canon T3i?
Err 20 Malfunctions related to the mechanical mechanism have been detected. Warranty repair.
Jan 21, 2015 | Canon EOS Rebel T3i
How many number of shot I can make for canon t3i rebel
Most digital cameras can shoot 150.000 shots before the shutter becomes unreliable. If you take care your camera should do the same. The shutter is supposed the weakest part, because it is the only mechanical part in the camera.
Dec 10, 2014 | Canon EOS Rebel T3i
How to fix err20 for Canon Rebel T3i?
Error code 20 refers to a detected mechanical problem
Error code 30 refers to a detected shutter problem
-Turn the power switch to < ON > to turn on the power.
-Remove and re-install the battery.
-Use a Canon lens.
-If the instructions above do not solve the problem you may need contact your nearest Canon Service Center.
Aug 03, 2014 | Canon Cameras
Why is image not displaying on LCD monitor?
Need more info. Does the menu display? Then LCD probably good. If the menu does not display, then LCD (or its driver circuitry) is probably bad. Not display after taking a photo? Or not display when you push the arrow button to turn on display. Check to make sure card is in camera. Set menu to factory default to make sure some setting in the custom functions isn't turning off the LCD. Also check the brightness level.
Jun 05, 2014 | Canon EOS 600D Rebel T3i Digital Camera
LCD Screen won't turn on. I can take pictures just fine but the screen just won't turn on. Hasn't been dropped or exposed to water at all. Canon EOS Rebel T3i
There are a few thing you may want to look at. In your menu settings (the second little wrench icon) you will find the LCD on/off options: Shutter Btn, Shutter/Disp, and Remain on, select your desired setting (page 179 in the T3i manual) Check to see that the display is activated by the "DISP." button located just in front of the Mode Dial. For the display to remain on during shooting you must me in "live view" which is avctivated by the icon button located to the immediate right of the eye cup. Unless this "live View" option is selected the LCD will remain off to save power. Also, if the menu is not visible try activating the quick menu "Q" button located just below the apature "AV" button. The LCD should work in the play/review mode at all times, if that is not the case then maybe repairs are necessary.
You can view the manual from the link:
http://www.bhphotovideo.com/lit_files/16003.pdf
Mar 19, 2014 | Canon EOS 600D Rebel T3i Digital Camera
I use a canon EOS 600D and been having issues today taking shots when i zoom in. Tried clearing all the settings but still wont take shots when i zoom. Neither does capturing video work. said "video...
Try another lens. It sort of sounds like the flex in the lens is partially cracked - like what happened to the shutter flexes in the old 35mm point and shoot cameras
Aug 30, 2013 | Canon EOS 600D Rebel T3i Digital Camera
My canon eos 600d won't take pics anymore is there a lock or something that could be released
Are you getting an error message or any other indication from the camera? Have you checked the memory card to see whether it's write-protected? What exposure mode(s)? What shutter release mode(s)?
Mar 19, 2013 | Canon EOS 600D Rebel T3i Digital Camera
How to mount q-ray 70-210mm lens on canon t3i body
Quantaray makes lenses with a variety of lens mounts. Assuming the lens has a Canon EF mount, it will fit onto the T3i just like any Canon lens. If it has a different mount, you'll need an appropriate lens mount adapter.
Feb 28, 2013 | Canon EOS 600D Rebel T3i Digital Camera...
I have the Canon Rebel T3i and having troubles with the LCD monitor. When I turn the DSLR camera on, the camera works perfectly fine. I can take pictures and the camera itself works perfectly. The...
Possible dead LCD? try these
1.press the play button to see if you can view photos
2. press the "disp." button near the shutter
if these fail. send it back for warranty
Jul 04, 2011 | Canon EOS 600D Rebel T3i Digital Camera
Canon EOS 600D Rebel T3i Digital Camera with 18200mm lens Logo
67 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
