Question about Sony KDL52W4100
I like to what I need to replace the problem is stated below please help: I try to turn the tv on I hear a click like its about to turn on then I hear another click then nothing. I see the red light
Took cover off then disconnected power to main bord the green light didn't stay on . Disconnected power to inverters the green light didn't stay on.
    Top Expert:
  • Sony Master
  • 74,211 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 10, 2014
Testimonial: "Thank yo so much I will follow your advice and replace the bords after I go through the link above."
My Samsung TV won't turn on
Please describe the problem more accurately. Flashing red usually means 'stand-by' state, flashing blue/green - starting up. When (during that) do you have a sound? Are there any 'high voltage' sounds like soft screeching from the screen? Is it LCD or LED?
Mar 02, 2015 | Samsung Televison & Video
Popped lamp, rapid clicking after replacement
Take it out and get in there with a vacuum. There are fans that keep it cool and there is a color wheel that might be damaged. All those shards need to be removed
Jan 22, 2014 | Mitsubishi Diamond WD-65831 65" Projection...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
May 31, 2010 | Samsung HCN4226W 42" Rear Projection...
It wont turn on
You give us littel to go on here. Can you describe what happens (if anything) when you attempt to turn on the set? Is there a click? Is there a standby light on the set before you try turning it on? Is there sound or nothing at all?
While possible, dead sets are not usually caused by a blown fuse. If the fuse is blown, then the power supply will need work. If not blown, the power supply may still be the problem. Please update this with any other symptoms and we'll try to assist further.
Thanks,
Dan
Apr 08, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Just replaced a new lamp. TV tried to turn on/off
Ur tv have a Ballast board that help to ignite the lamp.U hear alot of clickings,that mean the ballast board is dead,not doing it job.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Feb 28, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
T.v. clicking and wont turn on..
Hello:
The loud pop you heard is usually indicative of a failed lamp. The clicking noise you hear is likely the ballast trying to turn the lamp on.
If you need assistance with a new lamp, please feel free to contact us at www.dlplampsource.com or 866-764-5822.
Regards
Dan
Apr 12, 2009 | Mitsubishi WD-65731 65" HDTV
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Sony KV-32HS510, worked perfect, turned on the next day and all I got is flashing red light.
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Oct 19, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony KDL52W4100 Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
