Question about Sewing Machines
How do you do the small zigzag stitch? - Sewing Machines
  • Sewing Machines Master
  • 1,860 Answers
Try this link for a video, and see if it will help you
how to do the small zig zag stitch Bing Videos
Posted on Dec 10, 2014
Why is my White 1866 dropping stitches not picking up the bobbin thread when I am doing zigzag stitches?
Be sure you are using a brand new needle that is compatible with the thread and fabric you are sewing. Otherwise, your machine is most likely a bit out of time. Search for sewing machine timing or take it for service.
Feb 25, 2017 | Sewing Machines
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
1249380 kenmore sewing machine
Depends on what stitch you intend to use. I do a lot of mending with a three step zigzag set to maximum width and minimum length -- see: http://www.picturetrail.com/sfx/album/view/24395076 A wide, short zigzag stitch is another popular choice, as is a straight stitch worked back and forth over the area: http://www.running-w-scissors.com/2014/01/tutorial-patch-mend.html
If you're just mending a seam that's come unstitched, a straight stitch or zigzag stitch similar to what's already in the seam is what you're looking for.
Feb 05, 2014 | Kenmore Sewing Machines
Can this machine do zigzags?
The Sew Dlite 11401 shown on Amazon here, http://www.amazon.com/DLite-Supreme-Portable-Sewing-Machine/dp/B0006BDG8Q , does not do zigzags. It only does straight stitches. There are similar models that have a stitch width lever. Those do zigzag stitches and straight stitch when in the zero width mode.
I hope this helps.
Aug 25, 2013 | Sew D'Lite 11401 Mechanical Sewing Machine
I would like to know how to set the machine up for polyester/spandex material
You need a ball point size 70 or a jersey 70 if you can get it. Stitch length 2.3 to 2.5. Re tension, just normal tension setting. If the machine is sewing an evenly balanced zigzag on regular cotton fabric, then tension is fine. If you find the straight stitch on your fabric pops under stretch, then try using a very small zigzag to put some flexability into the seam.
Mar 28, 2013 | Bernina Activa 140
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Zigzag stitch only stitches on the left side.
if the zigzag stitch only stitches on the left side it's very possible that the cam or gear inside that does the zigzag stitch is either worn out or broke or damaged in some way, only a repair shop service tech can tell
Aug 26, 2011 | Simplicity Denim Star SW210
Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Nov 05, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
