Question about Watches
How do I fix the date on a benus watch - Watches
The date in my ice watch doesn't change after 12:00 AM but instead....it is changed at 09:00 AM ???!!!!
the hands of your watch had to be aligned. it is the only way to fixed your watch.
Aug 07, 2011 | Ice Watches
Date will not foward but time on watch is running fine i can adjust the date but it doesnt move even though the time has advanced
the date wheel of your watch has a problem, it has to be fix by timex watch technician. or someone that is good in handling a timex module.
Jul 11, 2011 | Timex 27191 Wristwatch
Hi, I was playing with Chronometer and now ended up with date messing. whenever i set a date it changes at around 12 in the morning. so how can i fix it?
The watch has a mechanism that changes the date once every 24 hours and it is 12 hours out.
This can be fixed by winding the watch forward 12 hours.
Jan 20, 2011 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Date will not advance on own. you can change it by hand but doesn't change at night stays on same date for days.
One of the wheels of the watch movement has become stuck or broken. You will either need to fix or replace the wheels or movement.
If you have still have warranty card for Movado and within the date range of the models warranty then Movado will repair watch for free if not you will have to have it fixed by Movado or a local jeweler.
Oct 18, 2010 | Movado 800 Performance watch
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
I can not change date and day for my watch is this mean that the battray is need to change? conquest chronograph watch i can not fix time and date
mcdevito75 here, It could mean a weak battery, Best Bet, look for a small watch repair shop in your area, they will do the adjustments on your watch.
Jul 09, 2010 | Chase-Durer Conquest Sport Chronograph...
Ots sport watch setting instructions ???
My watch is OTS T6320G ,kindly advise as I want to fix time and date
Apr 14, 2010 | Bulova Watch
Date function notworking properly
Do as follows:
1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Apr 04, 2009 | Tissot Le Locle T41.1.423.33 Watch for Men
Citizen eco drive watch movement E870 date window out of synch
If the movement is broken, you can play around yourself; but you will need very fine tools. May be complex. Send an email to Citizen, they are very supportive. Look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Mar 09, 2009 | Citizen 8700 BL8000-54L Wrist Watch
Watches Logo
12 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
