My hotpoint Aquarius wmf740 washer dial is just spinning is there an easy fix
Yes
its in error mode
its trying to get back to where the error was last
drain the machine from the filter
power off the mains
hold in the power on button
and turn on the mains
it will reset
the machine does a simple self check when it turns on
so a faulty pump will cause this
usually its a faulty pump housing is leaking water
or blocked up
so the pump cant move
when you turn it on it spins the pump motor a few turns and detects its running
so you may need to remove the filter round cover screw
and its tray
and check the pump viens move
may be some hair clip or clothes wires stuck in it or a coin etc
it should go to then where it left off
i would at this point stop it with the button
move the selector to drain
and let it drain and end
or to short spin
if it spins aok and ends
then you can just go for it with a load
if it fails to short spin and drain something else is wrong
prob electronic
Posted on Dec 10, 2014
4 Suggested Answers
miket756
  • 2702 Answers
SOURCE: Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Posted on Mar 07, 2010
SOURCE: My aquarius wmf740 has a blockage cannot undo the ...
tip machine right back and unscrew valve. It is probably caught on something. Hope this helps ( I had a kirby stuck in mine)
Audrey
Posted on Jun 16, 2010
SOURCE: I have a hotpoint aquarius wmf740 that is showing
Something wrong the pump would prevent the machine draining and generate an F5 code.
http://appliancejunk.com/ge/washer/31-9103.pdf
Service manual above.
Posted on Jun 25, 2010
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
Hi my hotpoint Aquarius wmf740 dial is just spinning no clicks is there an easy fix
try to tighten the screw using a small screw driver or try to pull the knob and give some paper packing and fix it then rotate the knob to the desired position
Dec 10, 2014 | Washing Machines
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
I have fault code F06 on my Hotpoint WMf740 machine, what does this mean?
F6 error is apparently a motor fault. The
motor could be jammed, open circuit ,
burnt out. It may just be a broken wire
or connection come off. Check the motor.
Dec 13, 2010 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint aquarius wmf740 that is showing a fault f--5 and wont empty out the water
Jun 25, 2010 | Washing Machines
My aquarius wmf740 has a blockage cannot undo the white water release valve on front bottom right hand side of washer to solve problem. Any help grateful.
Audrey
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Mar 07, 2010 | Washing Machines
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
