Question about Ingersoll Rand Air Tools & Compressors
Does the ssr ml 18.5 have its own air tank ? - Ingersoll Rand Air Tools & Compressors
    Problem Solver:
  • 13 Answers
No it does not but it has a oil receiver tank to hold the oil
Posted on Dec 11, 2014
How many ml is equal to 18mg
Depends what you are measuring. You need to repost with the material that you are measuring.
For example, 1 litre of water weighs 1 kilogram.
So, 1 litre of water weighs 1,000 grams.
Thus, 1,000 millilitres weighs 1,000 grams
So, 1 millilitre weighs 1 gram.
Thus, 18/1000 millilitres weighs 18/1000 grams.
I get 0.018 ml = 18 mg.
Good luck,
Paul
Feb 07, 2017 | Office Equipment & Supplies
Ssr up series 30e-40 Ssr 50 - pe low sump
compressor idling to long or inlet valve not opening
Oct 07, 2014 | Air Tools & Compressors
Pump not holding presure
If you have a bladder - type water pressure tank, it probably needs to be purged of air and then pre-charged to 18 psi. There may be directions on the side of the tank. Turn the water Pump off. Drain the tank of water. Check the pressure of the tank at the air valve on top of the tank. The pre-charged pressure of the bladder is set to 2 psi below the lower pressure set by the pressure switch, so in your case, the low end pressure is 20 psi. Therefore, the pre-charge pressure of the tank is 18 psi. If you set the pressure switch to operate at 30 -50 psi, then the pre-charge pressure would be 28psi., etc. Once the pre-charge pressure is set, turn the pump back on. ( don't forget to close the drain valve). The system should cycle normally. A tire gauge works to check the tank pressure. An air compressor may be used to charge the tank, but be careful not to over- inflate the bladder. A tire air pump may also be used. Hope this helps....
Apr 06, 2014 | Utilitech Plumbing
Ingersoll rand SSR ML 75
Hi, Yes there is a key combination on these, but it depends on the controller that i fitted onto it, is it an Intelisis with the 3 Oval buttons with the up and down arrows in the middle of them? If so, as you look at the left hand Oval button, just to the left of that is an invisible button. you need to press/swipe your thumb from the far left of the controller, going over the invisible button, to the left hand oval button. pressing both buttons in the process. Hope that helps
Aug 30, 2012 | Ingersoll Rand Air Tools & Compressors
Compressor will not auto start and when manually started it will not load it just keeps cycling the solinoid. its a ssr up6 30 60hz
First of I really need some more info. Model and serial # on tag on compressor.Does this up6 have a controller on it. First of all the unit will not load unless it has enough air pressure to open the inlet valve. Is the unit in modulation. If so you need to switch it to on/off line then start. if in modulation and the system/tank is empty there is no air pressure to operate the modulation feature. I would start by switching it to on/ off line first. After started and air in system you can switch to modulation and the unit will operate fine as long as there is air in the tank/ system.
Jun 22, 2011 | Ingersoll Rand Air Tools & Compressors
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
57 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
