Question about Brandt Washing Machines
Hi there Washing Machine model: WFA0877A My wash cycle was abruptly ended and all three indicator lights are switched on. How do I resolve this?
Unplugged and plugged in. Remove and clean the bottom clogging point.
Http://www.manualsdrive.com/results.php?lang=en&search=BRANDT%20WFA0877A#.VIhIUXtwnBQ
send your email get the user manual
all three lights on is blocked up drain
the pump not rotating {check for wires and coins}
i would empty the machine fully at the drain cycle and also at the pump filter
till its all empty
switch off and remove the water pipes and the mains plug
then pull out and lay the machine over on the side
opposite the soap drawer
then underneath you will see the pipe that goes from the drum
to the pump
take it off both ends and check its totally clear and any trap {a ball and also sometimes in a cage}
shine a light inside the drums and look around for socks or tights or plastic etc {have kids check for lego plastic toys etc etc }
clothing wires in the pump end
and check the drain
make sure the drain at the waste end is clean and flows well at the sink etc...
put it all back together
and try to hold in the program select or start stop button for a few seconds when you apply mains
then this resets the fault it detected
it should work aok
if not what part of the cycle did or does it stop at???
this will give more info that the three stuck lights
i can see the manual online for it
perhaps it has some details
Posted on Dec 10, 2014
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Washing machine would not start
On the lid is a switch that turn off the washer when the load pushes against the top. You may have over-loaded the machine.
Feb 26, 2014 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
My washing machine hitachi make model no SF-70EJ having problem with spin please give assistance what to do
Hi.
Most spin problems are consequence of drain system faults.
The first part to check is drain system. Check the drain hose at the back and the drain filter attached to the pump. See article at the end for more detail.
Most machines' timer boards do an additional check on the lid switch before starting the spin part of the cycle. If the lid lock light is flashing and the machine does not spin the lid switch is probably defective.
The lid switch is tested jumping its contacts or reading Ohms at switch terminal. A two-terminals switch must read continuity (low impedance) when door is closed and must read open (infinity of Ohms) when door is open. If the switch is a three contacts, the third contact is called "heater". In that case there must be continuity between the three contacts with lid closed. If the model instead of a simple switch uses a wax motor, then the lock cannot be tested by jumping contacts. The lock motor must be tested reading Ohms and checking that impedance is the same as indicated in service manual.
If lid switch and drain system are OK, then the pressure switch must be tested.The pressure switch detects the water level and among other things determines when to advance the cycle to spin.
If all the above is OK, then the motor and motor control unit (if present) must be tested.
Please read the solution in the article below for more:
If you have no spin ...
You can find parts and diagrams for most appliances using the links listed on this page: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 04, 2011 | Washing Machines
The status light says "control
Thank you for using FixYa. The " control locked " is a safety feature to prevent the inadvertant use of the machine by a child. To unlock the controls press the "end of cycle "button for approximately 3 seconds until the "control locked " indicator light goes out. If you have young children in your home and want to lock the controls press the "end of cycle" button again for three seconds.
Please post if this solution has been helpfull
Thank you
Duncan
Mar 04, 2011 | Whirlpool Washing Machines
The control locked is on on my machine
The control can be unlocked by pressing and holding the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and make sure and eliminate the possibility of an electronic glitch if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fail to unlock it. Indicate the exact model number of the machine for the right replacement part number and for specific replacement procedure should you require it.
Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My machine giving error message "control locked", please let me know how to unlock. Thanks
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing lights and machine not entering washing cycle.
you may have a circuit board damaged, check for the pump and door lock. may be one of this 3.
Nov 13, 2008 | Hotpoint Aquarius WD640 Front Load...
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
258 people viewed this question
Top Brandt Washing Machines Experts
Gerry Harvey
Gerry Harvey
Harjeet Singh
gcharal
Level 1 Expert
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
