Question about Dryers
Dryer works in timed mode but not automatic. Kenmore 417.93142400
  • 56 Answers
Please define does not work? But if I may guess, try testing your sensors. There are usually drawings packed with the dryer to tell you how they function.
Posted on Dec 13, 2014
5 Suggested Answers
  • 20 Answers
SOURCE: Newer Kenmore dryer automatic sensor not working.
I dont understand your problem?
Posted on Jan 19, 2009
milten1
  • 1304 Answers
SOURCE: Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Posted on Oct 06, 2009
SOURCE: I have model 417 88042 700 Kenmore Electric Dryer.
The front electric panel is out. I have the same problem. The part costs around $161.00 and about $100 for labor to fix it. Sorry for the bad news.
Posted on Sep 17, 2010
  • 8 Answers
SOURCE: Kenmore gas dryer 110.74632300 heats only for a short time in timed mode. No heat in automatic.
The gas
Posted on Jul 03, 2012
Auto is based on a moisture sensor, so it may be bad.
Dec 09, 2014 | Dryers
DRYER WILL NOT SHUT OFF ON AUTOMATIC SETTING
Most of the time when a dryer won't shut of in automatic, it is because the sensors inside the drum are bad and cannot sense when the clothes are dry. If your dryer works good on a timed dry then is probably the moisture sensors.
Oct 08, 2014 | Kenmore Dryers
I have model 417 88042 700 Kenmore Electric Dryer. When trying to start a drying cycle it goes automatically to COOL DOWN mode, every time...
Mar 05, 2010 | Kenmore Dryers
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
It will not automatically turn off when running, the knob does not turn while running.
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Apr 14, 2009 | Kenmore Dryers
Jan 19, 2009 | Dryers
Kenmore dryer dial doesn't advance
That looks like a thermal shut off to protect the dryer if it overheats.
I am assuming that the timer never advances - even in timed mode (as opposed to some automatic drying setting).
Most likely you need to buy an inexpensive multimeter and start testing. There should be a schematic on the back of the dryer either on the outside or on the inside of the back panel.
Since timers on dryers are just mechanical devices that use a small motor (and yours is brand new), it looks like your timer is not getting power. The switch itself is mechanical, you should be able to rotate it to the different settings, press the start button and the dryer will work in the correct mode. Without electricity, the timer won't advance.
Check for loose or burned connections. Dryers use a lot of amperage so occasionally the wires can get burnt and corroded.
Sep 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore Dryer 70 series
Hi, the problem with the dryer not stopping is most likely the switch that controls when it starts. This switch is located behind the button you would push in to start the dryer, and if you can take off the rear panel and get to it, you can most likely adjust the internal contacts so that they don't continuously make contact. Or you could just replace the switch, which might be easier!
Jul 21, 2008 | Kenmore 64742 Electric Dryer
Kenmore gas dryer
is this in the auto mode or timed mode??
Jan 25, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
