Question about Nokia Cell Phones
Nokia 101 keypad is locked. my IMEI1:358133/05/620452/9 ,IMEI2: 358133/05/620453/7. MODEL : NOKIA 101 , TYPE :RM-769
SOURCE: Restricted code require for Nokia 6300
hi all, I have a nokia 6300 which brought back from indonesia and need the unlock code as well. phone model : nokia 6300, type : RM-217 IMEI #359544018940944. Thanks
Posted on Nov 21, 2008
comms669
  • 34 Answers
SOURCE: nokia 2630 security code unlock
http://www.askstudent.com/hacking/how-to-unlock-any-nokia-based-cell-phone-and-get-its-unlock-codes-absolutely-free/
Posted on Jan 02, 2009
  • 135 Answers
SOURCE: undo restriction code nokia 6500s-1
NOKIA UNLOCK AND OTHER CODES
You will need a nokia phone (only).
IT IS A CRIME TO DELETE/CLONE OR INSERT AN IMEI Number on a PHONE,
However you may if you own the phone you may pick a service provider sim's "free phone".
Any network this is for (NOKIA phones only),
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI number). #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code.
Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
These codes should provide everything you need to mod your phone.
Mike.
Posted on Feb 21, 2009
SOURCE: Nokia 6030 unlock code
Hi i have nokia 6030 mobile and i forget my security no. and i watn my master code pls help me my phone 6030 rm-75 v.4.10.
and my phone give me some problem like all ring tone not work. i want to do restore my phone but without code that is not work pls help me my imei no is 359351004920179 and i calculate my master code that is 5676415661 but this is not work what i do
Posted on Mar 12, 2009
SOURCE: Security code for Nokia Model 1650 RM-305
my mobil model no is 1650 this mobil asking security code so plz solve the solution
Posted on May 13, 2010
Someone please help me I Have Nokia Phone MODEL 101 TYPE RM - 769 CODE 059H0F8 IMEI 1 : 355490/05/680626/2 IMEI 2 : 355490/05/680627/0t
contact your service provider for help for the codes or take it to a shop that handles you service provider requirements.
Apr 08, 2015 | Nokia Cell Phones
My nokia 101 RM 769 asking for security code immediately i turn on.i have tried 1234 but not working
If this is your phone then you will know the code! If it is stolen then the owner it was taken from will know the code!
Nov 07, 2014 | Cell Phones
Model No: Nokia 101 Type RM-769 IMEI NO 1:359071045921986 IMEI NO 2:359071045921994 Please send me the unlock number to alex_zam04@yahoo.com
if you did not change the code when you bought It from the store, try the last 4 digits of your cellphone number.. that is the default setting . on some phones you can reset the phone to the factory default 1234 . by holding a reset button and power , the reset button might be in the battery case..
Aug 08, 2014 | Cell Phones
Forgot Password how can Remove Nokia 101 of Security Code
evng sir mai apnea Nokia 101 mobile ka password bhul gaya hu Jo Maine change Karl diya ab mujhe yaad nahi h aur Mobile password mang raga h kr...
Good evng sir mai apnea Nokia 101 mobile ka password bhul gaya hu Jo Maine change Karl diya ab mujhe yaad nahi h aur Mobile password mang raga h kripya jaldi mera password bataye uska imei number h 356681050781621 Type -769 h model Nokia -101 h please my email I d ye h is par send jar dena vishvendrasinghjat728@gmail.com
Sep 01, 2013 | Nokia 101 Dual Sim Mobile Phone - Unlocked...
Forgot security code on nokia bl5cb
Please I need help to my Nokia bl5cb security level code 355476054578755
Apr 23, 2012 | Nokia 1616 Cell Phone
I forget my security code of nokia ce0434
You may try default phone and security code to remove
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
Sep 07, 2010 | Nokia 1650 Cell Phone
i have nokia nokia 6300 vietnam need the unlock code phone restricted
1.phone model : nokia 6300 , (type ; RM-217)
2.imei # 354189029721746
3.the network where you pjone is locked to : vietnam
Oct 08, 2008 | Computers & Internet
Cell Phones Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
