Question about Scuba Diving & Snorkeling
I am wondering if I am allowed allowance on rental CPAP machine and masks.I have just purchased CPAP machine and mask today.
  • 2712 Answers
SOURCE: scuba mask maintenance
" 1. Use a defogging solution before every dive, even when diving more than once in the same day. This will prevent your scuba mask from fogging during a dive. You can purchase a commercially prepared defogging solution from any reputable scuba diving retailer. Squeeze a drop or two onto the inside lens of your mask and gently rub the solution around to cover the inside completely. Dip your mask briefly into water, swirl the water around the inside of your mask very quickly and empty the water from your mask. A quick rinse will remove any excess defogging solution from the inside of your mask. You do not want to get defogging solution in your eyes, especially while diving, since it can cause stinging and irritation. If you don't want to use a commercially prepared defogging solution you have a defogging solution readily available and it's free, your saliva. Your saliva will prevent your scuba mask from fogging just as well as any commercial defogging solution. The enzymes in your saliva stick to the lens of your mask like a commercial defogging solution and you will never find yourself without a defogger while on a dive. 2. Never lay your scuba mask face-down on any surface. Salt, sand and grit will scratch the lens of your mask. Always place your mask face up when you are not wearing it or if it is not in its hard case. 3. Rinse your scuba mask in clean, freshwater after each dive and dry it thoroughly before storing it in its hard case. After a dive, your mask will be covered in a salty residue and/or dirt. This must be rinsed clean to prevent the silicone on your mask from degrading. Your mask must be completely dry before storing it to ensure the silicone stays clean and odor-free. 4. Always store your scuba mask in its hard case. If your mask did not come with a hard case purchase an after-market hard case. This will protect your mask from dirt and abrasives and protect it while traveling. Always store the case out of direct sunlight. Direct sunlight will break down the silicone after years of exposure. 5. Periodically repeat the toothpaste treatment to keep the lens of your scuba mask clean. A good rinse after each dive helps to keep your mask clean, but to ensure there is no residue or grit left on your scuba mask you must properly clean it on a regular basis."
Posted on Dec 01, 2008
  • 2712 Answers
SOURCE: how to choose a scuba mask
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
  • 2712 Answers
jaballou
  • 63 Answers
SOURCE: Avalon Mask strap assembly broke
Try to spread apart the clip using two sets of small nosed pliars on each side of the clip, therefore not applying any pressure to the mask. Best wishes with a wonderful sport!
Posted on Jan 05, 2009
Obertelli
  • 3006 Answers
SOURCE: the clasp to connect mask to snorkle broke. can I
In short, no. But just do as many other do and use a short rubber band. Lay the middle of the band across the inside of the strap, and then pass the snorkel tube through the two resulting loops either side of the strap.
Posted on May 29, 2010
Provent Therapy does it really work for sleep apnea?
Provent therapy very effectively work for sleep apnea condition. If you wonder how this therapy works then follow the link http://www.directhomemedical.com/30-DAY-PROVENT-therapy-sleep-apnea-treatment.html
Jul 23, 2014 | Ventus Medical Provent Sleep Apnea Therapy...
Clean cpap mask
HOPE THIS HELPS IT DID FOR ME.
Mar 04, 2014 | Respironics Amara Full-Face Mask with...
Sleep Apnea Relief in Charlotte, North Carolina?
Contact your doctor, who will probably schedule you for a sleep study, to see if you need special equipment to prevent sleep apnea.
Oct 26, 2013 | Verizon OEM Blackberry Storm 9530 9500...
The other end of the elbow will not fit into the tubing. Do I need to take the plastic piece off?
There should be a clear plastic end on the mask tubing. This fits inside of the white rubbery tubing that fits onto the machine. It is a tight fit the first time or two you put it on.Try sliding it in one side at a time.
Oct 03, 2013 | Respironics Wisp CPAP Nasal Mask with...
CPAP WONT TURN ON
Have you tried turning the machine on with your mask on your face? I have to blow a puff of air into the machine in order to activate it. You might also try bringing the water (distilled only!) up to full level. Good luck with your machine, they can change your life!
Mar 17, 2013 | iPhone Apps
What does a CPAP breathing machine actually look like?
cpap-breathing-machine-actually-look-yp05kui1bmoa5vtfxl1yxlad-4-0.jpgTHIS IS ONE KIND BUT THERE ARE DIFFERENT TYPES OF CPAP MASK
cpap-breathing-machine-actually-look-yp05kui1bmoa5vtfxl1yxlad-4-1.jpgTHIS ONE COVER THE NOSE AND THE MOUTH.
THE OTHER TWO THAT I KNOW OF COVER EITHER THE NOSE OR THE MOUTH ONLY.
Feb 13, 2013 | Health & Beauty
How do you know which CPAP snoring masks are best for you?
FOR ME I HAD TO HAVE A SLEEP STUDY DONE. IT IS A 2 DAY PROCESS. THEY HOOK UP ALL SORTS OF PROBS ON YOU AND MONITOR YOUR BREATHING. THE TEST WILL SHOW HOW MANY TIMES YOU STOP BREATHING. THEN YOU GO IN ON ANOTHER DAY AND THEY TRY DIFFERENT MASK DURING THE STUDY. ONCE YOU GET ACCUSTOM TO IT THEY MONITOR YOUR SLEEP AGAIN. THIS TIME, IF IT WORKS, YOU SLEEP THE REST OF THE NIGHT. FOR ME IT WAS WORTH IT.
My doctor suggested that I try sleeping with the CPAP machine to help with my terrible snoring problem. Are there any websites that sell them?
Take a look at the CPAP man site as they have a range of related products; http://www.cpapman.com/store/
Including masks, machine and humidifiers.
What is CPAP? I know it's something to do with sleeping and snoring.
CPAP stands for Continuous Positive Airway Pressure. It involves wearing a pressurized mask over your face while you sleep at night to help force air through the airways.
CPAP is used to treat sleep apnea and heavy snoring but the machine is very noisy and it's not comfortable to sleep with, so it's worth trying other solutions before turning to CPAP for help.
How to choose a scuba mask
Dec 01, 2008 | Vision Mares Pure Mask
Scuba Diving & Snorkeling Logo
689 people viewed this question
Top Scuba Diving & Snorkeling Experts
ray gallant
Bill Boyd
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
