Question about RCA F27628 27" TV
Rca tv f27628
How do you disable the guide plus. my cable will not work with this on.
Http://sci.tech-archive.net/Archive/sci.electronics.repair/2006-12/msg01203.html
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Posted on Jun 23, 2008
How do you disable the guide plus on a RCA tv?
Go to menu & choose settings. Change the zip code to all zeros. Then choose NO for all questions such as cable, VCR, DVD. This will disable guide plus from coming on when power is turned on.
Feb 24, 2013 | LG 32LX1D 32 in. LCD Television
I have an 2001 RCA TV model F31317 it has a Guide plus. Is there a way to turn off the guide plus? I have went through the programing and can't find anything in the menu to suggest a way to turn it off. My...
You can disable this only by going into the Guide Plus+ menu. If you have the original remote or one that matches the feature, press Guide then Menu (sometimes you need to hold this for a few seconds), navigate to Setup (right arrow until it is highlighted). OK, Menu or the down arrow all let you enter the menu. Then use the up/down arrows to select Review Options. Select Off (only two choices). Press OK and exit the guide.
I hope this helps.
Oct 02, 2010 | RCA Televison & Video
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
Rca tv my guide plus has quit working
The guide plus needs to reset itself over night. But as long as you are only connected to cable it will not allow for it to reset. You need a two way splitter the cable company signal will go in one side and the outside antenna or what ever you were connected to before cable will go on the other connector. The single side connector will go to the tv. Where the splitter says 'in' you will actually be using it as out to the tv. Where the splitter says 'out' you will be using as in for the cable and the other antenna. Guide Plus is built into your tv and needs the tv to be off to reset over night.
Jan 28, 2009 | RCA P61960 61" Rear Projection Television
Can anybody help me disable the Guide+ on my 52" RCA TV?
When you first turn your cable tv on go to the customer menu and turn off the G+, you should find it in your set-up section.
Jun 09, 2008 | RCA P52926 52" Rear Projection Television
RCA TV
Hook cable directly to television ( no box ) , Then autoprogram the set if you still have the problem replace the tuner it is about $30 rebuilt from Tip Top tuners.Do not attempt if you dont feel comfortable soldering precisely. IRIONS TV & Electronics www.Irionstvshop.com
Feb 21, 2008 | RCA F27628 27" TV
RCA 27" TV Guide Plus
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
Oct 15, 2007 | RCA F25649 25" TV
RCA tv only in black and white?
The route through the circuits in the TV from the various sources all lead to the final video amplifiers for red green and blue. Somewhere along the route is a circuit called a colour switch. This allows colour if the signal is strong enough, otherwise it only allows black and white. This fault suggests a weak video chip which is the one just before the switch circuit. the fault could also be a faulty coupling capacitor to or from this chip, or a low power supply voltage. Check for dry soldered joints around this circiut. Please note if resoldering on new televisions that they may have non leaded solder which requires about 50 degrees centigrade hotter iron.
Oct 15, 2006 | RCA F27628 27" TV
RCA F27628 27" TV Logo
241 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
