Question about Behringer Ddm4000 5-channel Digital Midi Dj Mixer New!
How do you use the headphones with cd turn tables?
I'm playing one CD player through speakers and I want to hear what's on the other CD player through the headphones. How do I do that?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
You should have a headphone out on the mixer or you need a mixer
Posted on Dec 21, 2014
Why does my lowrey organ not make a sound after I have switched it on?
This is a generic answer for this kind of question.
When there is no sound
Check the obvious.
Is there a light on the organ indicating it is on?
  • Plug it in to a known working wall socket, switch on at the wall
  • Switch on at the organ, check light
  • Very old keyboards need a voice to be selected!!
  • Turn master volume up
  • Turn any other volumes up
  • i.e. lower manual volume
  • upper manual volume
  • swell pedals down
Sometimes a sustain pedal plugged into a volume pedal socket will mute the output, check this.
Headphones out, most headphones will turn speakers off, sometimes the headphone switch can be dodgy, work the headphone plug in an out a few times
There maybe a switch that turns off the speakers, look near the output sockets
Software volumes up, check display, if any.
MIDI instruments, check local control is ON
Still no sound?
Can you hear anything from the speakers?
Hiss or hum usually means the speaker is ok
Total silence may indicate speaker failure, but only if there is one speaker, as in older home organs, or smaller keyboards
Try headphones next, TURN Down master volume first just in case!
If there is some sound, very quiet and gross distortion then possible power amplifier failure.
If your instrument has any kind of line out as well as a headphone jack, try these.
The line output will likely be a pair of phono sockets,like you have on HiFi equipment, 1/4 inch, 6.35mm jacks, like the bigger headphone connector, a 3.5mm socket like the smaller headphone connector, or even a DIN connector on older equipment.
Connect these to the aux (or Line or CD) input on your HiFi, guitar amp or similar. (some times these outputs will drive headphones, usually you will only hear anything in the left side). If this works then it is very likely the power amplifier.
Further tests on MIDI equipped keyboards would be to see if the MIDI does anything.
If MIDI out works and there is no sound, and MIDI in makes a sound this points to local being off, buried somewhere in the menu will be local on or off, make sure it is on.
If MIDI out doesn't work then the failure is likely to be internal power supply or something else critical (not nnecessarily major).
Power amplifier failures in newer, low power, keyboards are often the power amplifier chips (i.c,s), older amplifiers may have just blown their fuses but one or more output transistors may have failed.
Cost of repair will be down to the time it takes to get to the fault, taking these to bits and putting them back can take a lot longer than the repair.!
Hope this helps, Chris the Fader
Aug 28, 2016 | Music
How do I play a split track cd without the words coming out monitors I want music only
try playing it using a different player, or turning off lyrics in the settings menu of your player :-)
Dec 03, 2014 | Music
I cant hear music from the headphones numark cdj 200
Since there are no headphone outputs on this unit, I'm not sure what the trouble is. Please be more specific. Thanks.
Jan 12, 2013 | Numark Industries Numark NDX200 Tabletop...
Microkorg sounds are off but lights are on and midi works, but i hear no sound it the headphones
Look into all the settings, some of these has a setting to turn internal speaker jacks on and off. I have a casio that can turn them off when playing into the computer.
May 04, 2012 | Korg MicroKorg synth (includes microphone)...
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
I have a Yamaha ypp 100 keyboard that was sitting idle for awhile. When I turned it on and started to play there was no sound/an extremely faint sound from the speakers.
Try headphones... possibly the switch contacts on the headphone jack which disconnect the speaker when headpones are plugged in. If you can hear via the headphones, check the switch contacts. Also look for a loose cable.
Contacts can oxidize when idle for a long time.
Jan 17, 2011 | Yamaha Full-Size Keyboard
I cannot listen to a song through my speakers and a different song with my headphones at the same time.Either I hear one song or the other but never the two at the same time..any ideas why?
I believe that only ONE audio system can be active at once so what you are observing MAY be normal. The pro DJ units have two seperate CD players and are set up to cue with headphones. See if you have a "cue" control on your system... Often the clue to these problems is in the manual which one needs to know the name of the function to search for. Learning the language is the key as indexes are useless without the "word".
Jan 03, 2011 | ION Audio Ion Discover Dj Computer Dj...
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
I have a 20 watt peavey micro bass, and what happened was my brother knocked it over and will not turn on. I checked the fuse and it was ok, any help you would be great.
When it was knocked over it may have cracked the main circuit board, but does the pilot light come on at all? If the pilot light comes on but no sound is output from the speaker try plugging some headphones into the head phone jack and then turn it on and see if you can hear sound in the headphones. I have had a similar problem before and the main speaker had gone bad but it would still play thru the head phone jack.
Apr 22, 2009 | Music
Behringer Ddm4000 5-channel Digital Midi Dj Mixer New! Logo
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
