Question about Pioneer PDP-5020FD 50 in. Plasma HDTV
Find activation code for pioneer - Pioneer PDP-5020FD 50 in. Plasma HDTV
    New Friend:
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Posted on Feb 28, 2015
SOURCE:
I have a pioneer dxt-x4869bt sterio do I need a certain hook up subwoofers
Unless your Pioneer has a dedicated subwoofer output or output for bass speakers the signal for subwoofers will need to be generated by either a passive or an active crossover from the regular speaker outputs and then the resulting output will probably need boosting by an additional amplifier if a passive subwoofer is to be used. An active subwoofer might not require the additional amplification.
Feb 14, 2016 | Pioneer Car Audio & Video
Changed battery in the car. Now Pioneer AVIC-D3 will not power on. Can you help. Fuse seems to be fine
by pulling the battery you have activated the theft code
reinstall the code into the radio and it will work again
Jan 20, 2016 | Pioneer AVIC-D3 Car DVD Player
Swapped it from XF falcon to a triton ute and cannot get it to fire up.Any suggestions?
if it is a radio , you will need an unlock code because disconnecting it from a power supply activated the anti theft system in the radio
Dec 10, 2015 | Pioneer DEH-235 CD Changer
NO SOUND OUT OF NEWLY INSTALLED PIONEER DEH-X6600BT
Did the Durango have the Infinity sound system? If so, there is a separate amplifier that is probably not being activated. Look for a blue or blue/white wire on the harness adapter and connect it to the Pioneer's blue/white wire. If it does not have blue/white, use the solid blue one.
Dec 29, 2013 | Pioneer Deh-X6600bt Car Cd Receiver...
PIONEER RADIO NEED CODE
The code that came with it to activate it. It should be on a small card
Nov 25, 2012 | Pioneer Repair Fix Service For Avic-x920bt...
MY PIONEER RADIO IS ASKING FOR A CODE
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Aug 11, 2012 | Pioneer Car Audio & Video
My pioneer inno xm receiver is stuck on channel 1 and 234. have had xm reactivate my signal 3x since early this am. still cannot move to other stations, pioneer is closed for the weekend and the manual...
It sounds like the radio is not activated. If it isn't, go to xmradio.com and follow the instructions to activate it. If you have activated it, and you are still getting only two channels, either go to xmradio.com or call them and you can "refresh" the activation.
Feb 13, 2010 | Pioneer inno2 Portable XM Satellite Radio...
Will rarely eject Cd
Either switch is about to go bad, or the plastic activator underneath the eject button, which activates the switch is worn.
You can open it up to look, but I would suggest professional repair for something like this. If the electronic switch is bad, it will need to be replaced, and un-soldered from it's board.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 16, 2009 | Pioneer CDJ-800 Turntable
DE-ACTIVATION CODE FOR A PIONEER RADIO
there is no code for a pioneer radio expecially for the deh p720. what is wrong or what does it do
Jan 25, 2009 | Pioneer DEH-P7200 CD Player
Pioneer PDP-5020FD 50 in. Plasma HDTV Logo
944 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
