Spin Terrirble wobble on the spin cycle. I've checked for levelness(sp?) and it is off slightly but it wasn't doing this before today so I don't believe that is the problem. Even if I hold the machine it continues. I did try to level the machine but the rear feet seem to be connected to some sort of self leveling bar and I could not secure a position.
  • 1 more comment
  • islander07 Dec 04, 2007
    Thanks but that's not the problem. Actually it seems to have solved itself.
  • Alvin3 Feb 18, 2008
    Washer wobbles and vibrates constantly at spin cycle. Have leveled it and the problem continues. Have tried adjusting clothing inside and does not help problem. I have a Kenmore 700 series top load washer. The washer is quiet series and it just recently began doing this. Any ideas?
  • Anonymous Jan 25, 2009
    I have the same problem. Rearrangement of the load does not solve the problem. The washer is perfectly level.
Does this happen with every load? I've had this happen occasionally but it was caused by one or two heavier when wet pieces of clothing that caused the tub to get off center and it would wobble out of control. By just rearranging the wet clothes to balance the tub it stopped wobbling. But only after making sure that the heaviest objects were on opposite sides if the tub.
Posted on Dec 02, 2007
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
My machine is extremely loud when it spins. what do I need to do
I would guess you need to level it. Most washers and dryers have some sort of self leveling in their feet but some do not. Attempt to lift the rear of the machine up two to four inches and then set it back down. Check to see if it wobbles. If is still wobbles you may need to adjust the foot using an open ended wrench.
Oct 18, 2012 | Amana Tandem 7300 Washer and Dryer Stack...
Perfect level sounds very strange
Check the leveling feet on your machine. With the machine turned off, and with a small carpenter's level, check to make sure the machine is level front to back and side to side. Then give the machine a shake in each direction to make sure that the feet (which are adjustable). If the machine wobbles-even a little bit- adjust the feet until all 4 feet are in contact with the floor and the machine fails to wobble when pushed.
Rerun a load and see if the machine has stopped sending morse code...
you can also make sure that the fill hoses aren't banging into the machine or the wall during the cycle.
let me know if you have success!
Jun 01, 2010 | Washing Machines
Excessive shaking during spin final cycle
check to see if the floor is solid and not soft, thin or flexible. are the leveling legs tight? make sure the locking nut is tight and that the leg does not wobble.
Dec 23, 2009 | Maytag Washing Machines
Wobbling bad on spin cycle
check the level of your machine. after adjusting level make sure eveything is tight and in place on your machines legs. refer to your owners manual in the setup section for proper leveling proceders.
Oct 30, 2009 | KitchenAid KHWS01PMT Front Load Washer
1994 Toyota Camry LE Sedan intermittent wheel/suspension wobble
How about the rear bearing? These cars do have them!
Aug 11, 2009 | 1994 Toyota Camry
Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Jan 16, 2009 | GE Washing Machines
Brand new front load kenmore wobbles and moves across floor
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
500 people viewed this question
Top Washing Machines Experts
