Had the same problem right before Easter dinner! Used the self cleaning option on my Kenmore electric oven and code started coming on. I was able to still cook in it for about two days and then finally it will only beep when I press, "Bake." It turns on for broil and clean, but goes back to the eo f2 error message within a few minutes. How hard is it to replace the keypad, if that's what it is?Had the same problem right before Easter dinner! Used the self cleaning option on my Kenmore electric oven and code started coming on. I was able to still cook in it for about two days and then finally it will only beep when I press, "Bake." It turns on for broil and clean, but goes back to the eo f2 error message within a few minutes. How hard is it to replace the keypad, if that's what it is?
Yeah, i can cook on the elect. stove top and inside for about en-fifteen min. beforeit starts beeping and "f2" shows up on the screen. im really in no place to mess around w/ a stove when it broken. What should I do? We Keep the stove unplugged for safety purposes, and so it will cool down because it doesnt seem to stop heating up.Yeah, i can cook on the elect. stove top and inside for about en-fifteen min. beforeit starts beeping and "f2" shows up on the screen. im really in no place to mess around w/ a stove when it broken. What should I do? We Keep the stove unplugged for safety purposes, and so it will cool down because it doesnt seem to stop heating up.
AnonymousMay 25, 2008
My whirlpool gold range has EO F2 code,it beeps sometime, oven doesn't work.My whirlpool gold range has EO F2 code,it beeps sometime, oven doesn't work.
I just finished cooking Thanksgiving dinner and heard a beep. I checked on everything I could find and then I noticed that the panel on the oven was saying F2-EO-. I tried to press the cancel/off button but it would not respond. None of the buttons work at all. It continues to beep once in a while. I checked the owner's manual and it was no help.
My model # is 66595802000 its a KEnmore. HOw do we do this? and how much is the part? My model # is 66595802000 its a KEnmore. HOw do we do this? and how much is the part?
I have the same problem and have had to turn the breaker off to get the oven to stop beeping every few seconds. My oven is a Kenmore Elite Electric Model 65595002101. I have been without an oven for a few weeks and it is driving me nuts. Any advice would be greatly appreciated.
AnonymousMar 17, 2014
Sears Elite model 790-4501 get code EO 23 & it will not work. Any solutions-is new. Code not in bookSears Elite model 790-4501 get code EO 23 & it will not work. Any solutions-is new. Code not in book
You can't post conmments that contain an email address.
F2 E0 code is attributed to a short keypad with the Electronic Range Control (ERC). The recommended solution is to replace the ERC. If you can post back with comments I can locate a part number for you if you can give me the complete model number of your range (located along the opening around the oven door or lower drawer assembly). The model number includes a three-digit prefix. I would also need this to determine the manufacturer. This way I can research to find a part number and price and see if this is a repair you would wish to pursue. ERCs can be expensive on some models. I hope this helps you.
Here is what my online service manual for the F2-EO error code says
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board). 2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock)
there should be more of a code like fo/eo or f2/eo or f3/eo or f5 /0o .. if you have # 1 = analog t digital l failure / replace control..= #2 shorted key pad / = replace control /? # 3 oven tempt sensor = repl oven sensor or fuse .// # 5 ck door /latch sw = replace component .. hope this helped . mm ( re/ck codes and see if one of thes matches your problem .. mm pls leave feed back ..
HI, This seems to be another ERC issue. the temperature sensory circuit is malfunctioning. the oven will not operate while this condition exist within the ERC. This malfunction will allow your oven to over heat and may cause a fire. The second issue will be that the relay drive circuit is malfunctioning as well. If you cant cancel the error code and continue with normal usage, you will have to replace the ERC once more.
