Question about Car Audio & Video
How do I fix this: A friend installed this stereo in my car. I can program radio stations on the push buttons along the bottom of the unit and they stay programmed, but when I program settings into the stereo - such as turn off demo mode, equalizer settings, etc., they do not stay set when I turn the car off. I'm having to re-program them each time. I'm wondering if this is an installation problem or a problem with the stereo. My friend did say when he installed the stereo that the previous stereo had been "hard wired" in and so he had to install this the same way.
  • 1 more comment
  • kakima Dec 10, 2014
    What make and model is "this stereo"?
  • Barbara Allen
    Barbara Allen Dec 11, 2014
    JVC KD-R650. I know how to program it. Problem is having to program it each time the car is started....
  • David Payne
    David Payne Dec 12, 2014
    try talking to customer support at JVC, phone numbrer is: 1-800-252-2752, then press 1.. between the hours of 8am to 8pm m-f.
    Top Expert:
  • 14,161 Answers
basic way of doing this
Posted on Dec 10, 2014
My car was on and suddenly the car went off,and the auto electrician removed the battery and fix the car on starting the vehicle every thing was ok but except the cd stereo displayed code then on our car...
enter the code slowly and push the button for the next station
Depending on the make and model of the radio you input the code using 1-4 buttons then enter it by pressing 5
Dec 20, 2010 | 1998 Ford Explorer
How to lock in radio station on kenwood face off cd player
once you have the station you want to listen to on the radio press and hold one of the buttons along the bottom of the stereos face for a few seconds the screen should flash for a second or two or it should beep as well to indicate its saved it.
if when you turn the ignition off and then turn it back on the stereo has forgotten the station you programmed you need to remove the stereo from the car and check the wiring at the back of the unit. most of them have a red and yellow wire that are joined by metal push fit connectors, swap these two over and it will then remember the station for you.
the red wire is the switched power lead from the ignition and the yellow lead is a constant live feed for it to remember your settings, if these are round the wrong way it will keep forgetting radio stations you program until you switch them over.
hth
Dec 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Cannot play ipod in 99 daewoo lanos
instead of pressing the left/right scanning buttons hold them and then let go when you want to stop
Aug 15, 2009 | Daewoo Lanos 1999 Car Radio/stereo...
The stereo is Clarion M5675 older.
yes... you may have to push that same number again when it flashes though. its been a while since i played with that radio
Mar 29, 2009 | Clarion M5675-RET CD Player
How do I set radio stations into my car stereo?
have you tried just holding the preset button down ??
Jan 23, 2009 | Panasonic Car Audio & Video
Car radio
On the face of the stereo is a * button. Push this button then use the numbers on the face of the stereo to go directly to that station. Example, my favorite classical station is 90.7. Push the * then 907. This station will appear in display. Then push and hold for about 5 seconds the preset button you would like this station to be. The stereo will momentarily blink to a different station then come back. Station set.
Oct 20, 2008 | Becker Car Audio & Video
Stereo code for 1994 3000gt
You will need is the information from the label that is located on the top of the radio. To remove the radio is really quite easy.
1. Gently pry the trim plate from around the radio. This can be accomplished by taking a flat blade screwdriver and carefully prying up and out at one of the bottom corners. Once you see it pop out, repeat this on the other bottom corner. The bottom will be out and you can then pull the top away from the dash to remove it. There are two small plastic tabs on the bottom of the bezel, and two metal clips on the top that secure the trim to the dash. Very easy to do.
2. Once the trim is off you will see 4 phillips head screws that attach the radio to the dash. Remove them one at a time (be careful not to drop them into the dash like I do every time I do this LOL). Once the 4 screws are removed simply pull the radio towards you out of the dash. You do not have to remove it completely to see the tag, it is located on the top of the radio on the drivers side.
3. Write down the numbers on the tag. One is the model number that is in bolder lettering that starts with either an MR or MB. The other is the serial number.
4. Call practically any Mitsubishi dealership and ask for the service department. Tell them you are looking for a code for your radio. They will more than likely just need the serial number and within seconds will give you the code for it. This way you also don't have to take it in and have them charge you for "fixing the radio".
Once you have the code, reinstall the radio, turn the key on, turn the power on to the radio and enter the code pushing the #1 station button until you get the first digit, then the #2 station button until you get the 2nd, the #3 station button until you get the 3rd, then the #4 button until you get the 4th.
The next step depends on your radio. Once you have the code showing on the radio you will either have to push the "program" button to enter it, or the "Cassette" button to enter it.
You will have 3 chances to do it right, and if you fail and the radio says "lock" on the display do not panic. All you will need to do is leave the key on for one hour or so, and the "lock" will dissapear, and "code" will return.
Aug 17, 2008 | 1994 Mitsubishi 3000GT
Satellite radio controls
FixYa,
I went back to "Best Buy" installers and they quickley pointed out that I had pressed the scan button, and that it was still activated.
I pushed the scan button again, that turned it off, and the new sirrius satellite radio is now working perfectally.
"Thanks"
Jack
Jun 28, 2008 | 2004 Scion xB
Region problem
Try this for the tuner fix. Turn unit on.Hold down (volume down and SRC )buttons and unit will power off.Keeping them in also press and then release the reset button(bottom right hand side) .Release the other 2 buttons and unit should now restart with 50khz fm spacing and 9khz am spacing.If you find out how to change region code,Post It
Jun 09, 2008 | Kenwood DNX7100 Car Video Player
Very weird Radio Tuning Problem
This is a USA model and by default in the USA all FM stations end in an Odd number. This is completely normal. you can try holding preset 1 and 5 down while pressing the reset button on the unit and it may allow you to switch to a Europe style of tuning.
Oct 10, 2007 | Kenwood Sirius KDC-MP522 CD Player
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
