My viewsonic laptop its asking to type a x.source but its saying its a batch file what is that coman prompt
  • 113 Answers
X: source the is drive letter which has the batch file. If your batch file is in a usb drive check the drive letter ( E:, F:, etc).
Press Windows Key + R, and type cmd in the box appeared and press enter, you will get command prompt.
Posted on Jan 08, 2015
Windows 8.1 not running hping3 at command prompt
It is not correctly installed.
It is not accepted a windows command, so is not in the windows path, which is why you are getting the error.
Mar 07, 2015 | HP Computers & Internet
Tip
How to create a batch file ...
Did you ever get frustrated when you had to type a long list of commands in the command prompt window, even when those commands were already there on some site... I know it's very frustrating that ctrl+v doesn't seem to paste commands in the command prompt, but there is a way, and it's very very simple...
You can copy and paste those commands, to a new text document, and then select save as, hit the drop down menu where it says text document(*.txt), select all files, and name the file as filename.bat...
then just double click and run it from your desktop, or from anywhere else too...
you can execute the batch file in the recovery console as well ... just browse to the folder where the file is and type the name of the file
Good luck !!
on Dec 01, 2009 | Computers & Internet
I am stuck in Safe mode with command prompt on my Dell 620 laptop windows xp every time I type a command it says it is not recognized as an internal or external command, operable program, or batch file....
try restarting the laptop and before anything pops up on the screen hit the f8 key and the boot menu comes up then start in last configuration that worked and see if it helps
Sep 30, 2013 | Dell LATITUDE Computers & Internet
Can anyone explain how batch file works?
This is kind of tricky not knowing how familiar you are with the commandline, but a batch file simply contains single commands and executes them in order (usually from top to bottom). A batch file (or bash script in Linux) can be very helpful if you have to run certain commands over and over again, so you don't have to write them by hand.
An Example: You want to store your network settings in a text file.
You open the command prompt (WIN+R) and type this line:
mkdir C:\Network
Then you type this line:
ipconfig /all > C:\Network\ipconfig.txt
The first line creates a folder on your C: drive called "Network"
The second line runs the ipconfig command and saves it as a text file in that new folder.
To make a batch file, you open Notepad and insert the two lines. Then save it as "IP.bat" (make sure not to save it as "IP.bat.txt"! This is the most common mistake. If you save a file from Notepad, select "All Files" in the "Save As Type" dialog. Otherwise it will save it as a .txt file and you have to rename it later.)
Now you can double click the batch file and it runs all commands in the file.
You can also see the danger. If you run a batch file and don't know what it really does, it can destroy your whole system. So make sure you understand it and/or get it from a trustworthy source.
A nice example of how complex a batch file can be is here:
AllHelp.bat
Copy the content into a text file, save it as AllHelp.bat, run it and it will create a webpage with all available DOS commands.
Hope this helps - otherwise let me know if you have specific questions.
Enjoy!
Feb 26, 2012 | HEWLETT-PACKARD Computers & Internet
Remove read only files
After copying a batch of files to your Windows PC from a CD or DVD, you may discover that all the copied files carry the read-only flag. The most obvious way to remove the read-only flag from a file is to right-click on its icon, choose "Properties", and uncheck the "Read-only" box. But what if you have hundreds, or even thousands of files marked read-only?
You can batch-remove the read-only flag from multiple files using the attrib command from a command prompt. The Windows Command Line site has a tutorial on commands everyone can use, which includes an explanation of performing this task with the attrib command. The section on the attrib command is titled "Changing file attributes with 'attrib'", and is located about three quarters of the way down the page.
In short, you can remove the read-only flag from a group of files by navigating to their folder from a command prompt and typing attrib -r ./*.* /s. I did this to a folder full of image files with attrib -r ./*.jpg /s.
Bring up a command prompt in Windows XP by clicking Start → Run, typing "cmd", and pressing "OK". In Windows Vista, click Start, type "cmd", and press the Enter key.
Sep 23, 2011 | Computers & Internet
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
Copying to c:\ in vista using batch files..
You need to left click the batch file and "Run as Administrator".
Nov 01, 2009 | Microsoft Windows Vista Ultimate Edition
Problem for installing turboc++4.5 in wista
ok man i too had teh same prob dont back to xp
Before going to the details u have to create a folder (any name will do). Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
Now , Type in the following commands after the Z prompt:
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
Now type d: to shift to d: prompt .
D: cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
D: cd Bin
D: TC or Tc.exe [This presents u the Turbo C++3.0 screen]
On the Turbo C++ goto Options>Directories>Change the source of TC to the source directory [D] ( i.e. virtual D: refers to original c:\Turbo\ . So make the path change to something like D:\TC\include and D:\TC\lib respectively )
In order to get the full screen use the key combination of Alt and Enter
When u exit from the DosBox [precisely when u unmount the virtual drive where Turbo C++ 3.0 has been mounted] all the files u have saved or made changes in Turbo C++ 3.0 will be copied into the source directory(The directory which contains TC folder)
It is a good idea to backup your files in the source directory prior to running DOSBox 0.72
For additional help go through the readme file located in the installation folder or look on the website of the DOSBox forum.
The above procedure has been successfully implemented on Windows Vista Ultimate 64 bit
IMP : Don't use shortcut keys to perform operations in TC because they might be a shortuct key for DOSBOX also . Eg : Ctrl+F9 will exit DOSBOX rather running the code .
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
