Question about Citizen Watches Citizen CMP-10BT-U5MSC B/W Direct Thermal Printer, Up to 118.1 inch/min - max speed Print Speed, Magnetic stripe reader Built-in Devices, Wireless Connectivity Technology, Serial, Infrared, Bluetooth Interface, 203 dpi B&W Max Resolution, 64 KB Max R
How cam i get windows 8 and android driver for cmp-10BT
Where can i download android drivers for my dell pc?
Since Windows 7 all drivers can be downloaded from Microsoft. You only can install Microsoft certified drivers on a windows 7 or 8 machine.
When connecting an Android system to your computer it should see the computer needs a driver and a program and should hint you it want to download something.
When you have an older operating system, I think you need to contact the maker of the Android device and ask them not only for a driver, but also for software that will work on that version of Windows.
Mar 10, 2015 | Dell OptiPlex Computers & Internet
I have Medion akoya e7214 laptop and i just installed windows 8 on it,now the cam isn't working,I rang up the Medion support,and they told me that they don't support windows and that i need to buy a new...
Try and find out what the manufacturer and model of the camera is and search the manufacturer's site or the internet for Windows 8 drivers. There is not much else you can do. The notebook was designed for Windows 7 and there are not very many Windows 8 hardware device drivers available.
Nov 22, 2014 | Medion Computers & Internet
I need tutorial for configuration router 3 com model 3c16794 zorroazulado
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Jan 19, 2011 | 3Com 3C16794-US 10BT/100BTX 8-Port...
Location of cam sensor 2003 jeep grand cherokee v8
Answer
pic
REMOVAL - 4.7L
The Camshaft Position Sensor (CMP) on the 4.7L V–8 engine is bolted to the front/top of the right cylinder head (CMP Location—4.7L Engine).
It is easier to remove/install sensor from under vehicle.
Raise and support vehicle.
Disconnect electrical connector at CMP sensor (CMP Location—4.7L Engine).
Remove sensor mounting bolt (CMP Location—4.7L Engine).
Carefully twist sensor from cylinder head.
Check condition of sensor o-ring.
See picture for sensor location.
Jul 21, 2010 | 2003 Jeep Grand Cherokee
How do i replace cam positioning sensor in 2003 4.7 dodge durago
Answer
pic
REMOVAL - 4.7L
Apr 07, 2010 | 2003 Dodge Durango
Web cam dosen't work on msn
reinstall the drivers that came with the cam, if the problem still exists check your msn and windows live settings, this should fix the problem
please rate my solution
May 31, 2009 | Acer Aspire One PC Notebook
Passkey for printer
If you do a self test, you will find the passkey on the bottom listed at the "address"...it's the last 4 digits. But good luck! I have been trying for a week to get mine to connect and STAY connected AND to print! I contacted www.citizen-systems.com and they told me that I have to download drivers..but those haven't worked either. The tech did tell me however that the model phone I have hasn't been tested on this printer!
Nov 15, 2007 | Orange SPV M2000 Pocket PC
Citizen Watches Citizen CMP-10BT-U5MSC B/W Direct Thermal Printer, Up to 118.1 inch/min - max speed Print Speed, Magnetic stripe reader Built-in Devices, Wireless Connectivity Technology, Serial, Infrared, Bluetooth Interface, 203 dpi B&W Max Resolution, 64 KB Max R Logo
43 people viewed this question
Top Citizen Watches Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Citizen Watches Office Equipment and Supply Expert? Answer questions, earn points and help others
