Question about Plumbing
I was asked to add more details to my question. The ideal standard faucet in our kitchen is just like all other faucet having a handle. We use it to open or close tap water by pushing it toward right
I tried to screw the handle back into the hole on faucet but it did stay in. Look like the screw thread at the hole on the faucet is quite worn.
    Top Expert:
  • 50,411 Answers
Got t a plumbing store and see if the sell just handles .
Posted on Jan 29, 2015
  • 171 Answers
SOURCE: kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
  • 374 Answers
SOURCE: How do I disassamble my one-handle kitchen faucet?
First ensure you have shut the water supply off at the stops- the small valves located underneath most plumbing appliances. Since we are speaking generically my comments may be a bit different depending on make and model. Most single handle faucets have a snap on cover over the base where the handle connects to the valve base. Pop this cover off and it will expose a screw that holds the handle onto the valve cartridge.You will need to remove this screw this will expose a nut/retainer that holds the cartridge in place- remove this item. Now will be able to pull the cartridge out using a pair of pliers. If the cartridge will not come out most home repair stores sell a cartridge extracting tool. This tool is a tee handle device that screws into the cartridge and has a nut that one tightens to break the cartridge free of the valve body. Some extreme cases will require some extreme pulling and snatching on the Tee handle to get the cartridge out. I personally dry the interior of the valve body a apply a thin coat of grease/lubricant to improve the service life of the new cartridge. Hope this is of assistance to you and thanks for using Fix Ya. If I can be of anymore assistance please let me know.
Posted on Oct 08, 2008
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 12902 Answers
SOURCE: Water leaks from around the stem when I lift the
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Posted on Nov 04, 2009
Testimonial: "thank you so much."
How do I choose my kitchen faucet?
Whether you are remodeling, have an old leaky faucet, or are simply looking for an easy way to update your kitchen, choosing a kitchen faucet can be a lot to take on. From choosing the finish, number of handles, or thinking about pulling the faucet out or down, it's not just A or B anymore and that can be overwhelming!
Here is a quick list of 5 questions to consider before buying a new kitchen faucet that might help you modify your options before even leaving your house!
1. How many holes are in my existing sink?
Unless you are starting from scratch, keep in mind what is already in your kitchen. By knowing how many holes your previous faucet had, it is easier to tailor your search because this criterion needs to be met. One detail to keep in mind is that a lot of faucet manufacturers offer optional deck plates so if you currently have 3 holes, and want a single hole faucet, it is easy to cover up!
2. How many handles?
Two handles allow you to mix the hot and cold water, while one handle allows you to adjust the water temperature with a single motion.
3. Is a sprayer a necessity?
This question deals with a big part of the functionality of the faucet. Keeping in mind how you are using the faucet will help you to decide if a multi-function spray faucet would be ideal, aside spray, or no sprayer at all.
4. What are you using it for?
This is a big question! Do you do most of your dishes with your faucet, or do you mainly use it for rinsing? If large pots and pans are constantly filling up the sink, a sink with an arched neck might help with the functionality. On the contrary, if a lower sink works for you, or you have a smaller kitchen, something that goes straight out might go well with your kitchen.
5. What's your style?
The last tip to think about before shopping around is to know your style and your style in your kitchen. If you are a traditional person, look for a faucet to reflect that! If your kitchen is contemporary find a faucet that is chrome and adds that bit of modern edge.
After you have done your homework and are prepared, go to a showroom or a place where you can touch the product, this will give you that last bit of confidence before choosing your perfect faucet!
Mar 21, 2018 | Plumbing
The handle on the Ideal Standard single faucet in our kitchen fell out.
All sorts of things come to mind. Get on your computer and track the company and see if they offer replacement parts or an upgrade. Looks like you'll need to drill the hole and retap the threads. OR go down to a Michael's if you have one or any place that would sell wooden dowels. Find one that is a tad larger and whittle it to fit the hole. Use teak or something strong. It won't look stock but if you do it nicely you can stain the wood and make it look good, spray some clear on it to make it water-proof. You can also try running a tap through the threads to see if the threads can be repaired. Long shot but if you are on GREAT terms with the Powers, a small miracle would be nice ... but it CAN HAPPEN> I have run taps through some beaten threads and they have come back to life. The last option would be to have a machine shop make another steel dowel but thread it for the next size up and drill and tap the hole to match.
Dec 12, 2014 | Plumbing
I was using my single mixer kitchen tap or faucet I could not turn the water off, I can only turn off the water under the sink. How can I fix this problem I
Without seeing the faucet or knowing any other details, it sounds as if the o-rings or seats are bad. Most likely twisted or misaligned if the problem is such that it won't turn off. If the faucet assembly is loose, these small components can come out or become misaligned. Write down all the information you can about the specific brand and model faucet, then take this down to your local hardware professional and ask for the rebuild kit. You may need valves in addition to seats, springs, washers and o-rings (depending on the model). Most companies have kits for doing these rebuilds. Check also the seal made at the seat. If this is not tight, water will flow. Be sure you ask which, if any, special tools are necessary to remove the faucet assembly and various components. These tools are sometimes standard and sometimes specialized or unique to a certain brands/models (ie: handle pullers, seat pullers, valve wrenches). Final tip: before doing any faucet work, always remove the aerator to allow any debris to pass through the line and flush thoroughly upon completion before reinstalling the aerator.
Dec 08, 2013 | American Standard Kitchen Faucet 6310 020...
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Jan 09, 2010 | American Standard Kitchen Faucet 6310 020...
How to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Hi folks, seems stupid, but I'm changing the cartridge on my american standard kitchen faucet. If I line up the holes on the botton of the cartridge with the holes in the fixture, I don't have the ability...
Most likely you need to adjust the hot limit safety stop which restricts handle swing to limit the high temp of the water and avoid scalding... check out this link to the install manual for your faucet. Also includes detailed diagram of cartridge alignment just in case you need it.
http://www.americanstandard-us.com/Assets/pdfs/as/install/Install_1859.pdf
Hope this helps, Tripp
Dec 13, 2008 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
