Where is located sensor of. Fuzzy logic t7517tepto
I have error de on it how I solve that equotion
DE
Washing machine door detected as being open Door open error code can also be displayed as "dOE"
Very simple error, the fault code indicates that either the door is indeed open or that the door lock or door interlock mechanism cannot inform the electronics that the door is properly closed. LG door locks are known to and do commonly fail, the common one used in most LG washing machines and washer dryers can be found here with a link to a lower cost alternative part. However the door handle (can be found here) is also a common source of trouble and, if the catch doesn't engage into the lock properly you will get this fault code being displayed.
On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Posted on Dec 10, 2014
Lg turbodrum fuzzy logic 7.0 wf t700 showing error code "de" what that is mean? And how to fix it?
Try unplugging power, push and hold power button for 5 seconds, then plug back in. See if error code is gone.
Nov 05, 2017 | LG Washing Machines
DE error massage on lg fuzzy logic 8.2 kg 8071TTP
The dE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Jun 22, 2015 | LG Washing Machines
How do i fix an LG 5.0 fuzzy logic washer that keepscoming up with a DE error?
The DE error indicates a Door Error condition....check out the door for any distortion or misalignment with the door latch.
Check the door latch assembly for continuity and if faulty replace the switch.
Mar 24, 2015 | LG Washing Machines
Have a 7.5 Kg Fuzzy Logic top Loader that does not spin
Hello.. DE Error means door error but if wash cycle is working properly means you need to change your drain motor.
Feb 13, 2018 | LG Washing Machines
I have a fuzzy logic 8.2kg top loader WF-8071TTP. We had a power failure while the machine was in a washing cycle. Now I start the machine fills with water and when the wash cycle must start it give a DE...
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 13, 2011 | LG Washing Machines
Error code dE on LG fuzzy logic 6.5
'dE' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
John C
May 15, 2011 | Washing Machines
User manual for LG fuzzy logic 7.5Kg
Buenos dias mi lavaora es una fuzzy logic 7.5 lg cuando lavo me sale DE y la e palpita varias veces la lavadora prende normal llena agua pero cuando comeinza a lavar sale las letras a ver si me puedes apoya por favor
Sep 27, 2010 | Washing Machines
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
