Question about Refrigerators
Maytag refrigerator door panel lights are blinking nonstop
Door display panel lights are blinking nonstop
    New Friend:
  • 35 Answers
You might need to vacum underneath so the coils don't get hot. Or change out the water filter.
Posted on Dec 11, 2014
Door Panel not working along with inside lights
check your owners manual to ensure it is not in the sabbath mode. if this is ok their could be a low voltage board problem behind the display or high voltage board in the rear of the refrigerator. unplugged the refrigerator before proceeding to repair it.
Nov 10, 2013 | Maytag MFI2269VEM 22.0 Cu. Ft. French-Door...
Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Sep 19, 2007 | Maytag MFI2568AE Side by Side French Door...
All display lights blink
You will need to replace the main board on the back of the unit. Here is the board to order. Be sure to program the board when you install it. There will be instructions that come with the board.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I don't know how to turn on the door panel
I had same issue. The control panel had been set to Sabbath mode. Hold down the "DOOR ALARM" button for 3 seconds. Then lights will turn on on both display windows. Scroll using the + and/or - sign on the left side display until "SAB" is shown. Then scroll using the + or - sign on the right side display until OFF is shown. Finally, hold the "DOOR ALARM" button down again for 3 seconds. All should be good to go!
Aug 29, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Control panel not working and no lights
Hi. you will need to replace this non functioning Control Panel asap and, test the light pressure switch for it's operational value. If the switch is OK, simply replace the bulbs.
May 24, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Panel flashing, ice door opening and closing constantly
I had the same problem, with this model and it was the high voltage control board located in the rear. Replaced the board and it is working OK. Maytag Part # 12920710 will work on this model and it is 40.00 cheaper than the one it shows when you do a parts search. It will come up 12920709. I checked with Maytag and they said 710 will work..
Sep 23, 2007 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
