Question about Saws
How to replace brushes on draper bts 250a table saw
  • 62 Answers
SOURCE: Motor not working on Delta table saw: I just got a
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
Posted on Apr 18, 2009
  • 58 Answers
SOURCE: MY 10
call 1-800-525-2579 Ryobi technical service line:
Posted on Jun 20, 2009
venexcsd
  • 1185 Answers
SOURCE: what would cause the brushes to go so fast?
Are you using original parts or pattern
All brushes are made from carbon but they vary in their hardness and motor makers match the materials for the different applications
Soft brushes wear away quite quickly and hard brushes wear out the commutator of the armature
As stated by the other helper the segments of the armature can lift or go dead which makes the brushes arc when they stop conducting as they hit the dead segment and then spark when they pick up the next conductive one
Look at the commutator with a strong light if there are segments that are more of a blue colour that the rest they are the damaged ones.
You will see scorching on the leading edge of the next good segment.
If that is the case then new armature & carbons is the way to go
Posted on Jul 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: Bosch 4000 table saw. The saw stopped while
If you are mechanically inclined and it sounds that way do you have a volt ohms meter?? If so start at the cord and check the continuity to the brush holders. Why did you replace the field? You might have had a stuck brush or some other problem. Make sure the brushes move freely in the tubes and also look for discoloration on the commutator of the armature. Let me know what you find and I will try and help you thru the rest of it.
Posted on Aug 25, 2009
  • 332 Answers
SOURCE: I have a delta 36-600 table saw and i keep burning
What is your voltage going to the saw
You may have a high voltage issue
Posted on Mar 14, 2010
Replacing the brushes in the RTS10 10 inch Ryobi table saw
Take right side panel off (right as looking at front of table saw). Side panel will be held in place with 8 small Phillips screws. Take flat screwdriver and unscrew round brush holder on either side of
motor. Brushes are held in place with springs and fastener. Flick small fastener with fingernail and fastener and spring should pop out. Pull out fastener/spring/brushes(all one piece). Replace with new brushes (about $8/piece on ebay).
Mar 18, 2014 | Ryobi 10 in. 15 Amp Table Saw RTS10
Manual wanted for draper bench saw model bts 250a
I have a copy of this manual which you can have.
Feb 12, 2014 | GE 24993 Remote Control
Table saw keeps tripping breaker
May have a brush in the motor that's hanging up or worn may try
replacing the brushes
Feb 07, 2014 | Saws
How to replace brush holders on dewalt table saw dw745
There is a small allen screw in the field housing holding the brush holders in.
Most often I have found, if the brush holders are needing replacement the motor housing also needs replacement - they heat up and the plastic cracks.
Dec 26, 2012 | Dewalt DW745 10" Compact Job Site Table...
How do i replace brushes on dewalt table saw
unscrew brush cap on each side of motor and pull brush out
do it reverse with new one
Sep 07, 2012 | Dewalt Saws
How do i fit reducing ring 16mm bore onto a30mm bore table saw blade, to use on a draper table saw
the reducer should fit right onto the shaft, if its the right size. Mic it to ensure. Then the blade should fit on no prob. I use a 30mm to 5/8" adapter on my own General 50-185 saw. Quality(sizing) of adapter is an issue.
Aug 02, 2012 | Saws
My Bosch table saw motor runs but sparks are coming out the back of the motor. I replaced the bushings and that didn't help. Please advise.
The sparks are most likely coming from the brushes and the commutator. This is an indication of either worn brushes or an armature that is failing and if used further, will burn out. First check the brushes and look at the condition of the commutator. These motors are known to be problematic.
Mar 23, 2011 | Bosch 4000 - 07 Electric Table Saws
Require a manual for a DRAPER 10inch bench saw model no BTS 250 thank you
Try going to manualsonline.com they may have it.You can download it free.
Mar 15, 2011 | Garden
Saws Logo
201 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
