Question about Hitachi Office Equipment & Supplies
Hitachi CPX3021WN projector gives greenish image at center.picture is after focusing still slight blurry.Lamp life 168hrs
Filters cleaned, Lens cleaned, Focusing manually done. At the start up picture clarity is ok, slowly center to outer looks greenish & blurry.Lamp shows 168 hrs
  • 146 Answers
SOURCE: HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Posted on Jan 05, 2008
Marrie
  • 563 Answers
SOURCE: focusing
Hi real12
Unfortunately you will have get the focus ring replaced before you will be to make use of it if your model doesn't have automatic zoom and focus in the user menu.
Sorry , but there simply is no other way.
Posted on May 21, 2008
projdoc
  • 2237 Answers
SOURCE: Infocus LP 70 projects a blurred display
if it's pixelated, it's an electronic issue. if it's evenly blurred, it's an optic issue. was it dropped on the lens? see if the lens is hard to turn or is not sitting properly in the projector.
Posted on Jul 08, 2009
  • 43 Answers
SOURCE: Sanyo PLC-SW30
Solved many many problems with this projector. Used the repair service manual.
You can get it free here.
http://yama.co.za/forum/index.php?topic=146.0
Posted on Dec 03, 2009
projdoc
  • 2237 Answers
SOURCE: Greenish tint on my Hitachi x1250 Projector
the light polarizer on the blue lcd panel is fried due to excessive dust and heat. you'll have to replace the entire optical engine.
Posted on Dec 23, 2009
Epson projector center blurry
Sounds dumb on this one but make sure the lens is cleaned. Other then that check the manual for operating range of lens to screen. Typically somewhere in the area of 8 to 12 feet.
Oct 09, 2012 | Epson PowerLite 83 Plus Projector
White spots on screen i have changed the lamp
It's probably you have a busted DMD chip, have your technician replace that, better yet buy a new projector because replacing that chip costs almost a brand new unit.
Nov 19, 2011 | BenQ Office Equipment & Supplies
How do I clean the filter of the Hitachi CP-X1200 multimedia Projector ?
Remove and use fine bristle brushes assisted with a jet of air which will clean up the fine netting of the filter. It is important that the filters are occassionally cleaned so that there is no dirt accumulation within the lens unit that can reduce the life of the LAMP and save an expensive repair.
Aug 19, 2011 | Hitachi CP-X1200 Multimedia Projector
Cannot focus uniformly across the projected screen. This seems to be more than a focus problem in that some areas of the image seem blurry as opposed to out-of-focus. Also, in what may be a related...
try bringing the screen up as close as possible to the projector and still get a focused picture. check keystone here and also for image clarity. if you still have problems, check for dust or moisture etc in the optics. check the lamp for a clean front surface. clean the air filter also. Try a different image source for differences
May 20, 2011 | Eiki LC-XB25 Projector Multimedia...
Projected image is blurry, mostly at the top of half. Weird. Tried another laptop. Although that one was slightly clearer, the top of the image was still blury.
Clean the lens on the front, turn on the projector and wait for it to heat up, then turn the plastic ring on the front to change your focus. computer image can't be made blurry because of software. Blurriness is always something to do with the lens.
Jun 10, 2010 | Sanyo PLC XU35 Multimedia Projector
There are blueish-purple crystal-like distortions in the projected image. They actually can be brought into focus to look at, and at that point the projected image is extremely out of focus. So, obviously,...
either there is something on the inside of the lens, or there is something on the lcd prism face. if it was the lcd panel, it would be in focus with the picture. take it in for a good cleaning.
Aug 14, 2009 | NEC MultiSync MT840 Multimedia Projector
Projector produces very low light.
My recommendation is that since you have 2 of these machines and the other is working fine,
Pull out the lamp from the good one and place it in the faulty one.
Turn it on and check the projection quality if it is still blurry. If it is working good, then replace the lamp. If it is still blurry, a good cleaning to the lens on the projector may be a good idea.
You can also check the auto focus function of the projector and the cable that provides the video signal to the projector
You can get the manual from below link if you need to find out how to check the auto focus setting
http://www.necvisualsystems.com/Documents/UserManuals/MT860_1060_1060R_MAN2.pdf
Jun 03, 2009 | NEC MT1060R Multimedia Projector
Greenish picture when i play my Compaq Ipaq MP3800 projector
The greenish image is due just by one sof the terminals of the cable. You just need to replace it. Or try anothr RGB cable and look what happen.
Nov 18, 2008 | Televison & Video
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Camera Problem with Toshiba TLP 261
hi Document camera image is blurry: -The lens is dirty - Clean the lens with a blower or lens cleaner -The picture is out of focus - Focus the picture by turning the focus ring -The light is not on - Turn on the light check user manual for more details: http://www.fixya.com/BrowseManual.aspx?mnlid=5662&prdid=147420&__PAGED_=1 good luck
Mar 27, 2006 | Toshiba TLP 261 Multimedia Projector
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
