Question about JVC Audio Players & Recorders
The volume knob on my JVC receiver is loose and the volume cant be turned up or down by the knob. Can i use a remote to turn it up or donw or do i have to look for a new receiver?
    Scholar:
  • 60 Answers
Assuming your receiver came with the ability to be remotely controlled, then yes, a universal remote such as the Logitech Harmony etc, will be able to control the volume.
Posted on Dec 10, 2014
SOURCE: overheating?
I know this post is pretty old, but I just came across it. I have a GTP-750 that I have fixed. They do run extremely hot which causes the rectifiers in the power supply to fail. I have the rectifier part numbers to fix it as well as cooling method. I have been running mine now for about a year after fixing it sometimes at high levels for extended amounts of time and the case is now barely warm. If you need advice or pictures of my setup send me an e-mail
Posted on Apr 26, 2007
snakehead
  • 1074 Answers
SOURCE: AV-DV75 volume control not working
Hi Deebo check the following website www.dalsani.com www.repairworld.com good luck open the set and you will find the part number printed on the body of the component. NB.but i am in the belief that it IS your IC that is damaged.
SOURCE: Volume not working on remote
Just get a universal remote like i did but i also had another technics remote from another unit.
Posted on Oct 01, 2007
marsrover
  • 682 Answers
SOURCE: volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Posted on Jul 05, 2008
drumbanger
  • 1199 Answers
SOURCE: Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Posted on Jan 06, 2009
How do you tighten volume knob
Some older units have a small screw in the side of the knob. Use the proper tool to tighten that screw. If there is no screw and it uses a flat metal spring use a dental tool to bend the spring gently back into place. If this is all plastic with no adjustment consider using silicone sealer. A small dab will keep it on and allow you to remove it later if needed.
Aug 28, 2014 | Alpine CDM-9821 CD Player
CAN NOT SET CLOCK ON MY JVC KD-G116
Is it KDG200 or KDG116?
In KDG200, press and hold SEL to display menu
Turn volume knob or press fwd or rev buttons to select CLOCK H and set.
Press Volume knob to save.
In KDG116, instead of turning the volume knob, use +/-. Instead of pressing the Volume knob use SEL
Mar 01, 2012 | JVC KD-G200 CD Player
How do I turn off the demo mode in my jvc kd-hdr44 radio deck?
Press and hold MENU. Turn volume knob to select group, press volume knob to select item, turn volume knob to select, and then press volume knob to save.
Mar 01, 2012 | JVC Car Audio & Video
How to use jvc kd-hdr20 car stereo. I need to know how to fix balance,bass,bluetooth,ect.
To pair a bluetooth device with the radio, turn on the Bluetooth function of the device. Then press the SRC (source) button on the receiver. Select BT Audio or BT Phone, depending on the device you want to pair with the radio. Use the up/down arrows to select New Device and press the down arrow. Select Open and then press the down arrow. Then enter the PIN by using the left/right arrows to select a digit and turning the volume knob until the correct digit is entered. (For some devices, you need to enter a specific PIN. Consult that device's manual.) Press the down arrow to set the PIN. Enter the PIN in the device you are pairing to the receiver (if it doesn't have a required PIN). Wait for the message "Connected" to appear.
To use the device in the future, press SRC and choose the appropriate Bluetooth type. Then use the right/left arrows to select the registered device. Press the down arrow and then use the right/left arrows to select Connect and press the down arrow. (See the manual, link below, for setting the autoconnect or autoanswer.)
To adjust the sound system balance, press and hold Menu to open the menu and then turn the volume knob to Audio. Press the center of the Volume knob. Then navigate to balance and adjust the unit as needed.
The manual for the KD-HDR20 is available from JVC on the product support page: http://support.jvc.com/consumer/product.jsp?archive=true&pathId=54&modelId=MODL028465 . The direct link to the instruction manual is http://resources.jvc.com/Resources/00/01/14/LVT1960-001A.pdf .
I hope this helps.
Oct 13, 2011 | Car Audio & Video
How do i get my jvc kd-r210 out of demo mode?
Press and hold the volume knob until it changes to a menu setup, by pressing the knob again once it should cycle to another option, keep pressing the knob until you get to DEMO. when you get to DEMO turn the knob as if you were turning the volume up or down and it should say DEMO OFF. there are many useful options in this menu, like sub control for low pass filtering, display options, turning the beep noise off/on, loud off/on, clock settings, and a few more
Mar 08, 2011 | JVC 50W x 4 MOSFET CD Deck with MP3...
Had a new battery put in my car and now when I press source only the CD and FM show up not the AUX for my iphone. Cant figure out how to get the AUX programmed back in there. Its JVC stereo KD-G310.
push the volume knob button in and hold it down until the psm menu pops up. your display should read "DIMMER" press the track forward button repeatedly until you get to "EXT IN" and then use the volume knob to select it. then hold down that volume knob button again for 4 to 5 seconds and your done
Mar 17, 2010 | JVC KD-G310 CD Player
Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Mar 08, 2010 | Kenwood Audio Players & Recorders
How do you set the time on the jvc kd-s35
Press and hold SEL button. Press ^ button 3 times to display H (hour) turn volume knob to change hour setting, press down 1 time to select M (minute) turn volume knob to change minute setting. Press SEL to finish the proceedure. Reference page 14 in this link to your JVC KD-S35 instruction manual.
http://books.jvcservice.com/Download/106224402/GET0563-001A.pdf
Nov 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
The Volume knob malfunctions
Hi there. Sorry I haven't got a solution. Just want to know if you found one, as I got the very same prob with the volume knob of my JVC hi fi. Thanks for your time.
Oct 05, 2009 | JVC MX-J30 CD Shelf System
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Oct 31, 2007 | Yamaha RX-V630 Receiver
91 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
