Question about Kitchen Ranges
Westinghouse freestyle thermocouple replacement
I have a Westinghouse freestyle fridge and it is collecting up to 500 ml water underneath the crisper bins each day.
remove crisper bins and look for the drain tube . it must be clogged . as water is supposed to drain to the evaporation tray under the fridge .
Dec 17, 2014 | Westinghouse Refrigerators
How to adjust flame on Westinghouse freestyle gas oven
The flame is regulated by the thermostat you don't say if it's too high or too low. Suggest you buy an oven thermometer available for a few dollars at most homeware shops, compare the temperatures then you will see if the thermostat is working or not.
Apr 22, 2014 | Cooktops
I have a westinghouse oven freestyle 662 and i was wondering how to replace the light bulb inside the oven
I had the same problem. I found the glass cover was just too tight to move by hand so after isolating the oven, I used an old cloth and adjustable pliers that could apply more pressure. This worked straight away.
try not to screw it on too tight.
cheers
Jan 19, 2011 | Westinghouse Microwave Ovens
Im after a manual for westinghouse freestyle fridge RJ422T-R
You can go visit onlinand Google.www.manual for westinghouse freestyle fridge RJ422T-R
Oct 23, 2010 | Refrigerators
Door seals rotting out on westinghouse freestyle 920 dishwasher
If the machine is kept idle for long time without use, these types of problem happens.
When not in use, apply talcum powder over the gasket. Moist the powder and apply as it will fall off . Leave the door slightly open by keeping some folded cloth or some other soft material and close the door.
Contact the service provider and protect the electronics by a water-resistant cover.
May 26, 2010 | Kenmore 15129 Built-in Dishwasher
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 | Ovens
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Fridge freezer not cooling
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Apr 12, 2009 | Westinghouse Refrigerators
Kitchen Ranges Logo
63 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
