Question about LG Heating & Cooling
My lg split system model is LMS304V-4. the fan inside turns on for 3 minutes then turns off but the compressor does not cut in at all. the green light on the left of the panel inside blinks 5 times stops then blinks again.
    Novelist:
  • 187 Answers
I could not find the model number listed in your inquiry, but a lot of LG minispits use the 5 blinking light for indication of poor communication between inside and outside units. Try this before replacing control boards. Power down the outside unit. Remove the cover for the control wiring and loosen and retighten the 4 wire going into the inside unit. Then go in and remove the shroud cover for the inside unit and find the other end of the control wires and loosen and retighten them. Sometimes over time corrosion builds up and causes loss of signal and the lack of proper signal during communication is similar to someone talking to you while you are listening to loud music while wearing a headset. You cannot hear what is being said because to much noise. Remove the cover on the outside unit and see if it has a white reset button. If it does have a reset button after you have performed steps above, try restoring power and pressing the reset button. If it does not have a reset button, it should automatically reset when power is turned back on. If these steps do not help you will probably have to replace the control board on the condensing unit.
Hope this helps.
Posted on Dec 11, 2014
My LG FAN COILS MODEL HMNC096DEA0 TURN ON FOR FEW MINUTES AND THE LED BLINK 5 TIMES. HAVE CHANGE THE THERMISTOR STILL THE SAME PLEASE HELP
Communicatios Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jan 24, 2011 | LG Heating & Cooling
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
LG split inverter model LSL122V3 and it doesn't cool and shuts down after a few minutes with the green led flashing five times repeating.
Communcation error between in and out.
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Dec 31, 2010 | LG LSC121PMA Split System Air Conditioner
Turn on LG aircon inside house. Goes for a short time them c5 comes up on screen and the aircon stops. Compressor has been noted to start and stop
C5- Indoor to put door communication problem.
Lg spilt system turns of after 5 mins green light flashes
You need to note the pattern of the flashes, short or long flashes etc.
there is a legend that explains all the possible codes.
Example: 3 long flashes 1 short flash, the legend will say something like hi pressure safety switch
or low pressure safety switch , this could mean dirty coils, inside and outdoors, or bad fan motors either location as well, the compressor may be over heating or overloading, or be gong bad. a capacitor may be the culprit, what you can do is see the fuses and airflows good and no coils blocked etc , notice if any motors stop causing the flasing lockout condition.
Dec 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
The unit after running for ten minutes blows hot air inside the house
Service your unit completely and then check the following. 1. Thermostat setting must be minimum +3 degree from your temp. 2. Check room temp sensor 3. Check your out door unit fan motor. (If the outdoor fan runs with less rpm the compressor will get cut off by overload protector)
Dec 13, 2010 | LG LS-L1210CL Mini Split Air Conditioner
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Sharp split system, cutting out
If this is running in A/C mode, then I bet you have a low refrigerant charge. The compressor is dropping out on low suction pressure if it's cutting in and out every 5-10 minutes or so. If it takes hours, then it's likely a different problem.
Reply back and I can help you (been in that business for over 30 years.).
Feb 01, 2009 | Heating & Cooling
Heating & Cooling Logo
156 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
