Question about Elna Sewing Machines
How do i thread the elna 344
ALL THE INSTRUCTIONS IN THE BOOK HAVE READ THAT IN THE GREEN THREAD YOU HAVE TO REVERSE 2 THREADS????? I THINK I HAVE ALL THE OTHERS DONE RIGHT
SOURCE: Elna threading and reverse instructions
Hi
I have a Primula 310
The reverse is located in the middle of the stitch length dial, you press in the button whilst you reverse.
When threading up any sewing machine make sure the foot is 'up' as this opens the tension disks and the thread goes between. when you lower the foot the discs close around the thread and add the tension.
Hope this helps
Posted on Nov 01, 2007
  • 255 Answers
SOURCE: How to thread an Elna 2005
Hi. I've searched a number of my sources for a manual for your machine, but the closest I could find is for the 2002-2004-2006 models at http://www.mastersewusa.com/info_elna_2002_2004_2006.html
Threading should be similar enough between your machine and the ones covered in this manual that you can see what's going wrong.
Hope this helps!
Robbie
Posted on Jul 30, 2010
SOURCE: new 344 elna overlocker - can't thread lower
I have been dealing with the exact same problem for 2 hours and no answers!! I have just discovered that if you move the stitch width finger to R instead of N, your threader will work!! Hope this helps :)
Posted on Nov 30, 2010
  • 4 Answers
SOURCE: I need a diagram for threading a 4 thread serger
The inside diagram is for the loopers. For the needle threads, just follow the color coded dots.
Posted on Dec 03, 2010
Tally Girl
  • 1133 Answers
SOURCE: on my elna 6004, why is my ziz zag stitch loose
Possible causes:
top tension dial set too low
top tension dial not working at all
top thread not seated into top tension discs
top thread hasn't been threaded up correctly, missing out the tension discs or take up lever
Most likely your top tension device is either set too low, or gunked up and not working right or has actually failed. Can you access the tension discs? If so, turn dial to zero and 'floss' between the discs with the selvage edge of a clean piece of waste cotton fabric and see if any black stuff comes out. If so, continue until it comes out clean. Turn back to 5 or the marked normal setting.
Now thread up again from top spool down to tension, through take up lever, then down to the eyelet just above the needle. Lower the pressure foot to engage tension then pull on the thread downwards. Is it hard to pull? If not, then the tension dial is faulty and you'll need to get the machine serviced.
If this feels firm and hard to pull, then take a look at the lower thread tension but this shouldn't normally need any altering (unless you've adjusted it previously for some reason and not reset it to normal setting). Check thread is fully into the tension spring, bobbin is in the right way and bobbin case is in fully in the correct position.
If you look at the zig zag stitiching you've done, can you identify if the loose thread is the top one? If you use two different coloured threads for troubleshooting, this often makes it a bit easier to see what's happening, just make sure they are the same weight and brand of thread if you do this.
I hope this helps you to identify the problem and fix it. But if you suspect that the top thread tension device is just not tensioning the thread even if you turn the dial right up to 7, then you'll need to get the machine serviced as the dial could well be faulting.
Posted on Oct 11, 2011
How do i thread Elna 1200 also bobbin placement.
You should probably find an owners manual. Search for:
Make Model manual
(however, Elna manuals are seldom free)
IMPORTANT TIPS:
ALWAYS RAISE the presser foot when threading the top thread! Install a brand new needle at least every 8 hrs of sewing or whenever it strikes something. AVOID old and bargain bin threads.
How To Thread An Old Elna Sewing Machine
Elna Threading Instructions
Nov 17, 2017 | Elna Sewing Machines
Elna Pro 4De serger thread breaking
Be sure to thread each in the ORDER specified--for most machines (but yours may differ) upper looper, lower looper, then needles. Follow (closely) the threading diagram on the machine. Missing one guide or hitting the guides out of order will throw you machine into a tizzy! On my serger, the lower looper has to lay over the top of the upper looper/thread before it all gets pulled under the presser foot toward the back of the machine.
It also may help to RAISE the presser foot when threading the machine.
Having problems threading my Elna Pro DE 4 sewing discussion topic...
Threading elna lock pro 4 DE green knob
Oct 06, 2017 | Elna Sewing Machines
Hi there, I have elna 654 overlocker, problem is cutting off green thread. How to fix it?
Check the tension disk and thread guides of that green thread. Make sure there is no build-up of lint or broken threads hanging up anywhere. Also, make sure the thread coming from the spool and all along the thread path is not wrapped around something causing the thread to hang up. Usually, if the machine will stitch for a couple of inches and then you see the green thread tightening up, then breaking, it is hanging somewhere.
When threading, RAISE the presser foot so the thread will seat properly in the tension disk. Give each thread an extra little tug when threading the tension disk.
Last, set the tension disk to the midway point between high & low number. Then re-test.
If it is still a problem, you may need to take it for service.
Aug 01, 2016 | Elna Sewing Machines
When I am monogramming with my Elna 8600, the thread continually breaks, what could be the problem?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Dec 04, 2014 | Elna Xplore 8600 Computerized Sewing...
Why do stretch stich on elna overlocker become to tight for single knits and seams snap
Sounds like a threading problem rather than the stitch, have you raised the thread aerial pole to full height first up, its something that can be overlooked. The threads come off the cones very quickly so its critical that the pole is elevated and the threads are flowing smoothly. Look at the cones and check that a thread isn't getting caught under the thread stand too or wrapped somewhere like the flywheel; anytime a thread is snapping, always take a good look at your thread paths and check for obstructions, check tension numbers are right and work through the threading path.
May 10, 2014 | Elna Sewing Machines
Thread jamming in bobbin when i use walking foot
Had a similar problem with our Pfaff. Needed a replacement cam. broken gear.
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
I need a manual for an Elna Special machine. I am not sure of how to thread the machine properly and I don't know what one of the dials on the front of the machine does.
There is also a Yahoo group for Heirloom Elna owners which this model is.
You can find threading diagrams and manuals at www.sewusa.com. the supermatic will be closest to your Special. This webpage has images of threading the bobbin; all Swiss made Elna's have this wonderful top loading bobbin system and they are great. Important: use Elna bobbins, they have holes on the TOP ONLY. When you wind the bobbin, ensure the thread winds evenly by nudging the thread with your finger tip, keep the thread under tension as it winds by placing the handle of your scissors onto the top of the thread reel. Cut the thread, then place the bobbin into the bobbin case, holes upwards. The bobbin will turn anticlockwise as you pull thread from it. Follow the directions from the threading diagram, you need to "click" the thread into the tension spring. Now thread the top thread through the marked locations in the diagram. Hold the end of the thread as it comes from the needle and manually turn the flywheel to lower the needle down and up once to catch the bottom thread and bring it up to the needle plate.
ALWAYS hold both the two threads at the back of the needle plate when you start sewing, really important. I tally_girl.jpg You will have a knob with numbers going from -4 to 4, this is your stitch length dial. The negative numbers are "Reverse" normal stitch length is 2.5. The white knob is stitch width when the needle swings from side to side. Straight stitch would be zero, and then higher numbers for zig zag etc. The little wheel gives you different needle positions. And the metal slide at top of case is the reverse lever.
Hope this helps you a little. Early Elnas are all very similar and wonderful machines to use.
Feb 24, 2011 | Elna Sewing Machines
New 344 elna overlocker - can't thread lower looper After aligning thread in V cut-out of automatic threader it will not move far enough to the left to engage the thread. There is a metal part of the...
May 14, 2010 | Sewing Machines
Hi
Hope this helps
Oct 31, 2007 | Sewing Machines
Sewing Machines Logo
88 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
