Help! I'm looking for the remote control for a Sherwood AX-4050R amplifier, to buy. Anyone have one? Or will another remote do the same job? (on/off, volume, track forward /back).
    Scholar:
  • 60 Answers
I'd try ebay. If no joy there, then find an el-cheapo remote & try inputing the code for your brand. Here's a link to some Sherwood codes. Good Luck.
http://www.nktelco.net/wp-content/uploads/2011/12/ADBHDBlackRemoteRG.pdf
Posted on Dec 10, 2014
4 Suggested Answers
marsrover
  • 682 Answers
SOURCE: POWER OUTPUT OF A SHEERWOOD AMP MOD NO AX-4050Rwhat
100watt-rms.
Posted on Apr 26, 2008
  • 4234 Answers
SOURCE: Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Posted on Nov 30, 2009
  • 4 Answers
SOURCE: Yamaha AX-500 amplifier won't turn on!
Check fuses in back. If not fuses the power supply is dead. Buy a new one. They do weae OUT EVENTUALLy
Posted on Mar 09, 2010
Sherwood ax 4050r
'Direct' disconnects the EQ normally. Don't trash your amp because of a noisy EQ when you can bypass it.
Mar 05, 2014 | Audio Players & Recorders
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
Sherwood rv 4050 wont power up
internal fuse....open and replace
Feb 22, 2011 | Sherwood RV-4050R
Sherwood RV-4050R compatible with new gear?
The TV is irrelevant.
BD would need HDMI, digital audio or 5.1 analog inputs on the contol receiver. You have none of these.
Jun 19, 2010 | Sherwood RV-4050R
The main transformer in my Sherwood amplifier is down the primary winding is open circuit. I cannot find the transformer outputs as to replace it. does any one know the voltages and current ratings for...
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Jan 25, 2010 | Audio Players & Recorders
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
Need help hooking up surround sound with my Sherwood DAS
Sherwood's site has a manual for the model RV-4060 (click here to download) but not for the 4050. You might find it similar enough to help you. Otherwise you can try a Google search for generic Dolby surround connections. It's usually pretty straightforward. Connect the audio out from your source (TV, DVD player, etc.) to the receiver. Connect the surround channel speakers to the appropriate rear panel jacks. Fire up a source you know has Dolby encoding, turn on receiver's Dolby processing from the front panel, and experiment with the different modes to hear what you get. Just remember you can't break anything just by pressing buttons.
Jun 02, 2009 | Televison & Video
Sherwood AX-7030R amp - doesn't switch on.
Something doesn't sound right. The standby circuit is usually very simple. The "regulator" is just a transistor. Can you request and post the parts that he/she can't find. I should be able to get you a source or substitutes.
Dan
Dec 16, 2008 | Sherwood A-965 Amplifier
88 people viewed this question
 Grubhead
Grubhead
