Question about Refrigerators
I have a water tank behind the top drawer of my LG. Itseems to be empty I have checked the supply to the fridge and it is fine. I removed the filter and pressed the lever, water comes out. put filter
There is water going to the filter. Water comes out of the hole where the filter is installed. Nothing when it is installed
    Master:
  • 706 Answers
Sounds like a problem with filter. Was it having problems before installing new filter. Filter may be in backwards. I recommend reinstalling the filter
Posted on Dec 10, 2014
My water tank in the back of the drawer is empty. I removed the filter and pressed the water lever in the door and water comes out from where the filter was. I replaced with cap that came with the side by...
The filter head sounds like it may be defective, the bypass plug allows the water to pass through the filter head to the tank and on to the fountain. You can also try a new filter as the filters can be defective too. Pleazer Appliance....
Dec 10, 2014 | LG LSC26905TT Side by Side Refrigerator
Leaking water into bottom of fridge and freezing under deli drawer
Check the water lines. There should be a replaceable water filter in the interior of the fridge. Possibly the top portion, behind a panel.
Sep 03, 2014 | Refrigerators
My water dispenser is not working properly. It starts out with a good flow, then immediately slows down to a trickle. It started this after I replaced my filter. I removed the filter and tried the...
Hello, Thank You for using FixYa. I will be helping you today.Have you changed your water filter?If you have one it will be inside the fridge or on bottom in the front. This also happens when the water pressure is to low going to the unit from the house. If all those are ok make sure the tank in the fridge behind the drawers is not frozen,You can use a hair dryer to thaw out the tank
Thank You and please rate my answer if it was helpful...
Jun 22, 2011 | Whirlpool Refrigerators
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Filter indicator on samsung side by side fridge freezer is on
2 places filter can be top left upper corner of fridge or behind the fridge with a little longer filter type
the smell could be the filter but i would pull all drawers and shelves and i would check for mold also the possibility of water leak behind panel of water spout that has molded over this smell you could never forget cause smells like old gym socks
Apr 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Feb 11, 2008 | Freezers
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Mar 20, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
