Question about Sony Audio Players & Recorders
I have SONY TA-V715 amplifier with out transformer, please give me transformer details
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 924 Answers
If the unit is more than a couple of years old, that part is probably no longer available. As to the specs, you have have to obtain a service manual.
Posted on Dec 12, 2014
My speakers is100 watts which stk I'm going to us for the my radio and it's two speakers each one is 100 watts my radio is Sony TA-V715
The watts of the speakers are not too important when connecting to an amp. With large wattage speakers such as yours the amp will drive them. What you only need to worry about is someone turning the volume up to much, but only if the Sony amp can deliver a greater wattage than the speakers. If it can it will destroy the speakers at the highest levels.
However when connecting speakers to any amp, you must look at the Ohms of the two items. You must NEVER connect a speaker of lower Ohms to an amp of higher Ohms than it. Must amps and speakers will fall between 4 to 16 Ohms. If your amp says 4 ohms you can connect just about speaker to it. But if says 8 Ohms, you must not connect any speaker rated lower than 8 Ohms. Connecting a 4 Ohm speaker to an 8 Ohm amp will destroy the output transistors of the amp.
Nov 05, 2016 | Sony Audio Players & Recorders
I have sony TA-V715 amplifier, one set of (cd, phono, tape)input-red colour cable input is not working. Please give me a solution.
The possibility is that one of your premap input is not working and the fault could be in the preamp input section. Possible that the input IC, the selector digital IC or the tone amp could be faulty. It will be easier to find as one section is working and you can cross check with voltage readings from teh working side. Also apply the audio test from the output to confirmt he section, replace from the working side to confirm the fault. I hope you have checked on the speakers/ ouputs by crossing.Also check for fuse or failure of the output section. Hope you try and confirm.Good day .
Aug 09, 2010 | Sony Audio Players & Recorders
I accidentally plugged my 110V amplifier to 220V outlet.It has no power anymore.what possible solution for this. Thank you very much. Do I need to replace the rectifier in it's circuit?
Hi and welcome to the site,
Initially, on a completely dead Sony TA-N9000ES, primary suspects to be checked would be:
  • 8A F1 fuse;
  • primary winding of T1 transformer;.
  • fusible resistors R816, R817 and R818.
Good luck and thank you for asking.
Jul 13, 2010 | Sony TA-N9000ES 5-Channel Amplifier
I have 2 questions will my SONY TA-E9000ES preamp work with my SONY STR-DG720 7.1 RECIVER and what SONY ES Amplifer was spefically made to work with the TA-E9000ES WHEN IT WAS ORIGANLY PRODUCED
Here's a page for the 1st one
http://home.online.no/~espen-b/ta-e9000es/
It will work with your 7.1 receiver. Just use one of the inputs on the 7.1 to connect to the Pre-amp
PLease rate my help if this helps
Thanks
Nov 04, 2009 | Sony TA-E9000ES Amplifier
Audio Receiver Input Selector
i , too, i working with Amplier sony TA-V715
Apr 03, 2009 | Sony Audio Players & Recorders
Sony TA-AV421 Amp
im needing help connecting my audissey aps 5+2 energy floor speakers . im confused on the 2 channels
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Wire for st-jx285 tuner and a integrated amp. ta ax285
Need MORE details possibly in english and better typing
BIGRED
Apr 09, 2008 | Sony TA-FE370 2-Channel Amplifier
115 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
