Question about Yamaha Music
I just got a used Yamaha Electone FE-30, and not all of the keys are working and some of the buttons are not responding, how can i make it work, should i clean it from the inside (Key Contacts?) becau
Haven't done anything yet, i don't want to mess it up!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
The contacts can be dirty but most likely they are broken. Contact switches and key contacts are cheap but the labor to replace them is extensive. I would suggest bringing it to a service center if you have not taken apart a keyboard before.
Posted on Dec 21, 2014
pianokey54
SOURCE: I have a yamaha electone hs4, The foot pedals do not work.
JM: Your problem is this: There are rubber washerson the bolt that holds the pedal on. They are shot. Most likely Yamaha doesnot have the parts.Go to the plumbing dept of a hardware store and get some faucet washers and replace them. YYou can tell if the washers are shot by tiping over the organ and looking at the pivot bolt. Most likely that is yoiur problem. I am an organ tech. and have replaced many of these. DM
Posted on Mar 16, 2009
  • 1138 Answers
SOURCE: need an operator's manual for Yamaha Elecone organ model MFX-7420
Have you tried joining at the Electone Zone at www.electone.com? It looks like a fun site and its free to join. Maybe one of the members there can kindly help you.
Posted on May 26, 2009
  • 5603 Answers
SOURCE: MY Yamaha psr 550 stopped giving sound after
When cleaning buttons HOPEFULLY you did NOT use DeOxit or other contact cleaners like Blue Shower as these can damage the buttons that are conductive rubber.
The conductive rubber buttons should ONLY be cleaned with 99% isoprophyl alcohol and Q Tips. Both the conductive "pill" and the traces they contact on the circuit board should be gently cleaned with the Q Tip wetted with the alcohol.
If you used anything but the 99% isoprophyl alcohol, you can TRY cleaning properly and hopefully they will not have permanent damage.
Posted on Jul 17, 2010
  • 137 Answers
SOURCE: I try to fix my Yamaha Electone Model DK-400.the
You can get the schematic model from your vendor. The model is not available on the internet. See if the electone si still in warranty. If it is call the service centre and get it repaired. I would suggest contacting your country's Yamaha subsidiary or wholesale distributor who may have one in their spare parts department
Regards,
polysandy
Posted on Jan 05, 2011
  • 5603 Answers
SOURCE: I have a Yamaha PSR-S700.
You MAY be confusing touch sensitivity with VELOCITY sensing. Touch sensitivity is PRESSURE put on AFTER the note sounds that causes modulation. VELOCITY is what is used for example to control the loudness of pianoo notes depending how fast they are struck. VELOCITY sensing is done by using TWO contacts at every key... one closes first. IF one of these gets dirty, FULL velocity will be sensed and it will be LOUD. The contacts can be cleaned using ONLY 99% isoprophyl alcohol and Qtips after MUCH disassembly of the keyboard. The contacts are conductive rubber pills in silicone rubber domes. Clean boththe contacts and the circuit traces they pres down onto.
Posted on Apr 02, 2011
Need a Repair manual for Yamaha Electone HC-4 home organ or source to purchase Motherboard for same
Request the repair manual directly from Yamaha. Fixya is unable to identify a source for the motherboard other than Yamaha.
Mar 19, 2018 | Yamaha Music
Need a Yamaha E-30 Electone Organ Owners Manual
can be bought online ..go to yamaha website for more info
Sep 27, 2016 | Yamaha Music
Need an operator's manual for yamaha electone el-15
You can find it here
http://www2.yamaha.co.jp/manual/pdf/emi/english/ele/EL15E.PDF
Mar 12, 2013 | Yamaha Music
HOW TO GATE WIRING DIAGRAM YAMAHA ELECTONE HS-4
Looking for a Service Manual....any suggestions?
Sep 15, 2012 | Yamaha Music
I have a electone FC 20 all indicator lights are working and the ensemble section is working drum beat is ok its just the piano keys are not working could it be a fuse blown
Not likely iit is a fuse. The keys are likely scanned as a matrix with two contacts per key. You need to get a maintenance manual for thee organ. Contact Yamaha America parts for music products. They may have the service manual on CD... they used to get $15 for the CD of the manual. Unless you can find something simple like a cable knocked off this could be hard to troubleshoot.
Feb 24, 2011 | Yamaha Music
I try to fix my Yamaha Electone Model DK-400.the key #Fa din't works. also change to the Piano .No Work at all., Would you kindly tell me how to get repair, I don't get the schematic.Where can order one ?...
Regards,
polysandy
Jan 05, 2011 | Yamaha Full-Size Keyboard
I need the service manual or schematic for a Yamaha D-60 Electone Organ. Any help?
Go to the electone forum at electone.com and ask there.
Also the organ forum
http://organforum.com/forums/forumdisplay.php
When there, go into the home organ section.
Sep 19, 2010 | Yamaha Music
I Have Yamaha Electone HS-4. I already changer a fuse but i have no sound. Someone said, for change a fuse, i must change also a transistor or condensator? Help please. Thanks. andriaharifara@yahoo.fr
the problem is the main output amp. It is an IC so it is better left to a tech to put it in. Just had the same problem with mine. Seems to happen when unit is left on overnight.
Oct 19, 2009 | Yamaha Full-Size Keyboard
Hi, Yamaha Electone HS-4 NO SOUND
j have had the some problem on hs 7 . The relè not work probably you have a cold o breaked joint on power amplify integrate or it is broken.
Jul 18, 2009 | Yamaha Full-Size Keyboard
Need an operator's manual for Yamaha Elecone organ model MFX-7420
May 24, 2009 | Music
Music Logo
83 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
