Question about Linksys Wireless-G WRT54G Router
Port forward on linksys wrt54g2
How to port forward shareza
  • 3,960 Answers
Please follow the instructions found here: http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G2/Shareaza.htm
Posted on Jan 19, 2015
  • 720 Answers
You need to look at the router housing to find IP address of server.
usually looks like 192.168.0.1 and the user and password should be there too .once you are ...www.routerlogin.net you will find port forwarding options in advanced settings.you can google the default addresses for any type of router if there is no info on yours.
Posted on Dec 10, 2014
Where do i find the port forwarding?
To access the Port Forwarding option of your router, you will need to access the router setup page and from there you will find Application and Gaming tab and there you will see the sub tab port forwarding that is where you can open the port that you need to work behind the router.
Aug 12, 2011 | Linksys WRT54G2 Wireless Router
Trying to get XBox 360 Live to work and connection fails....I'm at a loss trying to figure out what to do
Check your XBox (network settings) and make sure it's getting valid IP from the Linksys router.
Normally, opening ports (port forwarding) on the router for that specific game should resolve this.
Hope this helps! Just reply back if you needed step by step guide.
Angel
Jul 20, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
MY LINKSYS WRT54G2 IS OK BUT CAN'T FIND SERVER.
The Linksys WRT54G2 is Cable/DSL router with 4 port switch. It has many features including a built-in DHCP server. By default, it's IP address is 192.168.1.1, username: blank and password: admin.
Plug in the Modem to the Linksys router's Internet / WAN port then plug your PC's to any of the 4 ports (1,2,3 & 4). The Linksys router once turned ON will automatically provide your PC with IP address starting with 192.168.1.xx (x means number from 100-149).
Make sure that known working ethernet cables are being used. Check your computer's IP adress by going to the command prompt. Start>RUN>type CMD then press Enter. Type IPCONFIG and check the IP address (e.g. 192.168.1.100). Check you PC's network adapter if you don't get an IP address from the Linksys router.
You may opt to reset the router by pressing the reset button at the back for 30 seconds if it fails to give out DHCP.
Cheers!
Angel
Jun 22, 2010 | Linksys WRT54G2 Wireless Router
How to port forward
This site has great step by step guides for many different games and software.
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54GX2/WRT54GX2index.htm
If your application isn't on there, follow the guide for any application, but change the numbers of the port in last few steps to the port ranges you need.
Good luck, don't hesitate to message me for more help/clarification
Dec 27, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Have Linksys WRT54G2. All port led's are lit and
How is your router connected? If you have all port lights lit, either green or orange, and nothing connects seeing the Internet, are your problems with wireless access? Is the Wireless set correctly, by going to http://192.168.1.1 and logging in to the router? Make sure the SSID (network name) and other security measures are set correctly ... I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you choose to log in with wireless devices.
Nov 11, 2009 | Linksys Wireless-G WRT54G Router
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
Set up my linksys wrt52g2 v1
Go to this site and scroll down to the section "Configuring your Router to work with Port Triggering"
http://portforward.com/english/routers/port_triggering/Linksys/WRK54G/Warcraft_III.htm
The username & password for the router is by default admin/admin.
Hope this helps
Mar 16, 2009 | Computers & Internet
Srx 200: how to port forward so I can live stream
Click the link below for the instruction on how to do port forward.
Click HERE
Jan 24, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
NO SERVICE BETWEEN MY LINKSYS AND MY PS3
You need to enter the router configuration. How you do this varies by model, but usually involves typing your gateway address into a web browser. Then, you need to assign your xbox an internal IP address and activate port triggering or forwarding (depending on the sophistication of your device) to send information on the designated ports to the Xbox.RICHARDM69
Dec 12, 2008 | Linksys Wireless-G WRT54GS Router...
Port forwarding
Go into the admin program, select Applications and Gaming, type in any name to reference it with in the first column. Type in your start and ending ports. Keep the protocol at both. Type in the last set of numbers that the IP address needs for the computer that you are forwarding to. Select enable. Select the save setting button.
Sep 09, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G WRT54G Router Logo
95 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
