How long does it take to charge battery initially and should there always have a lighting bolt while charging
Beand new abd has been charging 10 hours and no logo appears yet
  • 3,382 Answers
I would do 24 hours the first time. I have no idea what you have so I cannot answer the remaining questions.
Posted on Dec 10, 2014
How long does it take to charge battery for the first time?
Depends on the battery... a "toy" battery may only need an hour or two....a motorcycle battery may need 12 hrs @ 4 - 6 amps - depending on the type of battery....a car battery may need 10 amps for a short time (4 hrs) because they come pre-filled and charged. I NEVER depend on the "charge" of a new automotive battery (of any type)..I always charge them for at least 4 hrs @ 10 amps before initial use!! ...they seem to last longer
BUT - AS a RULE = 10 hrs @ 10% of the rated amperage...
Aug 16, 2017 | The Computers & Internet
New gmr 3055-2ck work fine just charming indictater on charge won't stop have charged twenty-four hours lights still flash
Make certain you are charging with the radio OFF. If on, the radio will use a small amount of energy and the charger will not know the battery is fully charged. If you intend to leave it on the charger, ON as in standby, then the lights will always flash. I would put a timer on the wall adapter so the battery is not always being charged. A battery always being charged will not last long, likely get hot and may cause problems. These are light duty radios, not designed for 24 hour if even daily use.
Jul 12, 2016 | Uniden Radio Communications
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Which battery cell is better for ntl cordless vs2000?
Please replace with same rating/type as given on cell that is normally NI MH, Rating current rating - 600ma, 900ma, higher ma means lasts longer after charge. Brand- panasonic, sanyo, any standard brand, initially charge for 10 to 12 hours. Pl do not keep hand set always on dock, this overcharges the battery, shortening cell life.
Jan 07, 2015 | NTL VS2000 Cordless Phone
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
I always charge my phone before i go to sleep and when i wake up it says it is charge but when i unplug it .. it says 75 percent what do i do??
First, every phone battery has their own required / maximum time of charging. Charging it before going to bed will over charge the battery.
Since you're getting 75% of the battery status, it means that the battery is now starting to become defective. The best thing that you may do is to buy a brand new battery for your phone.
Most brand new batteries requires 6 to 8 hours of charging. After the initial charging, the next charging will be 3 to 4 hours only. BUT, you have to make sure that the battery runs out of charge before plugging it in to the wall socket. This will make the battery life lasts long.
Thank you and good luck!
Aug 18, 2010 | Cell Phones
The light on my Roomba flashes amber very quickly when plugged in directly with the adapter. what does this mean? it usually flashes slower when docked.
If Roomba senses that its battery has been significantly discharged, Roomba will enter a special 16-hour refresh charge cycle. When the 16-hour refresh charge is initiated, the CLEAN light will quickly pulse red/amber. Do not interrupt the cycle once it has begun. The 16-hour refresh charge cycle is initiated by the robot and cannot be started manually.
For long-term storage, always remove the battery from Roomba and store in a cool, dry place. Blue or black batteries should be stored after Roomba has been used. Yellow batteries should be stored after being fully charged.
Battery capacity reduces overtime and usually the battery will need to be replaced each year.
May 14, 2010 | Roomba Robotic Floor Bagless Vacuum
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
I have a audiovox dvd player model D1998PK. I need to know how to tell when the battery is charged.
1. A blinking light indicates that the battery is not charging.
2. The steady light goes out (or turns green) when the battery is charged.
3. 6 to 8 hours for the initial charge.
4. Charging time after the initial charge depends on the length of time the battery was used and will increase over time as the battery gets older.
5. 2.25 hours of play time
Aug 23, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
