Question about 1997 Chevy C/K Pickup 2500 Block-It 380 Truck Cab Cover
My 1997 chevy cheyanne pickup will not start when it rains.
Just cranking it.
  • Robert Jacobs
    Robert Jacobs Dec 11, 2014
    It cranks,but won't turn over.
  • Covercraft Master
  • 906 Answers
Good advice Jeff, I had a Yamaha that was like this, I finally had to spray the entire electrical system with a silicone based water repellent, that fixed it.
Posted on Jan 29, 2015
  • Jeff Youtsey
    Jeff Youtsey Feb 02, 2015
    Thank u and hope I helped!!
    Habit-Forming:
  • 19 Answers
I would suspect bad spark plug wires; they leak worse when damp or wet. Bad coil wire for example, can leak so much that the spark never gets to the distributor.
Generally, I have found that good high voltage (plug/distributor) wiring will even work well with a hose spraying water on them; whereas, bad wiring will cause miss or even a stall.
You can watch the wiring at night and bad wires frequently show up with a glow or spark [stay clear to avoid belts, fans, etc.] I have also run a grounded screwdriver along each wire. However, if one is bad --- replace ALL of them.
Posted on Feb 12, 2015
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 104 Answers
Well i tell u that i have had cars and trucks that do this! Why i am not sure . Check and make sure that the seal is around the back part of the hood Is not displaced . (above the distributor) If water is leaking directly on to it that could be your problem! Also make sure the cap is good ! Need more info? So let me know if i can help!! good luck
Posted on Dec 18, 2014
2001 chevy blazer cranks but wont start when its been raining. Will eventually start but may kill battery first
Hey Tom if its rain, look to see if moisture is affecting wires a spray of WD-40 in and around electrical could really help and wont hurt any thing WD stands for =water dispersant.
Oct 05, 2014 | Cars & Trucks
S 10 pickup wont start after rain
Pray for the rain to stop, Then it will start,
Oct 30, 2012 | 1997 Chevrolet S-10 Pickup
1999 Chevy astro van won't start
Had the same issue with our 1999 chevy astro van, would crank but would not start. It had been raining and windshield had a leak, after 2 days of no rain it started. Pulled codes and was the Security system in the ignition switch. Hope this helps.
May 04, 2012 | 1999 Chevrolet Astro
1997 chevy s-10 6cyl won't start with new battery. Engine turns, but it won't crank.
crank no start? I would check for fuel pressure on these models, the fuel pump module is quite often repalced. Then I would check ignition cap and rotor. Cap get white with corrosion and rotor green.
Nov 29, 2010 | 1997 Chevrolet S-10 Pickup
The engine will not crank the battery seems to be strong
yes could be the solenoid as well as the starter and/or other things like the ignition switch and/or anti-theft module or aftermarket alarm
May 14, 2010 | 1997 Chevrolet S-10 Pickup
1997 chevy s-10 wont start easy
might need your injectors cleaned. or check your fuel filter. or your fuel pump is going
May 01, 2010 | 1997 Chevrolet S-10 Pickup
Got home, went out 2 hrs later, cranked but no fire at all. No previous problem. 1997 Silverado 5.7L.
simply check the battery cables.
I had a 93 s-10.Even a lttle bit loose will cause it
not to start
Feb 21, 2010 | 1997 Chevrolet S-10 Pickup
1997 Nissan Pickup Won't Start in very High Humidity
Sounds like there may be water or condensation entering your distributor cap. Cheap fix and might be obvious if you inspect its inside.. look for corrosion or moisture.
Dec 07, 2009 | 1997 Nissan Pickup
1997 Chevy S-10 6 cylinder all of a sudden cut off and won't start back. It will turn over but seems like is not getting gas or is not firing one.
probably a fuel issue on this one. get a big hammer and have someone crank the vehicle whikle you bang the bottom of the tank. If it tries to start-suspect fuel pump.
Dec 04, 2009 | 1997 Chevrolet S-10 Pickup
1997 Chevy C/K Pickup 2500 Block-It 380 Truck Cab Cover Logo
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
baire
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
