What is the side slot for
Just looking
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
The only slot I can imagine is the the hdmi cable
Posted on Dec 10, 2014
Plastic cover
How to remove back cover of ViewSonic G71F+. First remove the 3 screws at the bottom , one on each side and one above the VGA cable. Now look for three small slots on the top of the monitor near the screen. From the side opposite the screen insert 2 medium-small flat blade screwdrivers into the center slot and the slot on one side at an angle of about 25 degrees from the top plane of the monitor then gently pry up by pushing the screwdriver handles toward the top plane of the monitor. Once the plastic latch in the center and one side are released move the screwdriver on the side to the opposite side to release that side.
Mar 07, 2014 | ViewSonic Computers & Internet
On the receptacle which side is hot and which side is neutral
The screws are the identifiers. The brass is the ungrounded (hot) conductor and the silver is the the grounded (neutral / common)
conductor.
Another method is to look at the face side of the receptacle, orient
it so that the ground hole is on the bottom. You will notice that the
vertical slots are polarized (one larger than the other). The side
that has the larger slot is the neutral side and the smaller slot is
the hot side.
Jun 16, 2013 | Electrical Supplies
Install audio card for asus essention cg5270bp003 pc desktop
http://www.evertek.com/viewpart.asp?auto=58002&cpc=NEWARR
Three views shown.
http://www.revolutionpc.net/store/Asus-Essentio-Ultimate-Desktop-Computer.html
Scroll down to the photos towards the bottom.
Looking at the Front of the computer, the LEFT Side panel removes.
Remove the Philips head screw located towards the Top, on the Side Panel's edge, and the Bottom screw on the Side Panel's edge.
Pull back on the raised fingergrip, formed out of the back of the Side Panel.
The panel pulls back so far, then is tilted out, and removed.
-> FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
You may also wish to remove all cables from the computer, and lay it on it's side for easier access to the motherboard.
http://www.ebay.com/itm/OEM-ASUS-ESSENTIO-CG5270-P5QL-VM-MOTHERBOARD-61-MIB8Q3-01-US-TESTED-/170893854322?pt=Motherboards&hash=item27ca114672
Look at the right side of the motherboard, and the two long White PCI slots.
Above them is a long Blue PCI-Express x16 slot. This is used for a graphics card.
Above it is a small White slot. This is a PCI-Express x1 slot.
If a PCI slot is open you can use it for a Sound Card.
If not, and the white PCI-Express x1 slot is open, you can use it.
Examples of Sound Cards used in a PCI slot, and a PCI-Express x1 slot;
1) PCI;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4459743&CatId=2771
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2941927&CatId=2771
On the back of the computer case framework is a small 'door', that holds the expansion cards in place.
The Thumbscrew is loosened, and this allows the door to swing open.
Find the appropriate expansion slot cover, that matches up to the slot your wish to use, and remove it.
Note that the expansion slot covers, do Not line up inline with an expansion slot on the motherboard.
(Expansion Slot; i.e., PCI, or PCI-Express x16, or PCI-Express x1 )
The expansion slot on the motherboard, is usually one space over from the expansion slot cover on the back.
[Don't believe that is worded correctly, but you will see what I mean with the Side Panel off, and looking at the motherboard ]
Yes. It's a lot of fun(?) trying to keep the expansion slot covers in place, expansion cards in place, and trying to close that 'door' properly.
[Look close. The bracket for the expansion card, (In this case a Sound Card), fits in little depressions in the metal framework of the computer case; or the brackets half-moon hole, will fit over a small peg, in the computer case framework ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | ASUS Essentio CG5270BP003 PC Desktop
Hi, Is Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card capable for my Compaq HP Presario SR2020NX? -thanks a lot.
You mean will the Asus ATI Radeon HD6450 with 1GB of graphics memory, work in a Compaq Presario SR2020NX Desktop PC?
Yes.
The Compaq Presario SR2020NX Desktop PC has a PCI-Express x16 expansion slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757470&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245048
{Motherboard illustration and photo are towards the bottom of the page}
Look at the specifications.
Scroll down to the heading - Expansion slots.
Three PCI. (PCI expansion slots)
One PCI Express x16 graphics.
NOTE*
Looking at the motherboard illustration, it is Wrong.
Shows - PCIEX1 (PCI E X1)
According to the specifications it is a PCIEX16 expansion slot. (PCI-E x16)
A PCI-Express x1 slot has 36 contact pins. 18 on each side.
In comparison a PCI slot {White} has 124 contact pins. 62 on each side.
Looking at the photo of the supposed PCI-E x1 slot they show, the black PCI-Ex1 slot is longer than the white PCI slots.
It is a PCI-Express x16 slot with 164 pins. 82 on each side.
The Asus ATI Radeon HD6450 uses a PCI-Express x16 expansion slot.
So you know the graphics card will fit. Low-profile to boot.
Power requirement:
The Compaq Presario SR2020NX desktop computer comes with a 300 Watt power supply.
(Although in actuality it's more like 70 percent of the maximum rated wattage. 210 Watts)
Enough power for the computer, and the graphics card.
ATI graphics cards do not use as much power as a comparable Nvidia graphics card.
Concerned that the Asus graphics card uses DDR3 graphics ram memory, and the Presario SR2020NX uses DDR2 Sdram ram memory?
Don't be. The graphics cards graphics memory runs independent of the computer's ram memory.
Information on PCI-Express,
http://en.wikipedia.org/wiki/PCI-Express
(Top right of your page, blue Comment)
Regards,
joecoolvette
Sep 15, 2011 | HP Compaq Presario SR2020NX PC Desktop
My intel mother bord 945 gcpe in one ram slot is not workink but one ram slot is working pls saport me.
first check the capacitor in the side ogf the memory slot for bluge or leakage then look in the slot for any pin contact switch off the computer and look for shorting between the pins inside the slot if still not working the slot has the problem you must contact a chiplevel Tech to change the slot
Dec 15, 2010 | Intel D945GCL Motherboard
Where is the fuse box location
YES YOUR FUSE BOX IS LOCATED WHEN YOU OPEN YOUR DRIVER SIDE DOOR ON THE SIDE DASHBORAD THE IS A SLOT LOOKING THING IF YOU LOOK AT THE SLOT IN SMALL LETTERS IT WILL SAY FUSE BOX STICK HAND IN SLOT AND PULL
Nov 25, 2010 | 1996 Dodge Intrepid
Where is the power window fuse on 1999 Dodge Intrepid ?mmlch@usfamily.net
YOUR FUSE BOX IS LOCATED WHEN YOU OPEN YOUR DRIVER SIDE DOOR ON THE SIDE DASHBORAD THE IS A SLOT LOOKING THING, IF YOU LOOK AT THE SLOT , IN SMALL LETTERS IT WILL SAY FUSE BOX STICK HAND IN SLOT AND PULL
Jul 27, 2009 | Dodge Intrepid Cars & Trucks
Firewire with video camera
You can purchase a firewire card that will fit into a PCI slot on your motherboard. It is really very easy to install, phillips' screwdriver (2PT) is the only tool you'll require. REMOVE POWER CORD, pop open the side, look for two or three white slots about 5" long towards the bottom...that is a PCI slot. Now look at the card you are going to put in, you'll see you need to remove another silver colored rear slot cover that is even with the PCI slot...just take your time and slide it into the PCI slot and the silver slot at the sametime. Put one screw in it close'er up run the software that came with it and bingo your video camera will work with you puter.
Hope you got this...it is really simple (plug it back in after replacing the side panel)
good luck, please leave a rating, thank you kindly
May 01, 2009 | Dell Dimension 4500 PC Desktop
Mother boards
drivers for motherboard utilities sis chipset
tucd ver.2.46
fathy@mail.minia.edu.eg
Feb 09, 2008 | Intel Motherboard
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
