My Sony projection tv had all the channels programmed in the other night. Then I hit a button on my universal remote and made favorites screen come up. After I did this I can't get any channels to come up. I have tried auto programming the channels again, I have tried unplugging the tv, I even have checked the cable wire. Nothing is working. I don't have the original remote. My husband and me truly love this tv someone please help what else can I try?
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
It sounds that the main system control memory IC to your TV is damaged. Contact any service technician to replace it. Electro help
Posted on Dec 10, 2014
SOURCE: tv is locked
I had the exact problem...tried a number of things that did not work. My dog "ate" my original remote. After reading your solution I took the universal remote that was programmed to work with the tv and tried holding down each button for a few seconds hoping that one would work like the display button on the original remote. It worked. I have a GE universal remote and the menu/info button worked for me. Again, you need to hold it in for a couple of seconds. Thanks for the help and I hope my added solution helps other people. Claudia in Minnesota
Posted on Oct 04, 2007
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
  • 52 Answers
SOURCE: won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Posted on Mar 07, 2008
SOURCE: no signal
Hopefully, anyway.
I had a similar problem, and my solution was this: I pressed menu on my TV and using my universal remote, went into setup, and then channel search (or near to that), at which point it began searching for analog and digital channels. This can take up to approx. 30 minutes. I suggest you occupy yourself while waiting; it is a sluggish process.
If you want assurance, your TV will have the majority of analog channels (basic cable), and a couple digital. I am basing this wholly on my experience, however. Once finished, it should switch immediately so a channel. Mine was a weather station.
I hope this is successful in helping you and those in the future.
Posted on Jul 15, 2009
SOURCE: zenith wont tune channels
How do I reset and get my channel without the box.
Posted on Oct 29, 2009
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
How to enter to service menu?
you have to program a universal remote to the tv....when it turns on/off and you can adjust the channels then the universal is programmed.......then you have to find the magic button on the universal remote which will open up a little box on the screen with a 4 digit code....I have seen some use 0000. yet for the remote I used (Magnavox MG500S the code was 0413) then you will enter the Service Menu! To access My magic button I had to hit the TV button then the input button on the universal remote.......took me a few times to play with it, yet I finally got it.......hope this helps!!
Nov 10, 2010 | LG 42LD450 42 in TV
How to set color, verticl and horizontal lines
Not all universal remote control's operate MENU button on TV!!!
If you have >>COLOR separation ( red blue green) and CAN NOT adjust via MENU button then you must replace conversion IC's>>
part number: STK 392-xxx.....easy repair!!
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Programming channels
universal remote will work,
sony does sell a replacement remot or get a logitech harmony one
it replaces all your remotes
Apr 02, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
PROGRAMING A LOGITECH HARMONY ONE?
It looks like you are speaking about the soft keys when you are in the "watch TV" activity and you have a cable box. These buttons exactly match your original remote. In other words the "A" button on the screen of the Harmony will do the same thing as the "A" button on your original cable remote. If these buttons are not functional on your original remote or if your original remote does not have them I would get rid of them. This is done by logging into your software. Go to the activities page and you will see a link to "customize buttons" under the watch TV activity, click on that. You will then see a page with two tabs that will say "standard buttons" and "additional buttons". Click on "additional buttons" and you will see the "A" "B" "C" and so on. Click on the trash can icon and you will have reomoved that button.
As for programing favorites go back to the Activities page and click settings below the watch TV activity. Select "setup favorite channels and add icons" and click next. Now you are on the page where you can add your favorite channels. Have fun with this and pay attention to the hints on the right hand side.
Feb 06, 2009 | Logitech Harmony One Advanced Universal...
Cann t program my remote control
hold down setup button until tv light comes on then hit channel up button over and over untill tv channel changes then hit enter
Jan 10, 2009 | RCA Universal Remote Control
SANYO MODEL DS27510, CHANNEL DISPLAY IN CORNER WON'T GO AWAY.
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
http://www.askdavetaylor.com/how_to_program_comcast_cable_remote_control.html
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
Dec 05, 2008 | Sanyo DS27510 27" TV
Code for Sony tv
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 10, 2008 | Philips Universal PH301S Remote Control
REMOTE CONTROL MINTEK TV
1-800-Remotes. Guy at VideoOnly told me they specialize in replacement remotes, manuals etc for all types of units.
Dec 06, 2007 | Televison & Video
Can't clear channel off screen of Sony Trinitron with remote
Press (on your regular remote for your satellite) the t.v. button, then press info, this worked for me and I tried everything. another viewer posted this solution and it worked great! this is not the original remote, it is the satellite remote.
Nov 22, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
