Question about Refrigerators
The inside lights come on but nothing else comes on?
Replaced the microcomputor board part # 2214765
  • Refrigerators Master
  • 744 Answers
Hello Roy;
My name is Peter. I am a retired field service refrigeration technician.
Your refrigeration will go into a defrost mode every 8-10 hours for about 20-30 minutes. At this time your defrost heater will turn on. Everything will shut down except for the lights.
So, you are locked in a defrost mode.
The part number you gave for the board is your LED board. Your defrost model is generally in your main board. I am not sure what you have because you gave no model number. Is this what you have?
the inside lights come on but nothing else comes o - 25315900-jb2mhvjlpg0eez4hxwqwnjeu-2-0.gif 25315900-jb2mhvjlpg0eez4hxwqwnjeu-2-3.jpg
Your LED Board $267.00 Seathe inside lights come on but nothing else comes o - 25315900-jb2mhvjlpg0eez4hxwqwnjeu-2-8.jpgt/uploads/images/25315900-jb2mhvjlpg0eez4hxwqwnjeu-2-8.jpg" alt="25315900-jb2mhvjlpg0eez4hxwqwnjeu-2-8.jpg" class="h_mi" />
Main Control Board
Posted on Dec 10, 2014
Replaced control board have 115 to board can't get 12v nothing lights on frig or in side where does 12v come from voltage is good in camper Couchman with Dometic md RM2652
The 12V comes from 2 wires that come from RV and affixed to a terminal block on fridge. Insure you have 12V at those wires. Also check the fuses located inside the main electronic board. ArctiCold Refrigeration We keep it cold 28659511-ac6f-4f0b-b8c3-c7ac7cf165ac.jpg 8e5a2b6c-5f1f-429e-8512-595071232c90.jpg
Aug 29, 2013 | Dometic Refrigerators
Won't power on
You still have power supply trouble, even after replacement of the board. Recheck the replacement work; could be something wrong there
Jul 19, 2013 | Philips 47PFL7422D/37 Television
Tail lights and dash lights are out
Hi Jeffrey,
Most likely to be the lighting control logic board, inside the pod on the left of the steering wheel.
The board lives in that black housing through which the headlight switch is also mounted and has the fog light switches on the board also so that they poke out of the top when the board it in place.
To access the board take out the one Phillips screw directly underneath that left side pod and the bottom panel comes off, the board then un-clips (2 spring plastic clips at the far end near the dash clocks, one near to you, ease them back and you will feel the board come loose ) , and drops out, pull off the light switch knob and undo the nut around the switch to allow you to gently ease the switch shaft back through it's hole and remove it with the board, unplug and replace the complete board unit and the main light switch which is attached to this board by its wires, put the switch back in and nut back on that first, then ease the board back into its housing until the clips click, replace the bottom pod cover with the screw and you are done, takes about 15 minutes tops.
Hope this helps
any further questions post them here and I will see them
regards
Tim.
Source, 20 years in business repairing nothing but Jaguars.
Dec 07, 2011 | 1995 Jaguar XJ6
Screen is black even though the green light is lit
Tv has power supply board inside defective. This board needs replaced.
Aug 18, 2009 | LG 32LB9D TV
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
RCA Microwave and grilling oven Problem
If nothing works but light comes on, it is often because of a bad control board. The board must be tested before replacement.
Apr 27, 2009 | Microwave Ovens
AIR or Heat wont come on/ goodman GMP075-3
If there is no blinking light, then the unit is not seeing a call for heat or cool. My guess is a lose or broken wire in the thermostat circuit. Try and putting a jumper across the red and white heat terminals inside the furnace and manually closing the door switch. If you get heat, it's telling you there is a wiring issue. If you get nothing, it's a bad circuit board.
Jun 08, 2008 | Goodman GMS90703BXA Heater
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
