Hi ya, I need to know how to empty the water tank?
  • 3,506 Answers
You need to advise what appliance you have
Posted on Dec 11, 2014
How do u empty tank ?? I can't find how to get into it.
You shouldn't have to empty pan, the fan usually evaporates any water accumulation. I know of no water tank on a refrigerator. Hope this answered your question.
Nov 23, 2014 | Robinair 34750 R-134a 50 lb Empty...
Remove Water Tank
  • require you empty the unit by hand (usually less expensive units). These have either a removable water tank which must be emptied, or have an internal tank and a drain, where you have to empty the water into your own pan. Sometimes the drain is on the bottom of the unit, making it hard to find a pan that will fit under the unit to drain it.
  • discharge most of the water through the exhaust hose (usually more expensive units). This is called "Auto-evaporation" or "Self-evaporating" feature.
Most units are made so that they can be drained with a gravity hose that flows to a drain inside or outside your house. But the water must drain down. If the drain is higher than the unit, you may need a condensation pump to move the water upward. A few units do include a pump to send the water a short distance through the drain pipe.
do no forget to rate the solution as fixya if it helps you.
thanks.
Jul 02, 2008 | Danby DPAC10031 Air Conditioner
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
Never had any real problem with our old, but very good working machine. Yesterday suddenly keeps indicating water tank is empty, but the tank was topped up. With this indication "water tank...
Hi
The problem is probably in the water tank itself. Is your magnet in the water tank? Is it floating or sunk to the bottom? If its not in there, that is your problem. Need to know these things to determine the problem.
Nov 26, 2010 | Saeco Royal Digital Plus Coffee...
Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Dec 31, 2009 | Hoover Dryers
My cold water tank in loft is not filling
the ball float in the tank has stuck shut. Access the tank and free off. It may need replacing
Aug 19, 2009 | Plumbing
Full Tank very fast
witch model do you have, for some models thats normal on others its not, some run the water over hot coils and it evaporates others the water goes into a holding tank and sits their til the tank fills up then you must empty. expect more water when high humidity or in the summer
Jun 27, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
