Question about Air Cool Dryers
The cooling fan of my car works continuosly when the engine is on even with the AC off and low temperature. What can be the reason for this mulfucntion?
Mercedes C180 vin number WDC203 0 462R 097105
  • 21 Answers
Electric cooling fans are typically controlled by a thermostat switch senses the temperature of the cooling system water. If the switch fails closed, the fan will run continuously. The switch is often installed in the radiator or engine block, if you identify the switch you can remove the electrical connector. If the diagnosis is correct, the fan will stop. Replace the switch, problem solved.
Posted on Dec 26, 2014
Fan won't work
It can be issue with faulty motor or its faulty fan control relay.
Bother are to be inspected.Test volt at fan relay and fan motor.-------------
For more help,i suggest you to go through the troubleshooting links mentioned below:-----Click the link below:------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on 1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
------------These will help.Thanks.
Nov 27, 2012 | Cars & Trucks
Engine cooling fan only works when ac or defrost is on
if engine at long stand still,the engine temperature will rise about 190 degrees the cooling fan suppose to automaticaly turn on when coolant temperature sensor get hot it cause its resistance decrease causing pcm to send power to coolant fan relays and cooling fans, when you turn on AC the cooling fans suppose to turn on to cool down AC CONDENSOR, IF NOT AC WONT WORK COOLING FAN COOLS DOWN REFRIGERANT SO IT CAN RECYCLE THROUGH THE SYSTEM AGAIN.your cooling is suppose to turn on when engine at a sit still if vechicle not moving as coolant temperature rises at a set point the cooling fans will turn on cool down engine.cooling fans dont turn on when you first cold stsrt vechicle unless you have AC SWITCH ON.if cooling fans dont turn on when vechicle at a long stand still or moving along slow traffic.if coolant temperature sensor been replaced and fuses and relays okay have dealership check see if pcm driver circuit working faulty pcm will cause cooling fans not to turn on.
Sep 27, 2012 | 1996 Buick Century
Overheating problem, what is the most probable cause?
You need to stop using it immediately before you
cause some damage or more than you may already have
That is just common sense. It should not overheat or
be any different than it was in the past without problem
The car has to be checked over/diagnosed,tested,etc for
various issues to resolve
Borrow or Rent a car until resolved
No way to guess at the problem
You should have some type of codes avail even
if the check light isn't on,you need professional help
to get a start on resolving
The timing belt maybe worn & jumped or the head gasket
bad.
Over heating isn't usually a cheap repair unless the thermostat
sticks partially closed
The RPM moves around the car is 11 years old,so it may just
need a though going over
Timing Belt,O2 Sensors,Exhaust Converter,Spark Plugs
and such
If you depend on a repair shop to do things & don't
have the knowledge to request work done throughout
the year,then you run into a lack of proactive preventative
maintenance situation. Most things are simple looking
back, once resolved
Sep 06, 2012 | 2002 Chevrolet Prizm
Gas gauge and temp gauge and heater/ac fan dont work
Sounds like a fuse or an earth wire loose in the cabin. Take the fuses out and chk them in the light. Go thru all earth wires both in and outside the cabin, something is loose if not a fuse, remember fuses in the engine bay. cheers
Sep 04, 2012 | Cars & Trucks
1996 Honda Odyessey engine cooling fans don't come on and engine on and engine temperature tends to go up. it will only come on when the AC is switched on. i do not need to run the AC all the time but i...
Check all fuses first. if the fuses are okay, disconnect the engine cooling fan connector and using jumper wires, connect the fan motor directly to the battery and ground. If the fan still doesn't work, replace it. If the fan does work, its relay may be faulty. Check in the engine compartment fuse box for the cooling fan relays. Try switching the cooling fan relays and see if the engine fan comes on and the a/c condensor fan stops working. If so, the engine cooling fan relay is faulty. If the engine fan still doesn't come on with a good relay, then check the engine temperature switch located at the passenger end of the front cylinder head. It is supposed to switch (have continuity) when the engine temperature reaches 205 deg F. You can remove the switch and put it in a pot of close to boiling water (212 deg F). If it doesn't have continuity at that temperature, it is defective.
Mar 21, 2011 | 1996 Honda Odyssey
The cooling fan on my 2001 Mustang runs constantly. Even when the engine is cold. The temperature gauge reads normal. The engine has 39,000 miles. What is the problem?
low engine coolant ,coolant temp. switch for the fans,fan relay shorted closed.and possibly a computer.check for codes,coolant level in radiator when cold,remove relay for fan and see if the fan stops. check to see if the ac is on or if the heater ac switch is in defrost position. ac will be on and coolant fan is commanded on also.i hope this will help.
Oct 27, 2009 | 1995 Ford Taurus
My cooling fan does not come on when car is started.both the ac and cooling fan comes on when ac is started
The cooling fan is required to operate when the engine temperature rises above the maximum operating temperature threshold.
After the car is started, it will usually take some time for this temperature to be reached.
Ensure fan runs when fan control temperature sensor switch demands.
Oct 10, 2009 | 1997 Nissan Sentra
Dryers Logo
75 people viewed this question
Top Air Cool Dryers Experts
Are you an Air Cool Dryer Expert? Answer questions, earn points and help others
