Question about Dryers
How do I check to find out what's wrong with my Whirlpool dryer without having a service guy come look at it
  • 3,506 Answers
Read the codes and then check them against the paper document supplied with or in the machine panel
Posted on Dec 10, 2014
  • Jerry Pickering Jr
    Jerry Pickering Jr Dec 10, 2014
    how do I find out what code is showing
  • jfhinton45 Dec 10, 2014
    you should find that information in the paper also. I am assumingm the dryer is new enought to have comperization.
Hi, I have a Whirlpool dryer mod LHE780 that is running without heating up. Can you suggest a fix?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | Whirlpool Dryers
Everythings running but without heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 13, 2010 | Whirlpool Dryers
My Whirlpool mod# lgb6300pwo ser # mso902052 type dwsr-nat-120606 fm22 runs without any heat. Therefore, no drying. Checked the exaust ,the gas is on . What is the next point to check?
heatman101
Oct 11, 2010 | Whirlpool Dryers
No heating?
If the unit runs and heats for a short time, then only runs without heating, it may have bad gas coils(2 solenoids that are screwed on to top of gas valve)
If the unit runs without any heating would check the ignitor or the thermal fuse.(ignitor is fragile)
Check it is not accidentally set in air fluff....
Most all whirlpool dryers are front serviceable by lifting the top(two screws by air filter and putty knife pushing in about two inches on each side in front) Some have a lower front panel, most you remove the front to access parts. Sharp edges and unplug while servicing. The ignitor and thermal fuses can be ohmed out at a service store. There are other possibilities, these are the most common, good luck.
Apr 19, 2010 | Whirlpool GGQ8831L Gas Dryer
My whirlpool duet dryer beeps and the lights are on across the panel but wont start
I have the same problem. Tech guy says it's the electronic panel, doen't have one and it will be 10 days to get it and $370.00 to fix?
Anyone have a service manual?
Mar 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Can I run my Whirlpool HD Commercial Dryer on a 120/208 supply
you should change your heating element to a 208v element. go to your local appliance service depot and ask for 208 element for whirlpool commercial dryer and they will know what your asking for.
Dec 04, 2009 | Whirlpool CEM2760KQ Electric Dryer
My dryer only blows cold air I replaced the
Yes it is quite possibly your thermostats, A kit can be purchased for the majority of all Whirlpool dryers and is around $30.00 part number is LA-1053. But it can vary based on your model. However the first place i would have technician check is the fuses or breakers inside your home as this can often cause the dryer to only run on 110v when 220v is need to run both the motor and the element.Hope this helps.
Thanks
Nov 22, 2009 | Whirlpool Dryers
Problem with Whirlpool Duet gas dryer
Hi I have the same problem
Bypassed the hi limit switch and it runs fine
service teck replaced board,thermistor, all vents,gas coils , flame sensor and glo coil andf all with no luck. Unless it is bypassed thed ryer will only stay on 5 to 6 seconds on gas cycle
If i plug my old dryer in and hock up to gas and vent it works fine
So im using my old dryer and this peice of **** is sitting beside it as Im not going to run this without the safety thermostat
If you find out please let me know
Jan 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer
not element, same element runs Hi and low temp
whirlpool dryers have 2 thermostats,
40degreeC (low)100F
60degreeC (high)140F
the 60degree thermostat has failed
cost is between $15 and $40 depending on how the 'parts guy' feels on that day
the dryer is easy to open, check any of the 'change belt' questions or Joks instruction brief
Oct 26, 2008 | Whirlpool LER4634J Electric Dryer
Water in my Whirlpool Front Load Dyer exhaust..
Greetings ireneosanch,
Has it been taking longer than normal for your dryer to dry the clothing also leading up to this? Sometimes your ventilation can become so clogged that it will cause condensation to accumulate in the exhaust hose. I would check the vent on the outside of your house and see if it is clogged and you might also have to have the actual ventilation cleaned out leading through your house.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
Top Dryers Experts
