Question about Tablets & eReaders
I have responded to all of your requests to no avail. I can only retype this simple request so many times. once again my reset button on the outside of my d2-721 tablet will not respond, for a hard re
I have added all the details I can it is ONE simple question . please read above
  • 1,249 Answers
D2 support page enclosed. I would try for a replacement. http://www.d2pad.info/index.php?option=com_wrapper&view=wrapper&Itemid=141
or just go buy another for $50
Posted on Dec 10, 2014
Benimur
  • 6966 Answers
SOURCE: Thinkpad does not respond - bizzare!
Hi, Based on your post/description that it was not the laptop that was dropped and that all the connections are snugly fitted to where they should be, the dropping of the moused caused the laptop to be dead, then it is likely that the +5VDC of the mouse cable has shorted to the ground wire. The short is reflected towards inside the motherboard of your laptop. This +5VDC is common to all the USB ports, PS2 ports, and many other parts of the laptop. The short would open up a fuse somewhere inside. I can only surmise that the power supply is involved. You may need to check that the powersupply/AC adaptor (if present) is giving juice to your laptop with the use of a VOM, since as I understand it, simply plugging in your laptop to the mains would lit an indicator that ACpower is available. Normally a surface mounted fuse is on the motherboard right after the jack where the AC adaptor plug comes in and right before a reverse protection diode. If you are uncomfortable opening your unit and would not be in a position to do component level repair, you are probably better off seeking the services of a qualified service professional. Hope this give you and idea. Good luck and kind regards.
Posted on Aug 20, 2007
  • 4 Answers
SOURCE: taskmanager popup
Let's start as simple as possible:
Do you have a loose connection / glitch at the power-connector? Check and solder (link to manual for disassembly is further down in this document)
To me this looks like a stuck key (not necessary one on the keyboard):
create live-usb-ubuntu:
1. download and burn ubuntu 8.10 to cd.
2. boot _any_ computer with it, connect >1GB USB stick.
3. System --> Administration --> Install to live usb
4. Boot from live-usb-stick that you just created
5. open terminal (Applications --> Accessories --> terminal)
6. paste this: sudo apt-get install xev
7. paste this: xev
8. hover with mouse over white box
9. make sure not to press any keys or move the mouse. Now flip the screen or try to recreate a situation in which the task manager would pop up in windows.
10. what's the output in the terminal window? Try to pinpoint exactly how and when the events are generated.
There should be no event generated, when you physically flip the display (which means you don't have to replace the hinge).
Press every single key you can find on the laptop. Verify that each key generates exactly one event.
If you find that there is a series of events generated without any key pressed, try to clean the malfunctioning key. (Service manual for disassembly)
It might possibly be a broken hinge (20USD). Flipping the display and pressing soft keys (Q, rotate, e) does not generate events in xev. Any other button does.
Posted on Nov 06, 2008
anupam19
  • 263 Answers
SOURCE: How do I hard reset
Go to HP care.they may solve your problem
Posted on Feb 05, 2011
  • 12 Answers
SOURCE: Hi guys, during upgrade I did
Have you tried the hard reset? Try these instructions for a hard reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
Posted on Mar 05, 2011
cougar123
  • 77 Answers
SOURCE: the 7 inch tablet when you turn it on shows the 2 dogs then goes to rca logo and nothing else. tried to reset by holding power & volume button at same time, did not work
contact vendor mfg - shoulds be under warranty
Posted on Jul 11, 2014
How do i reset my zeki tablet when the factory reset wont work
on Zeki Tablet you had to hold both the "Reset" button and the "volume up" button at the same time for about 15-20 seconds it than boots into Safe Mode which you can select a full factory reset. NOT VOLUME DOWN.
If this fails, 1 888 999 4215 is Zeki support. If in warranty, tell them of failure of factory reset. They may request it be sent to them.
Jun 11, 2017 | Tablets & eReaders
Register fire to amazon account
Direct from online directions:
To register your Fire tablet outside of the initial setup screens:
  1. From Home, swipe down from the top of the screen and then tap Settings.
  2. Tap My Account.
  3. Tap Register.
    • If you already have an Amazon account: Enter your Amazon account information, and then tap Continue.
    • If you do not have an Amazon account: Tap Start Here, and then follow the instructions to set up a new account.
Note: If you've forgotten your Amazon account password, you can reset it by requesting that a personalized "password reset" link be sent to your e-mail address. To learn more, go to Reset Your Account Password .
Dec 03, 2016 | Amazon Tablets & eReaders
Can not log into iTunes each time I try I have to reset new pass word.
sorry to read about your troubles. I have not fully understood, are you only unable to access Itunes or are you having problems with other websites also?
May 27, 2015 | Apple iPad Tablets & eReaders
If the button does not respond it might be broken. If you have a slip case on your tablet it might be stopping you from fully depressing the button.
Dec 10, 2014 | Tablets & eReaders
How do i reset my tablet memory it wont start
Hi Zac! Usually, you will have to press and hold a combination of buttons like for example, the "volume up" key and the "power button", or the "Menu" button, "Volume Up/Down" Key, and or the "Power Button"... To be able to help you accurately, I would like to request if you could provide the specific brand and model number or the tablet device or gadget that you need to reset. Thank you.
Sep 22, 2014 | Tablets & eReaders
Hello i Need help to Download whatsapp on my iPad
It could be one of two things. Either the app isn't compatible with your iPad (the version of WhatsApp Messenger that I'm looking at is only for iPhone), or the Apple servers sometimes have so many requests that they can't deal with all of them at once. If the app is available for iPad, just wait a while and try again.
Jul 19, 2014 | Apple iPad Tablets & eReaders
Gmailkluunlock
You can reset your tablet to the original setting but it will delete all applications, Videos, Files and any other stuff that you have in the tablets internal storage
You can reset the tablet by using a paper clip to poke the reset hole for 1 minute while the tablet is turned on.
The reset button is located on the side of the tablet, this will reset the system and restart it self and you would notice that all other apps will no longer be there.
The second option is to access the recovery menu on your tablet to reset the system. Again, all applications and any files in the internal storage will be deleted.
To reset:
1. Turn off tablet
2. Press and hold Volume up and power at least 30 seconds to get the menu up,
3. Keep poking the hole to get in to the Wipe data and factory reset then press power to select
4. Once the it process the request, go back to the previous menu and select on restart for the device will power cycle.
Jun 05, 2014 | Curtis International KLU LT7028 Android...
How do i get a new charger
try going to Google.com and typing in the charger number it should show you possible vendors to choose from.
Mar 30, 2014 | Digix TAB-840 Android 4.1 OS Tablet PC
Can i restore my polariod 7 tablet to factory setting without messing up my iphone and laptop files.
Yes, its possible to hard reset your tablet. Turn off the device, hold the power and Volume up buttons together. Once the device turns on release the power button and continue to hold the volume up button. A Sceen with the android service icon will appear. Press the Volume up button once more then you will see a couple of selections. Press the volume down button and select (wipe data/ factory reset) option. be sure to press the power button to select the option. scroll down using the volume keys to (YES- Delete all user data) then press the power button again. Your device will begin to wipe its self. Once the selections appear again select (reboot system now) your device will restart and youll be back to when you first purchased.
Francisco Torres
Wefix Wireless Technician
Wefix Wireless
Aug 14, 2012 | Polaroid 7-in. Internet Tablet - Other
Tablets & eReaders Logo
52 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
