SpeedqueenWater doesn't drain awm270-3062 cuts out resets cutsout
The pump isnt running some wires or coins ....
and you need to check it moves
something is stuck in the drain system
and also check its connections are good
Posted on Dec 10, 2014
Husqvarna 65 cutsout cuts two blocks
check tank vent and the coil,to see if vent is plugged,and the coil gets hot
Mar 12, 2015 | Husqvarna Fuel Gas Line Hose 501462501 65...
Kenmore washer not draining
see the causes and remedies:
t spins, but doesn't pump
drain line is clogged+some sock inside remove+pump defective, if lines is not clogged.
It doesn't spin or pump
frozen pulley pump, replace,try to rotate manually, if donot replace
It pumps, but the water returns
improve the drain line, if exceed 4 inches cut off the excess
if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
I can hear the hot watre dripping into the washing machine when it is turned off
see this cause:
It spins, but doesn't pump
drain line clogged, +remove some sock with pliers maybe you can remove the agitator+pumps propeller defective.
frozen pulley pump, replace the pump
improve the drain line+if the drain line reach more 4 inches, cut of the excess. if is lower,install air/gap siphon break assembly.
God bless you
Jul 03, 2012 | Fisher and Paykel GWL11 Top Load Washer
Will not drain and spin
see this causes:
the drain line is clogged+ some sock remain, remove with pliers,+pump defective.
frozen pulley pump defective, replace
improve the drain line. If drain hose reach more 4 inche cut of of excess. If lower add air/gap siphon break assembly.
see diagram
God bless you
Jul 03, 2012 | Kenmore Elite 45986 Front Load Washer
Water does not drain
see this causes:
drain line clogged, ome sock in the outer tub, use pliers for large hose and pull out,test the pump can be faulty.
frozen pulley pump, replace, move manually see the diagram, if not replace
improve the drain line, if the drain hose reach the 4 inch cut of the excess, if is lower, install air/gap siphon break assembly.
God bless you
Jun 19, 2012 | Kenmore Elite 45986 Front Load Washer
Miele honeycomb care w 1712 drain fault comes on every wash
see this possibles causes:
God bless you
attached diagrams
see line clogged and fix it.
frozen pulley
improve the drain laundry, if drain hose reaches more 4 inch cut off the excess
May 16, 2012 | Miele Washing Machines
Car cutsout when i use electrics car sounds rough lock steering wheel and car stops
can you start the car back up after it cuts out ? sounds like altenator problem or belt, check battery output and charge, should charge at 13.7 ish, also check altenator cabling for damage and bad connections.good look I hope this helps (Rate me answer please)
Aug 18, 2010 | 2000 Volkswagen Golf
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
