Disassemble Removed all srews from underside but top and bottom sides remain attached at one end
  • A Geezer Dec 11, 2014
    It's a small tabletop printer. All the visible screws were removed but something inside, which I cannot see because I cannot separate them ,is holding them together at one endthe parts
    Habit-Forming:
  • 91 Answers
What kind of printer you talk about , any way look if ther is a scrow under top cover inside the printer.
Posted on Dec 10, 2014
Testimonial: "It's a small unit which can be held in the hand. Thank you for replying. All screws visible were removed but I could not prise the top and bottom parts of the case far apart sufficiently to enable me to find what's holding them together at one end."
Disassemble Toshiba A215-S7416 for speaker replacement
The speakers are monted beneath the top bezel that houses the keyboard.
Firstly, remove the keyboard, remove all of the screws underside of the keyboard and base. disconnect the plugs and sockets from the motherboard and remove the top chassis. There are the speakers.
Jul 29, 2014 | Toshiba Satellite Computers & Internet
How to remove the cover on an oster toaster TSSTRTS2S2-033
re: Oster TSSTRTS2S2-033 disassembly
Hi, I just took one apart to fix a cold solder joint, so here's my take on disassembly.
The brushed aluminum cover comes off by removing nine screws on the bottom, then manipulating seven tabs and removing the main handle on the plunger.
First, remove the main handle. It has a small plastic locking tab underneath and the tab may break because it hooks onto a metal spike in the toaster and this seems intended to be permanent. I broke it because I just pulled the handle straight off, but I'm not worried because the handle will still go back on reasonably tight; it just won't lock. However, if you want to try to remove it without breaking the plastic locking tab, I would try sticking a thin screwdriver under the bottom of the handle to disengage the plastic tab from the spike.
Next, remove nine of eleven screws on the bottom. Don't remove the two screws directly below the cord switch on the side - it should be obvious which two screws stay on. And take the crumb tray out too.
Next, there are three metal tabs on the bottom that need to be bent. Two of the tabs were held by the removed screws at the back of the toaster. Just bend those two out of the way away from the plastic bottom. The third tab is located in a hole directly between those other two tabs. Take a pair of needle nose pliers and twist the tab so it will unlock and allow the tab to slide through the slot in the plastic toaster bottom.
The four remaining tabs are located on the top of the toaster just inside the main toast slots. The top metal cover folds into the toast slots and forms metal tabs at each end of each toast slot. They unhook relatively easily by sliding the top cover tabs about 1mm towards the centre of the toaster - there's no bending of metal required.
At that point, it takes some playing around to actually remove the cover. Start by working it straight upwards, then lift it off at the back of the toaster first, before the front because there's a cable at the front of the toaster that prevents the top cover from lifting completely off straight up and, as well, the metal plunger arm that holds the handle will be the last thing to unhook. The plunger arm and the cord retraction mechanisms do get in the way, but it is possible to do it without forcing anything.
Note that after the metal cover is unfastened and pulled off, it is still attached to the toaster mechanism by a short internal electronics cable which connects the toaster to the front buttons in the cover. The front buttons and display remain attached inside the cover. At this point, the toaster should still function normally despite it having the cover off.
I hope that helps.
JimmyHaulinHogs
Sep 02, 2013 | Oster Toaster Ovens
Mdg9700 need to remove front cover, which does NOT match normal maytag type bottom held by clips not screws, first look is that control panel needs to remove first but if so these are concealed.
The top panel and the control panel need to be removed first before the front panel can be removed. Once the top panel is off, the screws attaching the control panel to the dryer cabinet are exposed. The screws securing the front panel to the dryer cabinet are exposed once the control panel is removed.
Disconnect power and remove the two screws attaching the top panel to the rear of the dryer.
Slide the top panel towards the rear to clear the screw head from the flange at the bottom side of the top panel then lift it from the unit.
Remove the screws securing the Heater PCB Assembly at the left side of the dryer cabinet then flip the assembly over and disconnect the black and the white connectors from the board.
Remove the four screws attaching the control panel to the dryer cabinet then rotate it down and remove it from the dryer.
Remove the two screws in the door area and the four screws from the top of the front panel and attaching it to the dryer cabinet.
Pull the front panel forward then disconnect the interior light harness.
Lift the front panel off the tabs across the bottom and remove it from the dryer.
Reassemble the dryer in reverse order of the disassembly steps.
Apr 05, 2011 | Maytag Neptune MDG9700A Gas Dryer
How do I disassemble my dryer?
Difficulty: Moderately Easy
Things You'll Need:
* Putty Knife
* Screwdriver
Step1
Unplug the dryer and move it away from the wall. This will provide work space around the dryer.
Step2
Open the lint trap door and remove the two screws with a screwdriver. Pull out the lint screen.
Step3
Remove the console by unscrewing the four screws that connect it to the top. With the screws removed, disconnect the wiring harness and set the console aside.
Step4
Insert a putty knife between the top and front panel 2 inches from the corner. Press in to release the holding clip and pull up on the top panel to remove it from the clip.
Step5 With your hands, lift up on the corner to disengage the top from the remaining holding clips. Set the top aside.
Step6 There are two screws at the top of the front panel that secure it to the side panels. Remove the two screws with a screwdriver.
Step7. If equipped with a toe panel, insert a putty knife at the top center of the panel. Press in and release the retaining clip and pull the toe panel off by hand.
Step8. Place boards underneath the front of the drum. The boards will keep the drum in place when removing the front panel. Remove the front panel by swinging the top out and lifting it to remove from the bottom tabs.
Step9. The rear panel is removed by unscrewing the attaching screws from the side panels and bottom with a screwdriver. The dryer is now disassembled and all parts are accessible
Mar 07, 2011 | Dryers
I have a Compaq Presario CQ60-215DX Notebook PC. For some reason it shuts down without warning. What can cause it to do that?
Overheating...
Your going to need to clean the fan/heatsink assembly..
On the cq60, this means complete disassembly of all parts and components...in order to get to the fan properly, the motherboard will need to be removed..
Remove All screws on the underside of Laptop, Remove Covers..(hard drive,RAM,Wifi).. Pull Out CDrom....Remove the 3 screws from cdrom area.....Flip Over.. Open Screen, Pull Media Strip (above Keyboard) Away from Laptop... Be carefull Here, There are Fragile ribbon cables attached to this on the left underside ..
Now Unscrew Keyboard Screws And Pull Keyboard away, THere's a ribbon cable here too attached to the motherboard,, Unlock the ribbon cable at the motherboard port(tab on each side pulls forward).. Remove Palmrest Screws.. Pull the Wifi Cables through the Motherboard upperside, Detach any plug/wires... Unscrew Screen Hinge Posts and pull screen away... Remove the 1 screw holding the rear strip of plastic---unsnap the plastic strip at back end of palmrest area... Pull palmrest away... Unscrew The Media Card Bay and the CDrom Port Board(left side)....
Remove the 2 motherboard screws on the bottom left side front...
Unplug the long cable port on the front underside of motherboard right in the middle....
Lift up the motherboard slightly.. pulling it up from the left rear side..... You will see the DC Jack Power Cable Right There Under The Motherboard... This Needs To Be Unplugged...--Pull The Motherboard Up About 2 inches and reach under to unplug the DC Jack Wire Port Plug...and the usb plug wire...
Now continue to remove motherboard
Flip Over And Remove Heatsink Fan Assembly... Unplug Fan... Disassemble Fan And Clean FAn And Heatsink Fins...
Nov 28, 2009 | Compaq Presario Notebook
Replacing the pipe unit
Here's how it works....
An initial short run of the pump draws water from the reservoir into the boiler where it is heated by an electrical heating coil. There are two outputs from the boiler, one from the top runs through a pipe to a steam valve. When the steamer handle is turned, the steam valve opens and steam is piped out through the steam tube for frothing milk. The second output from the boiler is on the underside and is stopped by the normally closed flow valve. When the water in the boiler reaches the right temperature, a sensor switches on the OK light. When the light is on, the user pushes the pump switch and more water is pumped from the reservoir. The pressure in the boiler increases because the pump is trying to push in more water and this forces the spring loaded boiler flow valve to open allowing hot water to run out. As the sump filled with ground coffee is fitted to the boiler output, the water is forced through the coffee and out of the sump where it pours into a waiting cup.
When enough coffee has been poured, the user switches off the pump. The boiler pressure falls and the spring on the flow valve pushes the valve shut again.
------------ The first three steps aren't strictly necessary for disassembly however if you're using a long handle screwdriver then removing the base makes it easier to gain better access to some of the screws.
Step 1. Remove the screw on each base arm.
Step 2. ... then lift and remove the arms.
Step 3. Remove the two screws on the base of the unit. Unlike in this photo I would recommend you avoid resting the machine on its back unless you are sure it has been completely drained. The black plastic base can now be pulled away allowing easier access to some of the screws that will be removed later.
Step 4. Undo the two screws on the top rear.
Step 5. Remove the coffee tamper by pulling and twisting.
Step 6. Remove the three screws. These are anti tamper screws and are star shaped with a nipple in the middle.
Step 7. With these screws removed, the top may be lifted away. The hotplate on the top section is still connected by a couple of thin wires so lift it carefully.
Step 8. To help with shifting the top out of the way, disconnect the hot plate/boiler heater connection. This will allow you to push the top of the unit away giving you the room you need to get inside.
Step 9. Unscrew the electrical safety earth and move the earth wiring out of the way.
Step 10. Use some long nose pliers to pull out the circlip that holds the boiler inlet pipe in place. Pull out the pipe to disconnect it from the boiler once the circlip has been removed.Step 11. Unscrew, remove and clean the diffuser.
Step 12. Remove the two screws . The black plastic underside casing can now be pulled away (plastic tabs need to be pushed aside ). Step 13. Pulling away the plastic underside once screws and tabs are removed.
Step 14. Loosen the four black Torx (star shaped) boiler screws . Water in the boiler may leak out at this point so ensure the unit is upright and a towel is placed underneath.
Step 15. Remove the four nuts (three arrowed) from the underside of the boiler unit.
Step 16. Lift up the top of the boiler assembly along with the steam outlet and place to one side. The two halves of the boiler assembly are sealed with a rubber gasket which should remain attached to the upper housing. Make sure this is properly in place when reassembling.
Step 17. The lower boiler assembly can now be lifted out.
to get more detailed help click this link directly.it has all the required instructions and pictures to disassemble the unit.the model number in the link is bit different from yours but the system is very same so it will help you
http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/129-delonghi-ec710-coffee-maker-disassembly-and-repair
click on the link above directly.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 23, 2009 | DeLonghi EN680.M
GE Spacemaker microwave turntable makes a grinding noise.
I fixed the problem with my GE microwave turntable motor without having to replace it.
I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate.
Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ‘bumps’ on the underside of the gear on top and washer on the bottom.
Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place.
If this worked for you please let me know – karlet@bellsouth.net
Jul 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 20692 top load washer won't spin. The
This is most likely a motor coupling. Pull washer towards you about two feet tilt back, look at floor for black sute. The coupling is attached to the motor to the transmission. It cost about 15.00 and takes a novice less than an hour. There are two 1/4 inch srews, one on top one on bottom , remove these use a scwrew driver to pop off the clips,pry off coupling on both side and replace.
Mar 12, 2009 | Washing Machines
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
71 people viewed this question
k24674
