Question about Canon Cameras
Canon pc1251 won't take picture with flash on. it will if i turn off flash
New batteries, set it on manual setting with flash on. still won;t work
    Top Expert:
  • Canon Master
  • 6,702 Answers
Check if your camera is on automatic. Then f there is too much light it won't work. To use a flash for fill in, you have to be on a scene mode. Check the manual. If the camera has a flashing light, indicating the flash won't work, you have a serious problem.
Posted on Dec 16, 2014
SOURCE: Battery Indicator Flashing and then Camera Shut down
I have the same problem on the same cammera. I sent it to canon and they say they will fix it for free. I have the same problem on a canon a530 and sent it to them also. My wife had droped that one and put a dent in the metal around the lense worked fine but they said they must fix it along with the battery problem at a cost of $108. Give them a call 1800 652 2666.
Posted on Feb 26, 2007
SOURCE: Canon SD 550 does not work when flash setting is ON
I have the same problem. Cannon customer support says it will fix this for $119 + 8 for shipping... or you can get a refurbished SD 800is for $140+10 for shipping with w/ a 6 month warranty... what a deal ;~)
Posted on Mar 27, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Canon powershot SD600 - flash doesn't work
It could be the sensor or a short in the flash wiring. You should take it into a camera shop and have them look at it. You could be covered under warranty if the camera is less than a year old.
Posted on Jun 22, 2008
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
t00nz
  • 4738 Answers
SOURCE: camera turns on, but no picture, using new batteries
First try pressing your DISPLAY button to see if that corrects the problem. If not, then the problem is likely a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 24, 2009
Canon pc1251 flash won't fire
If it even won't fire in a manual mode, when it is dark and you did press the flash button, it could be defect. Be aware that in some Basic Zone modes the flash won't fire. If you did put it in sport and in a few other modes it won't work. So try it in dark and don't forget to switch the flash on.
Dec 10, 2014 | Canon Cameras
Flash stopped working
Your problem is in the settings. Glad maybe turned off set flash to auto.
Jan 02, 2018 | Canon PowerShot A70 Digital Camera
Canon 600ex-rt speedlite won't turn on with new batteries
I was having exactly the same issue with my 600EX-RT. This is what solved the problem for me. With the power turned off. Hold down the 2 clear buttons for approximately 5 seconds, then turn the power on and hopefully, you should have a fully operational Flash.
Apr 14, 2013 | Canon Speedlite 600EX-RT 5296B002 Norman...
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
My flash is not working. the icon keeps flashing for a long time before taking the picture before it takes a picture. I've reset the settings and tried all the different modes and cannot get ii to...
I found this somewhere else and I was surprised that it worked. Reset to default settings. Press menu, arrow right to the tool menu. Arrow down to Reset All, arrow right to yes.
I had tried different batteries, even alkaline to get it to work thinking that my batteries were old and weren't charging the flash. I saw that someone had done the reset all to fix it. I did it and tried to take a picture, the icon flash twice and then the flash charged up and took the picture. I replaced the batteries to lithium and now it charges up right away. I hope that helps.
Dec 26, 2010 | Canon PowerShot A590 IS Digital Camera
Flash does not fire.
In auto If it does not fire the flash bulb or flash board in camera will need service. In auto it will fire all the time as a fill flash.
Jun 14, 2009 | Canon PowerShot A700 Digital Camera
Wont take pictures with flash
The problem is in the battery holder of the CR1220 battery.
-Take out the CR1220 battery (the little round one).
-When you replace it, put a bit of aluminum foil against the back, between the battery and the plastic holder, to make it a nice tight fit. One layer won't do it, but don't put in half the roll.
-Put it back in. Done
Using a fresh battery & clean it all with alcohol = good idea as well. Worked for me.
Wich
Apr 24, 2009 | Canon PowerShot A720 IS Digital Camera
Canon A 630 no flashing
Right now Canon's support section for their website is down.
What I'm looking for is to see if the flash was turned off by the control panel accidently. Most digital have a setting to turn it off.
Typically if the camera needs a flash and can't give you one you will get a warning message on the screen. If thats whats happening, then the sensor is working.
Sometimes weak batteries will cause the flash not to work because there may be enought current to run the screen and the shutter but not enough to run the flash at the same time. If you say the batteries are fine then that probably isn't the case.
If you have the book handy you might want to check the control panel settings and find the flash controls.
Jun 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
No.
Try taking a picture without the flash. Go to a mode other than Auto (try Portrait), and turn off the flash. If the camera takes a picture, then the flash itself is not working properly.
First thing to check is the safety feature that turns the flash off if the case is opened. Look on the bottom of the camera, and make sure that the center two screws are in place. If you're missing one of the center screws, then that's your problem. Replace the missing screw with either of the other two bottom screws.
If the screws are in place, again try a new set of batteries. Sometimes you can get a bad set of batteries right out of the package. If new batteries don't fix it, then the flash itself probably needs replaced. This is difficult, requires some soldering, and goes beyond what I can describe here.
May 18, 2008 | Canon PowerShot A400 Digital Camera
Cameras Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
